New XRAY 808
Old 08-15-2008, 07:49 PM
  #1771
Default New to Xray. need help with my 808
looking to see what springs would be best to stock up on for a large outdoor track that sometimes gets blown out.
also where can i find some setups at. Thanks
ericsp2 is offline
Old 08-15-2008, 07:58 PM
  #1772
Trader Rating: 208 (100%+)
The gray-blue springs is a good start and Teamxray.com for setup sheets.
dodgeguy is offline
Old 08-15-2008, 08:57 PM
  #1773
Crim3Wav3's Avatar
interesting "problem" with Avid brake disks after install...When i put them on, 2 race days ago, they seemed to fit the center outdrives quite tightly...I was hesitant to run them like this, but did, thinking they needed a "break-in" period. Well, as I said, after 2 race days they are still tight on the outdrives, causing the breaks to rub and periodically become inconsistent.
anybody else have this problem? If so, how long did it take to break them in so they did'nt bind?
Maybe i should just hit them with some sandpaper to take them down .001"???
Crim3Wav3 is offline
Old 08-15-2008, 10:34 PM
  #1774
So I just drove my buddys new 808 last sunday & Oh my god,I'm in the process of geting one now.Out of the 5 brands I have had this is the one I've been searching for.What I dont understand after driving it is, why have I only seen 4 or 5 here in socal?Am I missing something behind the scenes,other than being a pipe & header or couple sets of wheels maybe even less than the other cars?
Any way wasnt gonna post till I see the talk about the mags a few posts back.We actually see the editors of RC car race with us out here & all 3 I see regularly are faster than me.I'm mid to upper sportsman class at club level & I watch the RCcar guys set-up & change their cars through out the day & impove their times.Those guys actually know whats what & if you talk to them at the track they tell you what they think without hiding it from everybody & come closest to that in their mag.If S.B. or A.W say it in the mag then all you gotta do is wait till they show up at the track & you'll see they practice what they preach & do it while spanking the lap times of me & my friends.
OK no more soap box,one question though is looking at my buddys center drive line is there an agreed upon mod to the center diff cups or dogbones that significantly reduces possable pinion bearing problems?It seems more than a couple people are getting bitten by those & after running losi for a while I am not the most trusting of smaller than 8x16 bearings right now or angled drive shafts.BTW my buddy has had no problems in about a gallon of learning the car but it seems murphys law has been my constant companion lately.
One last thing mag comment,Skinny is a fun guy to have at the track too.
butch man is offline
Old 08-15-2008, 10:49 PM
  #1775
Jaz240's Avatar
Trader Rating: 52 (100%+)
Halfway through my build and I encountered a snag! Seems that one of my front hex axles (hudy steel) was slightly pitted and I didn't notice. Went to slide the bearing over it into the C-hub, and the dam bearing got stuck 1/4 way down the shaft! Now I cannot get it off, or slide it down, should I cut it off, and get another bearing, or try to force it off, and take a chance of ruining the shaft? I will obviously sand down the shaft, after I remove the bearing
Jaz240 is offline
Old 08-16-2008, 04:28 AM
  #1776
Trader Rating: 44 (100%+)
Put the stuck parts in the freezer for a while, take them out, heat up the bearing and pull hard.
sstoffer is offline
Old 08-16-2008, 07:49 AM
  #1777
pablo101's Avatar
Default Wolcott CT 808 setups?
Does anyone here run or have run there 808 at Wolcott CT? There pro series dates is coming up and looking for setups for that track. Any help will be greatly appreciated.
pablo101 is offline
Old 08-16-2008, 08:23 AM
  #1778
Jaz240's Avatar
OK I'm really PO'd now. I got the bearing off! Yea. I have been sanding, and lubing the hex axle for 20 minutes now and it's still too big! Caliper has it at .010 MM bigger than the other one, which is just enough to stop the bearing from sliding over it. Time to call RC America!
Jaz240 is offline
Old 08-16-2008, 02:50 PM
  #1779
Backpain's Avatar
Default Wolcott Hobbies
Pablo , the owner owner of wolcott hobbies Lester Runs one as well as 2others. I'll ask them at the race tommorow what setup sheet they based their cars off of. I'm sure i can get you a baseline, but they might not pass on their exact setups. My 808 wont be here untill the 21st so I cant help on the setup for our track yet.lol Nor am i qualified..
Backpain is offline
Old 08-16-2008, 03:50 PM
  #1780
pablo101's Avatar
Thanks...if I can help w/setup on the pro-series weekend just ask. I'll be there with a buddy who also runs 808
pablo101 is offline
Old 08-16-2008, 05:06 PM
  #1781
Jaz240's Avatar
I found a mistake in the instructions, for anyone who has not started the build yet. Page 23 step 2 of the steering assembly. Instructions show the front drive CVD will be sitting to the left, or in front of the front chassis brace. If you bolt on the front chassis brace with the CVD to the left, you will then have to unassemble the front chassis brace to move the CVD to the right. Be sure the CVD is to the right, or behind the Chassis brace, before you screw down the chassis brace!
Jaz240 is offline
Old 08-16-2008, 05:24 PM
  #1782
No worries about them being tight. They always are and will loosen up eventually. Either way does not effect performance.
Kane-o is offline
Old 08-16-2008, 11:28 PM
  #1783
I got my kit today & will start the build tomarrow but nobody has any recomendation on preping the center diff cups & or dog bones?Just build straight out of the instructions & call it good?
Old 08-16-2008, 11:36 PM
  #1784
Jaz240's Avatar
Build straight from the instructions and call it spectacular! Make note of the insert to the instruction manual. some of the sizes are off the turnbuckles
Jaz240 is offline
Old 08-17-2008, 08:31 AM
  #1785
nsgland's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Bigedmond
The BCE 8x8 chassis is bolt on and go. no extra parts, nothing. Brandon did pretty well with his test chassis at JBRL.
Where can I find this chassis.....
nsgland is offline
