Like Tree3Likes
Mugen MBX6
Old 11-29-2011, 02:53 AM
  #14221
yannis's Avatar
Default Rebond stop
Hello, i want to know how you tune your rebond stop
Did you have THE same for THE rear and THE front,
And what are your shock dimension
Thank you and sorry for my english
yannis is offline
Old 11-29-2011, 05:22 AM
  #14222
Sprinkler's Avatar
Trader Rating: 28 (100%+)
It all depends on the track and your driving style.
Limited droop in the front is 105-106. A lot of droop in the front is 109-110
Limited droop in the rear is 125-126. A lot of droop in the rear is 129-130.
Some people like a lot of droop in the cars. Keep in mind that a lot of droop can cause traction rolling problems in certain conditions.
Typically on the blown out or rough track you will want more droop. On a blue grooved track or smooth track with lots of traction you will want less droop.
Make sure your shock lengths are the same before you put them on the car. Then to measure the droop measure from the center of the shock tower screw to the center of the a-arm screw.
On the front....the length from the bottom of the shock body to the top of the shock shaft end should be 35mm. The rear should be 46mm.
If you run a lot of droop make sure you have it limited enough to keep the shock from being over extended. That will result in your shock shaft ends getting damaged.
I hope that helps.
Sprinkler is offline
Old 11-29-2011, 04:22 PM
  #14223
plus2ss's Avatar
Hey guys, I need a good starting setup for the plus 5mm chassis and new springs. The tracks are indoor, cold temps, and hard packed clay. Any links? Thanks guys
plus2ss is offline
Old 11-29-2011, 04:31 PM
  #14224
NitroXray80809's Avatar
Trader Rating: 24 (100%+)
pm me ur email if track needs steering then this will be a good start and batt forward. May just want to mess with diff a bit but this im sure will be dialed.
NitroXray80809 is offline
Old 11-29-2011, 06:05 PM
  #14225
Z-Man.'s Avatar
Originally Posted by EJF
Anyone know the part number for the flywheel pins on the MBX6? I remember them being able to be replaced on the MBX5.
Here ya go
http://www.amainhobbies.com/product_...en-Flywheel-X5
I also like the Xray ones, and they are $10 less...
http://www.amainhobbies.com/product_.../XRAY-Flywheel
Z-Man. is offline
Old 11-30-2011, 05:05 AM
  #14226
yannis's Avatar
I hope that helps.
thanks a lot i didn't think to have a completely ansewr like that but 46 mm for the rear shock it's the stock length and when you did it the piston goes out the shock, It's why i asked the length that you use
yannis is offline
Old 11-30-2011, 07:24 AM
  #14227
Integra's Avatar
Originally Posted by Z-Man.
Pins not Flywheel's.
EJF If i remember correctly I repinned a couple Ofna and Mugen Flywheels with some OFNA pins back in the day. I Cant honestly remember the length or size but im sure if you measure up your flywheel and look you could find something that would work.
Integra is offline
Old 11-30-2011, 08:20 AM
  #14228
It's the same length as the pins from the center CVD (2.5*15.8mm)
Bose is offline
Old 11-30-2011, 10:19 AM
  #14229
How is the easiest way to get to my throttle servo on my mbx6? I have to replace it but am not sure how to get it out and put a new one back in without taking a bunch of the buggy apart. Thanks for the help
EatYoLegs is offline
Old 11-30-2011, 10:59 AM
  #14230
Trader Rating: 19 (100%+)
Just remove the radio tray from the bottom side. Should only be 6 or 8 screws. Then you will have better access to the servo.
Pin2Win is offline
Old 11-30-2011, 11:37 AM
  #14231
lee_double2000's Avatar
Trader Rating: 46 (100%+)
Default just to let you mugen drivers know. lol
Hello, here i have a set of front and rear Mugen MBX6 shock kits both brand new in the package as you see on picture they will come with shock post mounts. They are both filled with 400 wt mugen shock oil as they do with the kit. Let me know. Thanks
SOLD
lee_double2000 is offline
Old 11-30-2011, 12:30 PM
  #14232
Sprinkler's Avatar
Originally Posted by lee_double2000
Hello, here i have a set of front and rear Mugen MBX6 shock kits both brand new in the package as you see on picture they will come with shock post mounts. They are both filled with 400 wt mugen shock oil as they do with the kit. I will let go for $120obo shipped. Let me know. Thanks
LOL...dude, your price is almost double what people can get them on Ebay for.
Old 11-30-2011, 12:46 PM
  #14233
JoeyTheRocket's Avatar
His name is lee double....
J/K all in good fun.
JoeyTheRocket is offline
Old 11-30-2011, 01:11 PM
  #14234
That what OBO stands for. Or Best Offer. So anyone can throw out there offer. It doesnt take a rocket scientist to know that. Lol
Joey the Rocket
oh yeah all in fun. LOLOLOL
Old 12-01-2011, 01:29 AM
  #14235
aussies1129's Avatar
Trader Rating: 74 (100%+)
aussies1129 is offline
