Engine base-settings Losi 427 >
Old 01-25-2008, 06:36 PM
JeffEmbracedDC's Avatar
Trader Rating: 20 (100%+)
Default Engine base-settings Losi 427
Hey, guys. I've got a Losi RTR and I need to know the base settings for the engine (Losi 427).
I know the low and high-speed needles are 2.5 turns out from bottom - though there's nothing published for the IDLE screw. Is there a certain setting I should start with for the idle screw?
Thanks!
JeffEmbracedDC is offline
Old 01-25-2008, 08:54 PM
Registered User
You want just a very small gap when the slide is closed... I would say about .5 mm?? Someone correct me if I am wrong.
lanerbrainer205 is offline
