New XRAY 808
Old 07-21-2008, 06:37 PM
  #1516
kolorking25's Avatar
Default set up
my 808 will be here soon i see alot of guys running rocco's setup where can i find this i want to start out running this setup
kolorking25 is offline
Old 07-21-2008, 06:51 PM
  #1517
slaytanic's Avatar
Trader Rating: 20 (95%+)
Here you go. One tip, a set of digital calipers will help you make sure your car is dialed the first time you hit the track. Check the inserts for proper turnbuckle assembly lengths.
http://forum.teamxray.com/xsheets-se...hByUserId=3497
slaytanic is offline
Old 07-21-2008, 09:01 PM
  #1518
nta01's Avatar
Trader Rating: 19 (100%+)
Where can you get Josh Wheelers set up sheet?
Thanks,
Tom
nta01 is offline
Old 07-22-2008, 04:18 AM
  #1519
slaytanic's Avatar
http://forum.teamxray.com/xsheets-se...p?mode=results
All the posted setup sheets. You can sort however you like.
Old 07-22-2008, 10:03 AM
  #1520
rmargiotta's Avatar
Trader Rating: 59 (100%+)
Just a heads up, Josh Wheelers setup is pretty aggressive, I found it hard to drive myself, which is weird because pretty much the only differences between our setups are slightly different shock setups.
rmargiotta is offline
Old 07-22-2008, 11:33 AM
  #1521
Trader Rating: 26 (100%+)
Maybe you could drop him a line and see if he'd post an updated setup sheet?
What clutch system is he using?
ldp787 is offline
Old 07-22-2008, 11:37 AM
  #1522
rmargiotta's Avatar
I'll give him a shout. I do know he runs the M2C 4 shoe clutch...
Old 07-22-2008, 11:46 AM
  #1523
.Double post
ldp787 is offline
Old 07-23-2008, 08:09 AM
  #1524
Im kind of confused about how the front and rear diff should be shimmed. Does there have to be shims?
I put mine togheter and i thought the gear mesh was good, no slop and it didnt feel like it was binding or heavy to move.
Do i need to shim them a little bit so i get more clearance between the pinion and diffgear?
Hans_Andersson is offline
Old 07-23-2008, 08:20 AM
  #1525
slaytanic's Avatar
If they feel right then dont sweat it. In my build I only used 1 shim on the rear diff. 808 diffs like a little bit of play. Dont shim them too tight or it will cause issues like too much heat and premature bearing wear. I used 1 shim on the ring side of the diff to push it a bit closer to the pinion. I think each one will be a bit different.
Old 07-23-2008, 09:03 AM
  #1526
rmargiotta's Avatar
You want to shim you diff (or not if its the case) to where you have a little more slop than you're comfortable with. The spring steel is very hard and the only time I've seen it break is when the mesh is too tight.
Old 07-23-2008, 06:16 PM
  #1527
nitrodog's Avatar
Trader Rating: 15 (100%+)
Stupid question here, but how are you guys putting together and taking apart your shocks, on my Losi the bottom of the shock was hexed and they supplied a tool, the xray shocks are smooth and I was wondering how to grab them and not scratch the threads. what tools?
thanks
nitrodog is offline
Old 07-23-2008, 08:31 PM
  #1528
MetalShield's Avatar
just hand tighten them works fine...
MetalShield is offline
Old 07-23-2008, 11:14 PM
  #1529
I think he's talking about the ball connector on the bottom of the shock shaft.
Just use a pair of side cutters on the threaded part of the shock shaft.
Page 30 of the 808 manual.
Lycan is offline
Old 07-24-2008, 03:28 AM
  #1530
WheelNut's Avatar
Originally Posted by malcnz
you guys know of any 12tooth clutch bells that use the bigger 5x 10 bearings?..for the 808...
Thanks.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRJS6&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXLMW1&P=7
I'd go with the Ofna, because I have used it and I know it is durable.
To put the ends on the shock shafts I like to put a towel around the shaft and clamp the shaft in a vice. Thats about the only way I've been able to get a good enough grip on the shaft to thread the thing all the way on. Huge pliers and a towel work too.
WheelNut is offline
