New XRAY 808
Old 07-29-2008, 07:01 PM
  #1576
slaytanic's Avatar
Trader Rating: 20 (95%+)
You really dont need anything. I would get bearings for spares and as far as options maybe sway bars and springs for tuning. The car is damn near indestructable! I have grabbed a few spares here and there but have yet to use any.
slaytanic is offline
Old 07-29-2008, 07:23 PM
  #1577
Trader Rating: 19 (100%+)
Ok thanks how about clutch bells and shoes?? just tryin to get ready.
teammidget lilB is offline
Old 07-29-2008, 08:07 PM
  #1578
Steve Walters's Avatar
I like the 15T Bell on most tracks I've raced on so far. Gives a ton of bottom end punch, if you have the traction for it. Well worth trying IMO. I like the stock shoes & springs setup and I have been getting 1.5 gallons of life out of them. I do like the Max-Life shoes with the stock springs a little better. A little better grip, and a little longer life and zero bell/shoe maintenance. Closer to 2 Gallons too.
Steve Walters is offline
Old 07-30-2008, 03:46 AM
  #1579
nitrodog's Avatar
Trader Rating: 15 (100%+)
Hey guys,
do you know what rate the stock clutch springs are? mediums?
and what other clutch shoes will work with the xray? I would like to try a softer shoe if possible to get more rip off the corner
nitrodog is offline
Old 07-30-2008, 04:26 AM
  #1580
slaytanic's Avatar
1.0 I beleive. For stocker shoes and springs they are good.
Old 07-30-2008, 04:36 AM
  #1581
Dan Reino's Avatar
Originally Posted by nitrodog
Hey guys,
Xray 1.71 gm silver shoes w/ 1 mm springs work well. I have been using King Headz Mugen black aluminum w/ 1mm springs for med bite. Also try the Carbon Mugen shoes w/.9 mm springs for low bite or loose tracks.
Dan Reino is offline
Old 07-30-2008, 04:47 AM
  #1582
nitrodog's Avatar
So shoes made for Mugen will work with the Xray?
What will carbon shoes do? Will they "hit" harder?
wear faster?
and would you run all three carbon, or a combo of Aluminum and Carbon?
nitrodog is offline
Old 07-30-2008, 05:18 AM
  #1583
Dan Reino's Avatar
wear faster?
Yes Mugen shoes fit and work fine
Carbons will slip a little but be sure to get some .9 mm springs for them and yes they wear faster. When trying a new set of Carbons always use a NEW clutch bell. If you use an old one that is roughed up from aluminum shoes, you will wear out the shoes too fast.
I like one or the other. Like I was saying, A rough or gared up clutch bell makes carbons wear out faster. Stick w/ 3 aluminum w/1.00 or 3 carbons w/ .9's
http://www.amainhobbies.com/product_...oducts_id/8651
http://www.amainhobbies.com/product_...oducts_id/9887
http://www.amainhobbies.com/product_...ducts_id/10016
http://www.amainhobbies.com/product_...oducts_id/2188
Old 07-30-2008, 08:03 AM
  #1584
CoryD's Avatar
Anyone use the M2C Racing clutch in the 808? What are your thoughts?
Thanks,
CoryD is offline
  #1585
Davidka's Avatar
Trader Rating: 86 (100%+)
Carbon shoes usually wear a great deal longer than aluminum shoes. I have carbon shoes on one of my engines that I have using on various engines since I began running 1/8 4 years ago. The clutch pin holes are ovalizing but the shoes still have plenty of material on the. I have always run carbons and have never acutally worn a set out (thought this first set is about ready to retire ).
I have found that a bell that has been used with alloys can be cleaned out by using a 6mm bolt as a chuck to turn the bell on a drill and some good sand paper (or even a dremel tool with a stone bit) to take off the aluminum deposits. You must get it all cleaned off though, otherwise you will eat those carbon shoes quickly as Dan said.
Davidka is offline
Old 07-30-2008, 08:46 AM
  #1586
Crim3Wav3's Avatar
i have 2.5 gallons on my stock shoes.....and, i SWEAR, they still are damn near perfect!
Crim3Wav3 is offline
Old 07-30-2008, 09:56 AM
  #1587
XRC
Trader Rating: 33 (100%+)
Thanks,
I haven't run the M2C. However, I did run the Fioroni Turbo Twin Slide this past weekend for the first time and was relatively impressed. Very consistant over the 30min main.
XRC is offline
Old 07-30-2008, 12:06 PM
  #1588
Trader Rating: 80 (100%+)
A few questions. Finally got a chance to break in my engine and wanted to clean my car due to all the soot and oil that got all over it. What is the recommended cleaning solution to use?
Also, I am running the OS 2050 pipe and the pipe holder bar that comes with the kit doesnt fit through the hole. Is it safe to drill out the pipe hole a little?
Cant wait to get this thing to the track. Hopefully the weather cooperates this weekend!
cpatel529 is offline
Old 07-30-2008, 12:15 PM
  #1589
ngo8's Avatar
i used the holder that came with the jammin pipes perfect fit .
ngo8 is offline
Old 07-30-2008, 12:46 PM
  #1590
rmargiotta's Avatar
Trader Rating: 59 (100%+)
Originally Posted by CAR
Rocco,do you know when the 12 and 14 castor blocks will be out? Thanks
We were shipped the aluminum c-hubs in the varying degrees. These should be in tomorrow or the next day.
rmargiotta is offline
