New XRAY 808
Old 10-20-2008, 06:34 PM
  #2461
Trader Rating: 208 (100%+)
Rocco, what pipe are you running with the C5Q?
dodgeguy is offline
Old 10-20-2008, 07:09 PM
  #2462
xlgraphicspro's Avatar
Originally Posted by Jaz240
ent
Sorry Tom, XLgraphics asked me why I didnt like the V-spec, and I went off on a tangant, consider the topic closed.
sphhhh blame me why don't ya? Yeah it was my fault!
xlgraphicspro is offline
Old 10-20-2008, 07:22 PM
  #2463
jrwoodchuck's Avatar
Does the 808 come with a steel flywheel or aluminum? If alum, who makes a steel three shoe flywheel that will fit?
jrwoodchuck is offline
Old 10-20-2008, 07:32 PM
  #2464
wild gopher's Avatar
Trader Rating: 39 (100%+)
its aluminum. I dont know of any steel flywheels that would fit except maybe an MIP.
wild gopher is offline
Old 10-20-2008, 07:39 PM
  #2465
http://www.miponline.com/pdf/MIP_2008_Catalog.pdf
Page 1 of catalog would be a start on your clutch quest.
butch man is offline
Old 10-20-2008, 07:42 PM
  #2466
Jaz240's Avatar
Trader Rating: 52 (100%+)
Wayne did you get my email about answer rc?
Jaz240 is offline
Old 10-20-2008, 08:02 PM
  #2467
rmargiotta's Avatar
Trader Rating: 59 (100%+)
Originally Posted by wild gopher
Rocco, how would you compare it to a P5XS? Ive been using that for a while now and its good and all, but our winter series is about to start and guys like Maifield and Fischer are in it so I need more than just a P5
From what I heard, the M5's ran like the P5X's (same block, sleeve, etc...) this motor is more efficient, has more top end and a power band with more 'feeling' to it, if you know what I mean.
I have a Sirio 2013 on mine. I've never felt a nitro motor that felt this close to an electric motor!!! I love the motor/pipe combo.
rmargiotta is offline
Old 10-20-2008, 10:08 PM
  #2468
Jaz240's Avatar
Sorry, i was not blaming you. It was not your fault, you just reminded me of some bad times, and since you are a fellow 808 driver' i felt I owed you an explanation as to why V-spec sucks!
Jaz240 is offline
Old 10-20-2008, 10:46 PM
  #2469
yeah I got your email James, sorry I havent replied. I see Avid has phenolics back in so once I get my order i'll replace the ones you gave me. Im going to be testing my MIP clutch in my Sirio next time out.
Old 10-20-2008, 11:13 PM
  #2470
Jaz240's Avatar
I'm in no hurry, as I have another set. i wont be out to the pit again till 11/1, for the next series start, but I think you said you cant make it. i'll see you when i see you
Jaz240 is offline
Old 10-21-2008, 11:03 AM
  #2471
Default Front lifting on jumps
Just run my 808 for the first time and what an excellent car it is, very light and nimble. One problem I have and I think it is because the car is so light compared to my old MBX5R is that the front is lifting up on the big jumps and gets worse the faster you hit the jump. The weather was not so good so I guess the very high wind was the cause, won't know until I race again in better conditions. Anybody else notice had this problem and if so how have you cured it, maybe adding some lead on the front will help for these extreme conditions?
old but fast is offline
Old 10-21-2008, 11:19 AM
  #2472
Jaz240's Avatar
definately the wind! My 808 jumps like a Gazelle on Coke!
Jaz240 is offline
Old 10-21-2008, 11:54 AM
  #2473
slaytanic's Avatar
Trader Rating: 20 (95%+)
Need some advice guys. I tore down and rebuilt this weekend. New hubs, knuckles, uprights, bulkheads, the works. Just been staring at the spare parts for all season and they looked lonely LOL! Anyway, I noticed my steering was binding. I found that if I loosened up the screws holding the posts to the top plate,it would free it up. But after last weekend it is back. I replaced the bearings but they were not the issue. Can I maybe shim off the top plate? Need some help.
Rocco, This weekend I ran your setup from the Texas race. Rough and loose track that got pretty blown out. It was awesome. A bit stiffer than what I usually run but it handled the rough very nice without scraping the chassis. Aslo had much more pop off the jump. I did run the camber links up 1 from you had though. I want to go back to silver with the same setup and see how it does on a little better surface. Going to JCP in Indianapolis tommorow to do some more testing. Thanks! AKA'sRULE!!!!!
slaytanic is offline
Old 10-21-2008, 01:56 PM
  #2474
s porter's Avatar
Slay, according to the manual...There is supposed to be a small maybe .020 washer between the top plate and steering post to prevent it from binding. HTH...Take a look at your manual.
s porter is offline
Old 10-21-2008, 02:07 PM
  #2475
Steve Walters's Avatar
Yes.... If those two washers are not in place under the top plate, harsh binding will accrue in the steering
Steve Walters is offline
