Like Tree3Likes
Mugen MBX6
Old 10-13-2008, 09:32 PM
  #946
teeforb's Avatar
Trader Rating: 94 (100%+)
You haven't seen an electric 1/8th scale... They are pheonminal!!! You can always youtube it...
Check this one out. This is my local track. It's a losi conversion by tekno RC.
Look at 2:23 seconds into it... u will see the lighting speed down the back straight.
http://http://www.youtube.com/watch?v=cYsq4M_o8PI
teeforb is offline
Old 10-14-2008, 07:26 AM
  #947
Jammin57's Avatar
Trader Rating: 120 (100%+)
Originally Posted by teeforb
Yep!!! I have the following on it's way:
RC-Monster conversion kit with battery tray
0610i dual charger
HT-200 950 receiver pack
I will be buying soon (within the week if available):
I am thinking of getting the 1512 1.5Y smooth
Neu 5S 5000mah lipo
MMM V3 when ever that comes out. So far, it seems that the MMM will be my main holdup before i get to the track...
IMO I would not get a MMM v1,v2,or a v3 when it comes out alot of people are having good luck with the MMM but ALOT are having problems with them
buy a mgm esc it is a little bit more but its worth it, the mgm is harder to setup and adjust but after you get used to it its not a problem.
on the neu i would get the finned version, the fins will help draw the heat out and keep it cooler and you dont need a rx pack you can run it off the lipo thru the esc
Jammin57 is offline
Old 10-14-2008, 07:42 AM
  #948
teeforb's Avatar
U have link to MGM?
teeforb is offline
Old 10-14-2008, 08:51 AM
  #949
allan42r's Avatar
Originally Posted by Factory Seal
One of my Bro's just got the truggy.......the only setup weve found was the same as the kit.......Mugen WebSite....
Does someone have the Pimp Setup???
Ahead of time i Thank You!......
He raced it this past weekend.......Said it was a little unstable through the Whoop's and ruff stuff.....
the track had a huge set of Whoop's...
Real Twitchy.......
Any help would be App........
this thread is the mbx6. try the mbx5t thread and if you still need more help you can pm me
allan42r is offline
Old 10-14-2008, 10:11 AM
  #950
Jammin57's Avatar
U have link to MGM?
anything you want to buy for a conversion is on this webiste and the forum has alot of info on it
http://rc-monster.com/
Jammin57 is offline
Old 10-14-2008, 03:06 PM
  #951
ALG
Default diffs
Are the MBX5r diff the same as the MBX6? and the truggy are also the same?
thanks for your help
ALG
ALG is offline
Old 10-14-2008, 03:51 PM
  #952
Mugen9112's Avatar
ALG
They are different. Same bearings, internal gears, and diff case(part that screws onto the gear). Dont quote on me on the internal gears being the same though
Mugen9112 is offline
Old 10-14-2008, 03:53 PM
  #953
teeforb's Avatar
Quick questions on the 6's diff. Are you guys using the standard diff screws or are you guys buying longer diff screws? Please confirm? Also, what are you guys doing special to ensure the diffs won't leak. I may start building now.
Thx!!!
teeforb is offline
Old 10-14-2008, 03:56 PM
  #954
Mugen9112's Avatar
Thx!!!
Im using the stock screws and so is Scott Hughes. I heard aftermarket seals aren't fitting the diffs and most including myself, and again Mr. Hughes like the stock ones. Although most people are saying they like 5-5-2 in terms of diff fluid
Old 10-14-2008, 04:00 PM
  #955
teeforb's Avatar
so, pretty much everything stock!!!
teeforb is offline
Old 10-14-2008, 04:03 PM
  #956
Mugen9112's Avatar
Yea essentially. Copy this setup as your base.
Old 10-14-2008, 04:29 PM
  #957
teeforb's Avatar
Thxs!!! So, no o rings?
teeforb is offline
Old 10-14-2008, 05:10 PM
  #958
RBMike's Avatar
I ran mine with 5-7-2 this weekend & thought the center was too thick. I plan to switch the center to 5 before the weekend. My diffs are built stock & do not leak. I did use some "green slime" on the outdrive o-rings (as always).
RBMike is offline
Old 10-14-2008, 05:16 PM
  #959
teeforb's Avatar
are you guys using internal diff rings? Also, is it mandatory to use green slim? I don't have any...
teeforb is offline
Old 10-14-2008, 05:17 PM
  #960
ALG
The big gears inside the diff are slightly different as are the pins that go through the outdrives. Those pins are bigger now.
windellmc is offline
