New XRAY 808
Old 05-08-2008, 10:22 PM
  #796
Originally Posted by mazzinga
Many Thanks Rocco,
only 5gr from my body and your......mmmm... I think that engine, pipe and servos are the trick mmmm....
according to the manufacturer-homepage the MAX-engine weighs only 330g. RB and OS are around 360g i think.
illebille is offline
Old 05-08-2008, 10:23 PM
  #797
Originally Posted by Nik
shoo goo bonds just about everything to just about anything. Its used to fix lexan bodies and glue together batteries for electric cars among other things
thanks!
Old 05-08-2008, 10:40 PM
  #798
Trader Rating: 18 (100%+)
The car works better with less droop try it and you will see. If the track is really ruff maybe a little more droop but not much.
infanterene is offline
Old 05-09-2008, 12:30 AM
  #799
RETRO RC's Avatar
Originally Posted by Greg M
I think those weights are abit out Adrian.
Mine weighs 3268g with no fuel. Mines got abit lighter since the North Islands, but I'm pretty sure Tims is about what mine weighs now.
sorry greg had a bit off a brain fade should have read 3260 and 3320
RETRO RC is offline
Old 05-09-2008, 12:58 AM
  #800
Greg M's Avatar
No need to apologise. My XT8 is 4358g, I guess Tim's is 4320, not 3320
Greg M is offline
Old 05-09-2008, 08:41 AM
  #801
rmargiotta's Avatar
Trader Rating: 59 (100%+)
Originally Posted by illebille
a bit offtopic, but:
i had to use google to find out what shoe goo is. what for is it on a rc-car?
I use it to reinforce my body and protect my paint, I'll snap a pic of the inside of my body to show you where I do it. I can run 1 body for the whole season doing this. I don't add that fiberglass tape, as some others do tho...
Originally Posted by rezenclowd3
Rocco, with your recommended droop settings, (103, 113mm) it seems as if there is very little droop at all. I see that the STOCK setup sheet has -2 on it which would imply that the droop is 2mm below ride height. This seems abnormally high. Is this correct?
Yeah, its what I ran at Silver State on my prototype car and when I built my production car, I measured the shock tower mounting positions to ensure I would have the same geometry and it is. But it does look weird but with this car so sensitive to setup (which i LOVE) that weight transfer (which is the only thing droop controls) means A LOT to the the setup.
Originally Posted by Vigilante212
Ok well im about 80% through the build now only things left is to put electronics in and radio tray.
I had a few other small issues. First issue I had a RHCS bolt with a crushed hex in it, not really Xrays fault, just stuck a SHCS in its place. They supplied the wrong size bolt for one of the mounting holes for the bottom of my center diff mount, the spare parts bag solved this issue. and one other issue the pipe hanger was too large in diameter for my dynamite 086 pipe so I just ground down the end to fit inside the hole.
Did anyone install the pipe protector? I did, but thought it was kinds goofy to be cutting holes in the side protector for it, but no biggy.
The wire is too big for the Max Power pipes too, I just drill the pipe out, because I'm likely to have different pipes over the life of the car/pipe hanger. I personally don't run the stinger guard (unless I run the thin Max Power pipes) the nuts that secure it to the side guard can also beat up the bottom of the pipe, so heads up!
Originally Posted by captain america
I don't know if it's worth all the fuss for just a few grams. Can anyone show factually that such a menial amount of weight has a significant impact in perfrmance or run time?
A bunch of 5g add up to a lot of grams tho!
rmargiotta is offline
Old 05-09-2008, 08:42 AM
  #802
The -2mm number in the book is used IF you are using the Hudy setup station. You set the chassis on the 30mm thick blocks then the bottom of the hub should be at the -2 step on the droop gauge. If you are not using the Hudy setup station then I would suggest using Rocco's Center to Center length for the shocks.
Chris
ccm399 is offline
Old 05-09-2008, 09:04 AM
  #803
Crim3Wav3's Avatar
The XB808 is a Sex Machine! I don't want to get it dirty...lol
gonna have to do a spray bomb body for the races this weekend....i suck at painting
Crim3Wav3 is offline
Old 05-09-2008, 09:16 AM
  #804
Trader Rating: 96 (100%+)
Crimewave- RCE on Saturday? I may have to make a special trip up there to show Bob where the wall is.
K.Copeland is offline
Old 05-09-2008, 09:18 AM
  #805
rmargiotta's Avatar
I asked XRAY to put a shock length section in the setup manual and the setup sheet, but nope, who cares about being UNIVERSALLY EASY TO UNDERSTAND!!!
Crime - Good lookin' ride bud! Those one color paint schemes are bummers!
Old 05-09-2008, 09:30 AM
  #806
Crim3Wav3's Avatar
Kevin: I think it's going to be an RCE day on Saturday for sure...we are gonna get hammered by Sky Tears today and tonight.
Can you bring a sick pack reciever battery for me? I will certainly pay you for it with "favors"..lol
Old 05-09-2008, 09:47 AM
  #807
Steve Walters's Avatar
How's the Losi starter box mate up with the 808 chassis? Any modifications needed to be done? If so, what? I would like to have everything ready to go when mine arrive.
Thanks....
Steve Walters is offline
  #808
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Chris
Ya, I understand that. TC has taught me much more about setup than offroad ever has. The Hudy Setup station does not come with the droop blocks btw, only the camber and toe plates.
rezenclowd3 is offline
Old 05-09-2008, 11:02 AM
  #809
Thanks....
Friend of mine was starting his 808 off a Losi box the other day. Dropped right on no mods needed. The box was starting both cars all night!
Chris
ccm399 is offline
Old 05-09-2008, 11:17 AM
  #810
Vigilante212's Avatar
Ok can someone tell me if I did this right. Its my first time setting up an 1/8th scale linkage.
Vigilante212 is offline
