New XRAY 808
Old 03-19-2009, 03:48 PM
  #3961
jhautz's Avatar
Trader Rating: 86 (100%+)
Also, Whats the part number for the new longer rear body post? I'm getting one of them for sure.
EDIT: Wait a minute.... Will the longer post work with the originall 808 style body still?
jhautz is offline
Old 03-19-2009, 03:57 PM
  #3962
elcaminosslover's Avatar
Trader Rating: 60 (100%+)
[QUOTE=rmargiotta;5572122]Which shop?
RCXRAY.com
elcaminosslover is offline
Old 03-19-2009, 04:05 PM
  #3963
Trader Rating: 38 (100%+)
I see the new version on Ebay for $610 shipped and with the 10% Live.com Cashback deal, it's not too shabby.
Breakin2 is offline
Old 03-19-2009, 04:11 PM
  #3964
I just saw that myself also, I have already paid RCXRAY.
Old 03-19-2009, 04:21 PM
  #3965
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jhautz
Thanks Rocco.
So all I would need is a spring retainer and an o-ring then. Not the whole assembly.
Honestly, I dont have a problem with this now so I probably wont even bother.
Dont take the chance! My servo saver spring backed off during a main, and my steering was Gone!! If you are not going for the upgrade, then pour CA on the threads...its amazing how we learn the hard way...Dont be a "me" save your servo saver..
Jaz240 is offline
Old 03-19-2009, 04:31 PM
  #3966
vince7870's Avatar
Trader Rating: 15 (100%+)
yes they will work with old body. if you cannot find xray ones, you could use the ocm ones they work perfect as well....old mugen trick had them laying around in my box
vince7870 is offline
Old 03-19-2009, 04:34 PM
  #3967
jnfweld's Avatar
Those cones things are the new shock boots they are acordian style.
jnfweld is offline
Old 03-19-2009, 06:12 PM
  #3968
Trader Rating: 16 (100%+)
Default Active diff
Do you need the active diff outdrive adapters to use the active diff. or will the standard ones work?
wrayth is offline
Old 03-19-2009, 08:28 PM
  #3969
Thanks for the heads up on the oil rocco.I had already put 3k in.
BTW I borrowed a buddys Hudy pin replacement tool & did all mine again & must say if your gonna do pins OUT of the car the Hudy tool is the way to go,super easy & quick & super hard metal,no marring from the hammer.Gonna buy my own.
Rocco could you explain what you get from running your front lower hinge pins all the way down & your upper camber link all the way down.I dont understand other than raising the chassis up what it would do.I seem to remember you saying something about it before but cant find it now.
butch man is offline
Old 03-20-2009, 07:18 AM
  #3970
rmargiotta's Avatar
Trader Rating: 59 (100%+)
No problem!
I'm trying to separate the roll center and center of gravity so I can get as much roll/grip as I can.
rmargiotta is offline
Old 03-20-2009, 08:12 AM
  #3971
Hey Rocco, I have ordered the new 808 from MacHobbies and it will be here soon. I have seen your starting set-up for the 808 and was wondering what set-up you are using for the race this weekend at Indy Rc? Could you please note the parts that are not included in the kit that is in your set-up? I going to get those parts ordered as well. Here in OKC, we have no XRAY parts at any LHS's. Thanx -Craig
Old 03-20-2009, 10:36 AM
  #3972
Alffa164's Avatar
Has anyone had any experience with Prolines V3 series tires? I put them in the rear, they make the car incredibly stable but they steal some steering. Is there something i can do to get more steering with this tires? Should i use lighter diff oil in the rear?
Alffa164 is offline
Old 03-20-2009, 12:03 PM
  #3973
I have had no issues with not enough steering while running V3s as the 808 has so much steering. I would lighten up the front diff oil and see if that helps.
-Kane
Kane-o is offline
Old 03-20-2009, 12:24 PM
  #3974
Merciless's Avatar
No problem!
Originally Posted by rmargiotta
No problem!
I hope you don't mind me chiming in, but if you want as much roll as possible, you'd want to be running the upper links in the upper position also ? Just trying to understand your reply fully Rocco.
Rod
Merciless is offline
Old 03-20-2009, 05:05 PM
  #3975
Banter's Avatar
Default 09 spec parts for sale!
See the two 808 '09 spec parts I have for sale here!.
Banter is offline
