New XRAY 808
Old 12-30-2008, 04:15 PM
  #3046
jrwoodchuck's Avatar
thanks!
jrwoodchuck is offline
Old 12-30-2008, 06:49 PM
  #3047
RC Huligan's Avatar
Originally Posted by Jaz240
Maybe they can get Les Porter to help them with a new site, hint, hint, wink, wink
<under breath>I believe something is in the works right now, but you didn't hear it from me.</under breath>
RC Huligan is offline
Old 12-30-2008, 07:24 PM
  #3048
question, a LHS has xray front and rear adjustable hinge pin holders for the XB8 and they say they will fit the 808. they have them for a great price and i will snag them if they fit. so will they?
thanks
Old 12-30-2008, 07:50 PM
  #3049
Jaz240's Avatar
Trader Rating: 52 (100%+)
Originally Posted by jrwoodchuck
i saw in another thread and someone also brought it up at the track about going to the 8x16x5 bearings on the diff outdrives. is this on all 6 or just the front and rear difs?
These larger bearings will allow you to fit diffs into housings without the plastic bearing shields that come with the kit. some people believe the shileds were causing the bearings to overheat. I cut the front of the shields out to help disapate heat, and still allow original bearing size to fit. be advised, once you remove the plastic shields the bearings need more attention as they will get dirty faster..
Jaz240 is offline
Old 12-30-2008, 08:06 PM
  #3050
Good question jrwc. I bought the rear set to fix a handling problem that was caused by my own stupidity. When I found the actual problem(missing stiffener nut) I played with rear geometry since I spent the $70 on the part anyway & stay at a non stock toe & antisquat setting.I must say the stock plastic parts do not wear & are the best balance for most drivers & I do not think the rear set is worth the money for adjustment. I am however taking my diffs out alot right now & those non nutted hinge pins is well worth the money for those parts & the added adjustment is just a bonus. Its so worth the money for those pins that I am seriously thinking about getting them for the front. Sorry bout the name abrv but its too long.
PS dont lose the diff o-rings that come in the kit,& if you replace them hold on to the used originals for a while in a baggy or something.
butch man is offline
Old 12-30-2008, 08:20 PM
  #3051
tex1 and i have the same driving style. just talking with him at the track suprised me that there isn't one difference in set up or racing style. he has the adj hinge pin holders to get 1/2 degree setups. i race very comfertably in expert class, but i'm a rookie to the 808. so that's why i wondered if the XB8 and 808 are the same for thoes parts.
Old 12-30-2008, 08:27 PM
  #3052
Jaz I actually went with the larger diff bearings because they are "larger" & I had a big stash of them from other cars & had a really bad taste in my mouth from odd size bearing losi days. I dont believe the higher performance of smaller ball/lighter mass over rides the durability difference at the sportsman skill level. BTW I also use dual shielded bearings throughout & that also helps keep the bearings cleaner than a metal shield only bearing. It really comes down to preference though if I didnt have all those 8x16 & didnt have losi diff bearing problems I most probably would be using the stock setup without a second thought.
Old 12-30-2008, 09:11 PM
  #3053
I hate the stocker! It looks like a pregnant Goldfish to me. I am a big fan of the Jconcepts, as it has cut outs for the servo saver, and the header, which makes the lid last longer
if i wanted my car to look like a turd rc8 then i would run a jconcepts body
punkracer24 is offline
Old 12-31-2008, 02:26 PM
  #3054
champ3's Avatar
Anyone know who has the bearing spacers for the diffs in stock?
champ3 is offline
Old 12-31-2008, 02:34 PM
  #3055
Djballen's Avatar
This is where I got mine. Takes like 2 week to get here from the UK .They work great and they are a must have .
http://cgi.ebay.com/XRAY-808-alloy-g...3286.m63.l1177
Djballen is offline
Old 12-31-2008, 03:09 PM
  #3056
omarwashington's Avatar
I got them from here also, the shipping does take a while so be patient. Its a perfect fit.
omarwashington is offline
Old 12-31-2008, 03:28 PM
  #3057
John Sullivan's Avatar
Did you try Rc America i just got those last week?
John Sullivan is offline
Old 12-31-2008, 03:55 PM
  #3058
champ3's Avatar
RC America says that they are out. They did not say when they expect to get another shipment.
champ3 is offline
Old 12-31-2008, 04:13 PM
  #3059
Poppin Fresh's Avatar
What's the deal with the extreme price drop on the 808 at Amain Hobbies? Is Xray releasing a revised 808? Am I missing something here? Should I wait for the Nuremberg Toy Fair to see if they release an 808 '09?
Poppin Fresh is offline
Old 12-31-2008, 05:13 PM
  #3060
Thumbs up ACER Racing X Ray 808 Ceramic Ball Bearings
Hello to all our RC Tech friends!
ACER Racing has a full ceramic ball bearing kit for the X Ray 808. It is complete and includes re-engineered 13x19mm bearings as well as the 5x12mm clutch bearings. This is a bulletproof system. Take an additional 20% off the already reduced price of $89.99 til Jan 2 for rctech members using promo code "rctech20"
Happy New Year!
ACER Racing
acerracing is offline
