Mugen MBX6
Nope, the losi vented cap theory is another whole game, some say its great. I tried it this past summer and didn't notice any change but the foam supports the bladder and keeps the shock consistant.
Remember there is alot of different opinions out there and this is just mine and what i have found to work for me and others that i race with locally.
Hope this helps,
Scott
Hope this helps,
Scott
as for the foam I use a 9mm socket and yellow Ofna foam (buggy) and punch out the plug. Then cut the foam to the height needed, just so it touches the bladder not pushing on it. This may take a couple trys but 1 foam will give you enough material for life. Oh yea, punch the foam in the center of the foam not on the edges cause the foam tapperes off on the sides. Scott
cheers Jason
Cheers Jason
Scott
I raced my mbx6 this weekend. The was standing on my shelf since the previous season ended. The just stays awesome! It's jump far and great, you can push it so hard and it eats bumps and ruts
(finished 2nd btw)
Can't wait to try the new springs!
Hey guys just wanted to know can use the losi blader foams and if so do I have to do anything special
John
John
I felt that venting the cap (2mm hole) helped, really. Think about it - our issue without the foam is that the bladder collapses and stay collapsed, the air that was trapped behind must have gone swhere, right? Either in the oil, or outside the cap, and it stayed there.... both are bad. Might as well vent it to prevent any pneumatic side effects so the air goes outside on compression and back in on extension.
What's funny is that we're still talking the same tricks that were described almost 2 years ago soon after the car came out
Can't wait to race nitro - I am going through a pre-season cleanup as we speak and the mbx6 remains a great design, the material quality is just superb. I just replaced the bones pins with the hudy tool ($$$), waiting for my new KO's to come it (erg-vb's have had it, 2 full seasons now) and the car is ready to rock and roll for one more season, woohoo!!!
Wondering about the new chasssis though, I never found anything I didn't like with the older one, but still... could be tempted.
Paul
check page #552 - or the Losi 2.0 EU manual.
Paul
Paul
Can someone post the link to the brake disc they are using for the mod. About to place an order on Amain and want to get it right the first time. Thanks!!
Shinnbad, Ran the 10,10,7 It really worked nicely car was noticeably different. I think I will either square off at 10,10,10 or go up to 15,15,10 took 2nd this weekend. I'm still making some dumb mistakes but its all good. The car is feeling better and better each week. Not sure I'm going to run the new chassis yet I don't think there is anything wrong with old one. I am going to try the new springs though.
Thanks Again
Thanks Again
All
scanning the last few pages to figure out what's new after not visiting this thread for a while (winter = EP
So new lengthened chassis, new springs - why did they went to a smaller wire? I mean, how different can a N/cm rate can be from another N/cm? I don't get it... I mean, other than making sure everyone shelfs out more cash
Any educated insight?
thanks
Paul
thanks
Paul
if you have 2 springs with same wire diameter then the spring with less windings is harder. (look at the old springs).
If the distance between the windings of the new springs is even getting bigger and you want to keep the spring rate the same you need to reduce the wire diameter.
The old springs have a more liniear feel.
The new ones will feel more progressive.
Thanks Again
Thanks Again
ps. im indoors in IL. so dont know if the spring will be the same ones for outdoors.
Scott
Thanks lonestar
