New XRAY 808
#1651
I'm the one who posted the 10 W 30 oil in your bearings. I find a light oiling attracts less dirt and dibris, which is what really wears out bearings. Thick grease can create dirt globs, which can stop a bearing in it's tracks.
Also, if you use simple green to degrease your car, make sure none of it gets in your bearings, that creates a bad situation inside your bearings.
COOL, I'LL TRY IT....DO YOU FIND THAT YOU NEED TO DISASSEMBLE MORE OFTEN?, AND ALSO , DO YOU OIL ALL YOUR WHEEL/DRIVETRAIN BEARINGS WITH MOTOR OIL?
#1652
I'm running the Ninja (Grp based) motor with a 053 Ofna pipe. I don't run on any really big tracks. I can tell you that this combo on a Med sized track is awesome. I have the 2053 FLS Ninja pipe that I run from time to time. I know that I can use it on bigger tracks just from it's power band. For the money though the little Ofna 053 is the best bang for the buck. It really just depends on the tracks your running on. Hope this helps you out
#1654
I would still treat Avids the same. I run Avids and they are great. But honestly the 808 stock bearings are better. Cost more too though.
#1659
Hey Jaz240. Try my painter. It's XXXL Graphics. He starts at about 40.00. You provide the body. P.M. me if you want his number. I can also post some pics of mine if you want.
#1660
#1661
There is a great little shop in Edmonton Alberta Canada, selling 808 kits for $577 Canadian. Shipping cost isn't to bad between Canada and the US.
You can find them at thehobbyroom.ca
Great service and great selection of parts!!!
The only problem I see with Xray products at the current time is R/C America.
#1662
#1663
hey guys i have a stupid question for you. for the 2 peice engine , there are 2 engine blocks that mount on the motor. now i am looking at a go tech engine now what block would that fall und
358718 XB808 Alu Stands For Engine Mount - Novarossi, Sirio, R&B, Max, JP - Hard Coated
358719 XB808 Alu Stands For Engine Mount - Picco, Mega, Orion, LRP, OS - Hard Coateder the
thanks chad
thanks chad
#1665
now another queston are the al. hopups like the al. rear hubs, and the al. frount caster blocks and the al. frount hubs worth the money.
