Advice on an OS MAX .21 RG >
Old 12-04-2007, 07:21 PM
Chuck67's Avatar
Trader Rating: 36 (100%+)
Default Advice on an OS MAX .21 RG
I have an older OS MAX .21 RG I dropped it into our Losi 8 Buggy. Question is which pipe would be better suited for it a JP-1 or a JP-2?
Thanks,
Chuck
Chuck67 is offline
Old 12-05-2007, 06:40 AM
I used to run an 053 and have also run a jp-1 back in the day and it sreemed with either one but that was on a small tight technical track. The rg's seem to have a ton of bottom end grunt. You would probably be fine with either of the ones you listed depending on the track conditions.
shockripple is offline
Old 12-05-2007, 06:52 AM
Trader Rating: 21 (100%+)
i like the jp-2. better top end on an engine that lacks top end from the factory. And i run on a track with a mile long back straight, top end matters where i run...
shawnyd is offline
Old 12-05-2007, 08:44 AM
Trader Rating: 15 (100%+)
Chuck67:
If your running on a track with about only 100-110' straight run a 13 tooth CB. If your running on a track with a longer straight then use a 14 tooth CB.
Also run either aluminum or carbon shoes with 1.0springs.
The only pipe to use is a Nova 086 with a regular header!
With these combos you can run with anything out there.
7.5man is offline
