New XRAY 808
Old 08-27-2010, 08:42 PM
  #7846
grizz1's Avatar
The Proline Crowd Pleaser 2.0 gets my vote. It looks real swift with nice lines - to my eye anyway
grizz1 is offline
Old 08-27-2010, 08:54 PM
  #7847
Jaz240's Avatar
Trader Rating: 52 (100%+)
I like the Bitty low profile
Jaz240 is offline
Old 08-27-2010, 09:14 PM
  #7848
xlgraphicspro's Avatar
who stocks the bitty bodies?
xlgraphicspro is offline
Old 08-27-2010, 09:26 PM
  #7849
Jaz240's Avatar
I dont know. I run the Illusion. I think the Bitty's are only overseas but I think thats the nicest looking one of the 3.
Jaz240 is offline
Old 08-27-2010, 09:43 PM
  #7850
Bitty is Italian...
ganymede is offline
Old 08-28-2010, 06:38 AM
  #7851
brandon_101's Avatar
Trader Rating: 23 (100%+)
what is the most comon setup most of you is running on your 808?
brandon_101 is offline
Old 08-28-2010, 06:50 AM
  #7852
Gizmatron's Avatar
+1 on the j concepts illuzion body...I have several myself and like both the shape and the quality..the proline is nice too but you can only run low profile filters which I don't like.The j-concepts has the space for high volume filters.
Gizmatron is offline
Old 08-28-2010, 08:40 AM
  #7853
bigmatt's Avatar
Trader Rating: 16 (100%+)
I am painting up 3 different skull themed bodies. The costumer will chose the base color. The bodies are 1 of each. I my self like the low body[original] with the losi 2.0 filter system. I get my best run times 13 min's+ with that filter. Even in dusty conditions.
bigmatt is offline
Old 08-29-2010, 12:27 AM
  #7854
grizz1's Avatar
Going to try running the Dynamite brake linkage kit on the 808.
Seen these on a few cars now and the set up seems to work very well. It also eliminates the problem of the brake linkage levers getting close to the spur gear, and makes for easy brake trim adustments on the fly. Any one else tried this or a similar set up. I think someone was talking about a Kyosho set up similar to this the other day.
http://www.amainhobbies.com/product_...ke-Linkage-Set
grizz1 is offline
Old 08-29-2010, 12:47 AM
  #7855
Gizmatron's Avatar
Not tried the dynamite linkage but I'd be more worried about hitting the body in the other direction than the spur gear.probably have to set it up to get the lengths right then trim off all the excess linkage length..looks a nice set up though.
Old 08-29-2010, 02:41 AM
  #7856
grizz1's Avatar
Yeah, that's what most guys have done. Truggy is fine, but the rods can hit the body on a buggy unless trimmed depending on your set up. Worth a crack I reckon.
grizz1 is offline
Old 08-29-2010, 04:31 AM
  #7857
hyper9boy's Avatar
ive seen this style of ball cup make the brakes bind make sure they click on nice
hyper9boy is offline
Old 08-29-2010, 08:02 AM
  #7858
bigmatt's Avatar
that's what I use. will just need to trim the length of the rods.
bigmatt is offline
Old 08-29-2010, 10:49 AM
  #7859
Jaz240's Avatar
I tried that set up a while ago and I took it off. I don't remember if it was because the rods sit at a weird angle to the brake cams or if it was because the rods that slide into the cams themselves were too long or too short but it was not smooth and level like it should be. It was binding in two spots from what I remember and was more trouble than it was worth to try and get it all smooth and level
Jaz240 is offline
Old 08-29-2010, 10:53 AM
  #7860
Trader Rating: 156 (99%+)
thats set-up is not really anything like the kyosho set-up. the kyosho set-up that we use is the set-up right of the mp9/wc777/st-rr which instead of using fuel tubbing it uses a small spring for a more consistent feel
skoalisbad4me is offline
