Like Tree3Likes
Mugen MBX6
Old 11-03-2010, 11:32 PM
  #9496
imaxx21's Avatar
imaxx21 is offline
Old 11-04-2010, 03:34 AM
  #9497
morgoth's Avatar
11.98 indeed.
Diff ratio is 44/13 (3.38)
Clutch/spur is 46/13 (3.54)
morgoth is offline
Old 11-04-2010, 04:48 AM
  #9498
lk
Originally Posted by lk
What is the weight difference between the aluminum and plastic rear hubs?
Anyone??
lk is offline
Old 11-04-2010, 11:42 AM
  #9499
Default bent chassis
Originally Posted by Mugen racer123
the car's hinge pins and rotating parts. Today i bought a new servo saver and relized that the chassi is bent
all u need is the kings head extended engine mount.
muaythai is offline
Old 11-04-2010, 12:09 PM
  #9500
jpz_67's Avatar
Trader Rating: 57 (100%+)
Anyone??
Sorry friend, I dont know the weight but I am sure it would be very minor. Where the real advantage is in the rear aluminum uprights is they help dial in more rear traction in the buggy by less flex. I have some at home and will weigh both tonight.
jpz_67 is offline
Old 11-04-2010, 12:31 PM
  #9501
morgoth's Avatar
I bought my mbx6 second, but it was brand new in the box and in the bags. The guy bought the kit but hadn't the time to build/race it. I got a few alu hopups with it: Alu front upperbrace (I use it), alu shocktowers (I use them as spare, the CF looks better ), alu front brace (I use the stock plastic one), alu rear hubs. Now I don't know what to do with the rear hubs. I heard you break the hingepins/A-arms easier with them. Is this true? And what's the benefit of the alu rear hubs? Do they really give more rear traction?
morgoth is offline
Old 11-04-2010, 02:41 PM
  #9502
lk
Carbon fiber is almost always lighter than aluminum. I have found the exception to this with the OT Fioroni front upper plate and front brace combo. As well as shortening some of the screws, you also lose the need fir a couple of nuts, in the end I shaved off around ten grams.
lk is offline
Old 11-04-2010, 03:30 PM
  #9503
Trader Rating: 14 (100%+)
Becaus i want to
try leaving it alone for a couple weeks. i find that most cars dont like to be touched that often. make sure your shit has loctite on where needed and your bearings are ok and leave it.
o.s. power is offline
Old 11-04-2010, 03:37 PM
  #9504
Mugen racer123's Avatar
I will try it but the only reason i do it is because i like it clean
Mugen racer123 is offline
Old 11-04-2010, 05:43 PM
  #9505
James khoo's Avatar
Trader Rating: 15 (100%+)
Yeah,clean car mean car ready to race.I like it clean too,and tear it down every 2 weeks of play.
James khoo is offline
Old 11-04-2010, 07:37 PM
  #9506
jpz_67's Avatar
Morgoth, I bought the car upon it's first day of release and over time figured out what could use more durability. I am not saying these parts are necessary but for me the front tower in aluminum and the front upper hinge pin holder are very well worth investing. I managed to break several of both items until I finally switched to aluminum. As for the rear uprights yes they will help the car hook up better, less flex. This has been figured out by many if mugens top drivers already but once again it is not totally necessary. If you choose to use them be sure and use the small setscrews to secure the hinge pin to the upright. I will weigh them in a minute.
jpz_67 is offline
Old 11-04-2010, 07:54 PM
  #9507
jpz_67's Avatar
According to my scale a plastic upright is 14 grams and the aluminum is 19 grams. Not much difference. This is empty with no bearings.
jpz_67 is offline
Old 11-04-2010, 09:33 PM
  #9508
+1
Old 11-05-2010, 04:32 AM
  #9509
morgoth's Avatar
I have a few front carbon shocktowers that I got cheap from ebay. I ran the alu hubs for the first time during my last race this season. But that race was on dirt and I'm used to run on astroturf so I couldn't notice the difference. It was actually my race on dirt.
The track was very loamy and blown out. There were lots of bumps and ruts and I think my diffs where too thick. I was running 10-7-5 in the diffs. (I'm used to 20-15-10 or 15-15-7 on astro). I guys I'll try 7-7-3 next time on dirt.
morgoth is offline
Old 11-05-2010, 04:49 AM
  #9510
Lonestar's Avatar
there we go.
don't oil/grease anything that's not enclosed. All it does is attract dust and make whatever you've coated bind/scrub. No "wet" lubing of any suspension parts, ever (unless dry lubing). Pull the car apart, and mount it "dry" except the conical diff gears.
Shocks and diffs need to be torn apart down to the o-ring level and rebuilt regularly however. Silicon fluids wear with time, not even talking about how "corrupted" they get with outer stuff (dust, nitro, ...), and then there's leaks...
A slightly bent chassis makes very little difference to the handling, really..
It's all in the maintenance
Paul
Lonestar is offline
