New XRAY 808
Old 07-23-2010, 01:37 AM
  #7516
808gx7r's Avatar
Originally Posted by grizz1
I am thinking a bent shock shaft ??? Only other thing that could jam is the piston if it's got out of shape somehow (maybe done up a little tight and got squashed outwards). My money would be on a bent shock shaft though.
they are strait. plus... one night they were fine... next day i was testing something an pushed down(buggy had not been run) and it stayed down but i did run it after wards on grass and it become fine??
so its got me beat
808gx7r is offline
  #7517
Originally Posted by Jaz240
My most vastest experiences are with crashing, and I can say the 808.809, and 810 take a beating like no other buggy out there and keep coming back for more
Jaz240 for President of XRAY Addicts Anonymous Group!!!
ganymede is offline
Old 07-23-2010, 01:38 AM
  #7518
so its got me beat
you sure your arms are not binding? check the hinge pins also...
ganymede is offline
Old 07-23-2010, 01:42 AM
  #7519
808gx7r's Avatar
its deffently the the shock
808gx7r is offline
Old 07-23-2010, 01:43 AM
  #7520
Jaz240's Avatar
Trader Rating: 52 (100%+)
took them off. took out the oil and it seems to lock up sorta...(when going up and down with the rod...)
what you are describing can only be one of three things:
bad pistons
bent shock shaft
Rocks/mud/gravel/dogfood, jammed in the bottom end caps
Jaz240 is offline
Old 07-23-2010, 02:25 AM
  #7521
808gx7r's Avatar
bad pistons
bent shock shaft
well. i replaced shafts... but my old ones wernt bent... new pistons... still locking up a tad...
808gx7r is offline
Old 07-23-2010, 02:34 AM
  #7522
shesha's Avatar
Look at the cases roundness most likely not round anymore maybe oval shaped like an egg.
If that not the issue, do you wash your car with shock boots on ?
If so I would suggest you inspect the shock shaft after a wash the metal shafts changes colors a bit and gets some sort of dirt to it, just polish the shaft and try to see if that fixes it.
It could also be your orings being worn out, if not i would check every moving part of the arm being free to drop by itself and make sure its not the shock.
Quick trick to know if it is the shock or not the arms section, remove the shock bottom arm screws an compress if the shock pushes back your in the clear, if not then something in the shock itself.
Also pay attention to the top shock cap screw mounts they can bend and cause a similar issue.
shesha is offline
Old 07-23-2010, 02:35 AM
  #7523
shesha's Avatar
grizz you got pics of the mod ?
I just took a look at the losi 8 2.0 shock cap pics and dont see where the vent holes are.... custom mod by A drake ?
http://www.amainhobbies.com/product_...ock-Caps-Top-2
shesha is offline
Old 07-23-2010, 02:49 AM
  #7524
808gx7r's Avatar
shock bodies? they are still perfectly round
808gx7r is offline
Old 07-23-2010, 02:52 AM
  #7525
shesha's Avatar
http://www.rctech.net/forum/attachme...ck-mod-img.jpg
http://www.rctech.net/forum/attachme...d-img_0001.jpg
Just found the article on losi thread
Personally I would go with foam inserts instead of orings.
shesha is offline
  #7526
grizz1's Avatar
The vented shock caps are only on the Losi 2.0 Euro.
Have you watched the video a few pages back on shouck rebuilding ?
No pics sorry. Just drill a similar sized hole to the bleed hole in the top of the shock cap, so it enters into the crown of the cap which will be inside the bladder when assembled (hope that makes sense).
Cut a Losi or Kyosho compensater foam in half and fit it between the bladder and the cap after you have bleed the shock down to get the correct rebound.
The video by Drake explains it very well.
grizz1 is offline
Old 07-23-2010, 03:42 AM
  #7527
808gx7r's Avatar
bad pistons
bent shock shaft
fix'd it... a tip for everyone. never rebuild shock infront of a gas heater... i moved to the shed... nice and cold... and they worked fine once back on buggy....
hey grizz. can you tell me what person you are in one of the auckland clubs photos????
808gx7r is offline
Old 07-23-2010, 08:21 AM
  #7528
juzza99's Avatar
Ive found with the ribbed bladders ,that you dont need to run the foam in the cap.
juzza99 is offline
Old 07-23-2010, 01:00 PM
  #7529
shesha's Avatar
Thats what I would have thought also, the bladder from the pics looks much more stiffer then the 09 spec I have on.
Thanks for sharing...
shesha is offline
Old 07-23-2010, 01:03 PM
  #7530
shesha's Avatar
Yup checked out Drake's vid, actually thats a really good video will save me time rebuilding my shocks, hell I have to go through 30 minutes everytime I rebuild them to let the bubbles settle and rebound etc.
At the nitro party I noticed Stanley W. and Hara using vacuum pump to really get rid of the air bubbles, I guess people always look for perfection...
Thanks for the exp Grizz.... hope to see u at the WC..
shesha is offline
