Like Tree3Likes
Mugen MBX6
Old 09-16-2010, 11:16 AM
  #9001
imaxx21's Avatar
no
imaxx21 is offline
Old 09-16-2010, 08:43 PM
  #9002
Trader Rating: 68 (100%+)
Originally Posted by imaxx21
no
so what is the reason for that? thanks
Speedychris22 is offline
Old 09-16-2010, 09:03 PM
  #9003
Mauve's Avatar
The O'Rings behind the planetary gears put more load on the diff causing it to behave like it has much much thicker oil in it. I would only use them in extreme circumstances as you will end up with a huge amount of drive, like crazy amounts. Very very few people use that style of setup as it can become incredibly difficult to drive but it will be fast if you can drive that style of setup. If you have the skills of Lutz or Savoya, go for it, for the rest of us meer mortals, not a hugely useful setup.
Mauve is offline
Old 09-17-2010, 07:22 AM
  #9004
slow coach's Avatar
its just more consistent to put heavier diff oil in rather than try to use the o rings to get the same effect
slow coach is offline
Old 09-18-2010, 11:24 AM
  #9005
Trader Rating: 25 (100%+)
does someone know the part# for the replacement pins for the drive shafts?
thanks,
arm2storm is offline
Old 09-18-2010, 11:30 AM
  #9006
jpalessi's Avatar
Trader Rating: 55 (100%+)
thanks,
which ones? dog bone pins? or cvd joint pin? center and axles are different for both.
jpalessi is offline
Old 09-18-2010, 11:32 AM
  #9007
R/C Tech Elite Member
thanks,
http://racemugen.com/catalog/index.p...sort=2a&page=2
bpalmer is offline
Old 09-18-2010, 01:23 PM
  #9008
The dog bone, the ones that turn the outdrives. The ones you need a press to remove, the ones that are preinstalled.
Old 09-18-2010, 01:44 PM
  #9009
jpalessi's Avatar
Centers
http://www.amainhobbies.com/product_...28mm-Joint-Pin
Axles
http://www.amainhobbies.com/product_...38mm-Joint-Pin
jpalessi is offline
Old 09-18-2010, 02:23 PM
  #9010
Are they different?
Old 09-18-2010, 02:26 PM
  #9011
Dos Andos's Avatar
Trader Rating: 32 (100%+)
Are they different?
The center one's are 12.8mm long
The drive one's are 13.8mm long
Dos Andos is offline
Old 09-18-2010, 02:29 PM
  #9012
jpalessi's Avatar
yes the center are shorter because of the brakes.
jpalessi is offline
Old 09-18-2010, 02:58 PM
  #9013
Thanks guys.
Old 09-19-2010, 10:42 AM
  #9014
Default where does the oil go ?
i now have about 2 gallons on my 1st nitro buggy. i thought i was overdue for checking diffs and changing oil. i noticed upon teardown there is almost no oil left. there was a little less than a 1/4 inch in the frt and rear diffs and a little more thatn that in the center. i have always kept my ride pretty clean and always check for any type of fluid leaks.never saw any indication whatsoever that there was a leak...anywhere.when i filled these initially i filled the fluid up to the cross shafts and let sit for an hour or so and rechecked.
my other question is regarding my shocks. during a run at a local indoor track i found my r/frt shock was binding up,enough to keep the suspension from extending. after checking the shock shafts and feeling confident they were straight,i chalked it up to being dirt in the shock. drained cleaned(w/o spray cleaner) and replaced the oil it was fine for a few minutes and bound up again. this binding is very very intermittent by the way. when i got home i tore this shock down again and inspected with a magnifying glass and found the shock piston had a slight distortion to it with what appears to be fine threads of plastic on the side of the piston. at this point i replaced the pistons with the black 6 holes. cool everything working great now ! went to the track on fri nite and it happened again. took the shock out and i could get it to bind ..sometimes 3 out of 4 strokes,sometimes once every 50 strokes. but when it binds it takes an act of congress to get it to release again. checked the shafts again and found no problem.i finally loosed the nut on the piston about 1 turn and loosened the collar on the seal pack slightly and hasn't bound up again ( yet...)
any input is appreciated
ty
bpalmer is offline
Old 09-19-2010, 11:43 AM
  #9015
s porter's Avatar
Sounds to me like your pistons were overtightened...Run your seal retaining cups finger tight.. Sometimes I leave mine loose and apply a touch of blue loctite if they feel tight.
On the diffs, you can't run that car 2 gallons and expect the diffs to be full...Service them once every other race if you want optimum performance.
s porter is offline
