New XRAY 808
Old 08-11-2008, 11:43 PM
  #1726
Jaz240's Avatar
Trader Rating: 52 (100%+)
Got my 808 in the mail today!! Need to know which engines fit the stock engine mounts? Manual does not say. They are not universal
Jaz240 is offline
Old 08-12-2008, 12:25 AM
  #1727
Greg M's Avatar
What makes the BCE chassis so great? Whats different?
Greg M is offline
Old 08-12-2008, 12:55 AM
  #1728
RETRO RC's Avatar
the stock engine mounts are universal as they are two peices and can be moved individualy to accommadate different engines.
Adrian
RETRO RC is offline
Old 08-12-2008, 12:58 AM
  #1729
Greg M's Avatar
Adrian
Hows your 808 going Adrian?
Greg M is offline
Old 08-12-2008, 01:13 AM
  #1730
RETRO RC's Avatar
should have the build finished tonight just got the shocks build and throttle linkage to setup
RETRO RC is offline
Old 08-12-2008, 07:10 AM
  #1731
chad24's Avatar
Default 808
hey when you are done building , post some pictures of the beast.
chad24 is offline
Old 08-12-2008, 07:51 AM
  #1732
xlgraphicspro's Avatar
So Umm, Yeah I just saw how much the new Kyosho mp9 is gonna cost. $850 bucks!!!
That makes the new increase on Xrays prices seem like a great deal!
xlgraphicspro is offline
Old 08-12-2008, 08:58 AM
  #1733
Originally Posted by lowey79
This is just my opinion, but i'd say that the bearing failed first which is where the heat was generated from to melt the cup.....
NAHH, THE BEARING STILL ROLLS GOOD, THE MELTED COMPOSITE SHEILD PEELED THE SEALS OFF THE BEARING, AND IT SPLATTERED ITSELF ALL OVER THE DIFF CUP, THE ONLY REASON I'M REPLACING THE CUP IS B/C I CAN'T SCRAPE THE SH** OFF, AND THE BEARING B/C I DON'T HAVE A RUBBER SEAL THAT SIZE...JUST THE RETAINER BLEW UP
TRAV15#?%! is offline
Old 08-12-2008, 09:12 AM
  #1734
nsgland's Avatar
Trader Rating: 19 (100%+)
Default caps
Originally Posted by chad24
will the losi shock caps on the bottom of the shocks that holds the boots in place fit on an xray 808?
thanks
These will......
http://rc-mushroom.com/product_info....ducts_id=15296
nsgland is offline
Old 08-12-2008, 09:37 AM
  #1735
Jaz240's Avatar
the stock engine mounts are universal as they are two pieces and can be moved individually to accommodate different engines.
Adrian
HOW can I move the mounts if the engine does not line up with the screw holes?
Lets start from the beginning. The engine needs to be bolted to the engine mounts, then the mounts gets bolted to the chassis. Are you saying that the screw holes for every engine (.21) are spaced exactly the same, and will line up perfectly with these mounts? Why do the other engine mounts come in specific engine designs?
Jaz240 is offline
Old 08-12-2008, 09:51 AM
  #1736
Steve Walters's Avatar
Improvement vs the stock chassis
The BCE 8x8 chassis is 7075 "BILLET" vs the stock being 7075 "Alclad". Thus the strength factor is much greater with the BCE. So overall chassis wear is going to be way less, and there is less chance of bending from hard crashes, or landing wrong on extreme jumps that are on most US tracks now. BCE also slightly changed the geometry of the front & rear center drive line, so there is slightly more clearance to help prevent possible bearing failure due to shock from casing jumps (Pushing the drive line/pinion threw the inner bearing in the diff case), which has happened a few times from racers. The 8x8 chassis is 3mm also, but will most likely be lighter when the final production is finished. Mine is one of the prototype just for just testing. The cost is going to be very similar to a replacement stock Chassis so it's affordable too. Its a win win situation IMO...
Biggest thing I noticed when testing & racing was the increase performance it gave the buggy going threw the rut's. It improved the overall handing characteristics on a blown out track. I turned my fastest lap times with it, and helped me increase my point lead in the Nitro Nights series I'm racing in. All on a track that is progressively getting more and more rutted.
Steve Walters is offline
Old 08-12-2008, 01:05 PM
  #1737
UNSTABLE's Avatar
Yep, they all have a standard spacing.
UNSTABLE is offline
Old 08-12-2008, 01:16 PM
  #1738
slaytanic's Avatar
Trader Rating: 20 (95%+)
Most .21's have the same hole spacing. What changes is WHERE on the block they locate them. Thats why the need for 2 differnt types of upper blocks. This helps get the mesh on the bell/spur line up.
slaytanic is offline
Old 08-12-2008, 02:04 PM
  #1739
Jaz240's Avatar
Awesome, 7 Years in Off road Nitro RC, and i just learned something new!! Thanks, JAZ
Jaz240 is offline
Old 08-12-2008, 05:11 PM
  #1740
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Some .21's have a wider case, between the mounts, but the same bolt spacing dimensions.
Jaz, tell your avatars boobas to stop staring at my eyes!
lol
...Jim
W.E.D.
W.E.D.Jim is offline
