New XRAY 808
#766
I had to shim mine, one shim in front and two in the rear. I like to shim mine a little close at first until they wear in during chassis and diff break in period . Then I will check again after a good day of running ,and after that I'm good to go.
#767
Finished building (well 98% of it) my 808 last night and it went together really good. I LOVE the new shocks, they are really really smooth and amazingly light weight for their massive size. The new seal pack at the bottom is so easy to build it is just ridiculous. The only problem I had was that one of the rear arms was a tiny bit tight on the inner hinge pin hole, which was easy to fix with a few quick passes from my Hudy arm reamer. Everything on the car look really great. I can't wait to get the body painted and final assembly done so I can go drive it!
#769
Has someone perhaps weight a 808,say with proline tires and empty tank.I have a 8ight and want to change,what do you guys think?
#771
#772
much more stable car and it makes the 8 look like a brick over jumps
Adrian
#773
Well lets just say.... its been a long time coming! I'm back in a big way!
World Domination BEGINS!!!!!!!!!!
.....oops got a little carried away... sorry guys!
Seriously, this 808 buggy is insane... I've had two Losi's, and well that buggy just doesn't even compare!
I ran out of orange paint and totally screwed up my paint job hence all the stickers, but I'm ready to rock this sucker!
Will follow up with setup sheets as I dial...
Oh ya you can get those filter covers on UndergroundRC, in tons of different colors... they work very well!
#775
UPDATE!
Team Xray XB808 screw kits are now in stock!
Team Xray XB808 325-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, lock washers and set screws.
Please note: The kit does not include the 3.5mm x 22mm and 3.5mm x 45mm diff screws. It also does not include the 4x10mm flanged button head motor mount screws (Xray part # 911410). These are specialty items. Please purchase these from your nearest Xray parts supplier.
Thanks and best regards,
#776
I also suggest replacing some of the button heads with cap heads for the same reason. They are much easier to get in and out with the larger 2.5mm hex socket. If you're in the middle of a long race and break (or even in warm-ups) and need to get back to the pits to quickly change a part, the cap heads make life much easier (especially if there is dirt in the hex socket which is very common on screws like the lower shock mounts).
#777
agreed. I have already taken a few screws from my Mugen "extras" for this reason exactly. The upper and lower shock mount screws, and the sway bar lower mount screws (which are a pain to access without a ball tip driver and once they are 2.5mm cap heads you can use a ball tip driver without worry of stripping)
I have almost completed the build....only thing left is the shocks. I did have an issue with one of the front CVDs. The little metal insert which the pin goes into had some burrs on one end. When i assembled it, there was major binding. After staring at it for 15 minutes i decided to dissassemble it, chuck a wooden q-tip in the drill and run it through for a few seconds...problem solved. (big relief..i was nervous that the part was machined incorrectly!)
...man i wish there was a yellow wing included instead of white!
The car is REALLY easy to build. I would put it on par with Mugen quality...which IS saying a lot.
#778
On the subject of the small shims for the diff that are explained on page 5, IMO, it is not neccesary to use them at first build, and that is why they are not shown on page 6. As the diff gears(ring and pinion) wear in, then you may need to shim the ring and pinion tighter to tighten up sloppy mesh. I MAY BE WRONG. Or maybe I just got lucky cause mine seem perfect w/out using any shims. (I have had to do this w/ almost every buggy I've ever run....Ass. Mugen, Jammin, Kyosho, Etc.....
Rocco, feel free to correct me if I am wrong or misread the directions.
I haven't heard much talk of clutch shoes and springs. Any body try different springs????
Thanks, Dan Reino
Thanks, Dan Reino
It's all good. If you're new to XRAY, one thing to always remember: if you're having a tough time fitting something, you've done something wrong! It's what I LOVE about their kits.
#780
Regarding diff shims: you could also assemble the diffs with no shims at all and then (if needed) use Hong Nor #J20 shims that is mounted outside the bearings - see pic. They just come in one thickness though @ 0.2 mm. Its 4 in a bag...
I would guess they are available also in the US under the Jammin brand but I have no clue on what # they have over there.
