New XRAY 808
Old 08-04-2010, 04:01 AM
  #7681
Trader Rating: 25 (100%+)
there been leaking from new. there about 3 meets old.
i havent tried new bodies and caps. but ive tried different caps and bodies to see if i could elliminate what it was.
still does my head in. there obviously machined wrong
Jarred King is offline
Old 08-04-2010, 04:04 AM
  #7682
one more question, did you install the bladders using the manual's method or adam drake's method?
ganymede is offline
Old 08-04-2010, 04:12 AM
  #7683
Adam drakes method.
whats the difference? no matter what way you put it in the shock cap should seal the bladder to stop leaking shocks.
Old 08-04-2010, 05:02 AM
  #7684
Adam drakes method.
yes, it doesn't really matter which method but with adam's method you have to make sure when you screw down the shock cap, the shock bladder is nicely fitted inside the groove of the shock cap... which you can't see...
if you use the manual's method, the manual specifically reminded user to seat the bladder inside the shock cap snugly before capping it...
i used both methods without any sign of leaking YET...
i also make sure when i screw down the shock cap, the shock cap goes in nice and square...
ganymede is offline
Old 08-04-2010, 08:21 AM
  #7685
Jaz240's Avatar
Trader Rating: 52 (100%+)
Jarred, I'm just throwing this out there for what it's worth. Don't know if it is causing your problem or not but when XRAY released the new shocks with the new bottom caps and shock boots they did not redesign the shafts or bodies to compensate for the increased up travel. In most situation at full up travel your piston nut will hit the shock bladder. When this happens it may very well be causing a slight lift of the seal and allowing the oil to escape. Try one more thing before you give up:
put 2 shaft O rings around the top or the shock shafts right under the bottom shock cap before your slip the dust boot on. This will prevent the nut from hitting the bladder upun full up travel
Jaz240 is offline
Old 08-04-2010, 10:22 AM
  #7686
merdith6's Avatar
Default There you go
that's what I was thinking......
merdith6 is offline
Old 08-06-2010, 09:40 AM
  #7687
CJ Weaver's Avatar
Does anyone know where to get the Much-More LiFe pack? The part number MFE-RF1600, but I can only find it on the Much-More Japanese website. I know someone posted that they were running it a while back, but I was wondering how you got it.
Thanks.
CJ Weaver
CJ Weaver is offline
Old 08-06-2010, 12:30 PM
  #7688
razo125's Avatar
+1 The 2 orings work but make sure you use soft o-rings, if they are the hard ones they act as a extra spring and bounce your car.
Also with the 09/10 shorter lower shock caps, the rubber boots seem to function as the limiter when your shocks bottom out. So technically you should not need the o-rings unless you don't run a shock shaft dust boots. The problem is these get worn or damaged pretty quick on rough tracks. At that point they no longer work as well limiting up-travel.
If your getting leaks on the bottom o-ring seals... I think it's already been posted but some people are using kyosho or mugen o-rings
razo125 is offline
Old 08-06-2010, 12:38 PM
  #7689
808gx7r's Avatar
Thanks.
CJ Weaver
http://goracingnz.vpweb.co.nz/default.html
808gx7r is offline
Old 08-06-2010, 12:52 PM
  #7690
CJ Weaver's Avatar
Thanks!
Old 08-07-2010, 08:07 PM
  #7691
bigmatt's Avatar
Trader Rating: 16 (100%+)
I have a problem. I did the adam drake foam compensator losi shock trick. set the rebound for 50% but the shaft will not return by it's self from full compression back to the 50% like it shows in the video. I am using air filter foam for the compensator. Any body have any ideas? also any one have the height and circumference of the foam that needs to go on top of the bladder? isn't it like 5mm thick and fit into the bladder? I'm thinking I cut the foam to small not putting enough pressure on the bladder.
bigmatt is offline
Old 08-07-2010, 08:26 PM
  #7692
Trader Rating: 96 (100%+)
I did the drilled shock cap thing, used some dense foam, and have no rebound at all.
K.Copeland is offline
Old 08-07-2010, 08:47 PM
  #7693
Trader Rating: 21 (100%+)
Does anyone know if xray will be releasing a 2011 version buggy next yr?
TopGearRC is offline
Old 08-08-2010, 10:43 AM
  #7694
Zerodefect's Avatar
Doubt it. The 2010 is about as good as it gets.
They should be concentrating on the E 810 right now!
Zerodefect is offline
Old 08-08-2010, 11:13 AM
  #7695
mmaattppllaayy's Avatar
Trader Rating: 35 (97%+)
Im sure there will some improvement always can improve those pinion bearings and maybe some better sealing bottom shock caps. If the shock shaft is 3.5mm then they need a 3.4 mm oring to seal it not 3.5mm easy fix
mmaattppllaayy is offline
