Like Tree3Likes
Mugen MBX6
Old 07-19-2010, 02:31 PM
  #8251
Registered User
Originally Posted by donrod
drop the rear roll center to bottom and you should all the traction you will need.
Cheers Pal ill give that a go
Originally Posted by Lonestar
Megacrash
to calm the rear end down on throttle try the following:
- move rear hubs/arms forward
- stiffen rear diff (yes, stiffen... will be harder to drive off throttle though).
Paul
Hi Paul,
thaks for that i thought a thicker rear diff oil would help
ill also try the hubs as well
Cheers all
Megacrash is offline
Old 07-19-2010, 02:40 PM
  #8252
Paulus's Avatar
Use the upper hole in the rear uprights, that will also give you massive grip.
Paulus is offline
Old 07-19-2010, 02:44 PM
  #8253
Registered User
The rear uprights do you mean the rollcenter on the rear shocktower as the guy above says to drop that to the bottom????
Slightly confused now
Old 07-19-2010, 03:10 PM
  #8254
Paulus's Avatar
First try the rear camberlink in the lowest hole on the schoktower, if you then steel need more grip use the upperhole in the rearhub.
Mayby you can give Savoya's european championship setup a try, that was on a very low traction track.
http://www.neobuggy.net/images/News/..._euros2010.pdf
Paulus is offline
Old 07-19-2010, 04:09 PM
  #8255
R/C GUS's Avatar
Originally Posted by R/C GUS
Is there much difference between the mbx6 and the mbx6 m spec ?
A bit late but thanks for all the info .
cheers
R/C GUS is offline
Old 07-19-2010, 04:14 PM
  #8256
Trader Rating: 68 (100%+)
You should be able to get great traction from the Mugen. I know if you drive hard, it's easy to break all these buggies loose. For my liking, I run a weaker clutch spring. That slows down the snap.
Greg B is offline
Old 07-19-2010, 08:18 PM
  #8257
s porter's Avatar
Results may vary but, in my experience, the higher pin location on the hub yields less traction mid corner not more. Higher in location=low roll center...Someone correct me if I'm wrong here
As Donnie mentioned, use the lower hole on the tower, outside on the hub. If that doesn't work, go up in the rear diff and maybe run the rear arms flatter (low position on antisquat).
s porter is offline
Old 07-19-2010, 09:01 PM
  #8258
rcdriver54's Avatar
Somebody tried Losi SMART diff in the centre (or front) on MBX6?
What impressions?
rcdriver54 is offline
Old 07-20-2010, 02:03 AM
  #8259
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
Just received my JConcepts Punisher body today! Looks awesome!
Funking-Awesome is offline
Old 07-20-2010, 04:05 AM
  #8260
James khoo's Avatar
Trader Rating: 15 (100%+)
Originally Posted by morgoth
The top of my bladders is always pushed in a bit... Arrrgh
I just tested my shock with own cut foam,the shock feel lot more consistent.
Love this set up.And the bladders will never push in.
Cheers
James khoo is offline
Old 07-20-2010, 05:24 AM
  #8261
morgoth's Avatar
That's what I'm thinking too. Lower roll center = less grip... The upper hole is good for high traction tracks imo.
Cheers
Do you have a pic of that? My bladders of my brand new mbx6 collapse after 1 run...
morgoth is offline
Old 07-20-2010, 06:06 AM
  #8262
Trader Rating: 120 (100%+)
Is anybody running a different bladder than the mugen one? I seem to have the collasping problem as well. I saw one setup where the guy was using D8 bladders.
JoeC is offline
Old 07-20-2010, 12:04 PM
  #8263
jsp619666's Avatar
The D8 bladder work perfectly it's amazing how much the car is in the rough and the car just does what ever you want it to.
jsp619666 is offline
Old 07-20-2010, 01:51 PM
  #8264
s porter's Avatar
[QUOTE=morgoth;7694239]That's what I'm thinking too. Lower roll center = less grip... The upper hole is good for high traction tracks imo.
Just goes to show you, you need to be careful what information you believe around here. Best advice I can give someone learning is too pester the heck out of the local club race pro
s porter is offline
Old 07-20-2010, 01:59 PM
  #8265
johnny t's Avatar
The problem I noticed with mugen bladders is the "feel" on the track change as the day or race progressed. whether that was due to the bladders collapsing or what I was not sure. Now I run a foam backer with a vented cap and things stay the same throughout a run. Plus the car looks more stable and not bouncing around as much, probably due to the self dampening characteristics of foam as opposed to a bouncy air ball. And opening the shock to see a sunken bladder was not reassuring, even using various tire foam backers did not stop that.
I was using losi bladders for awhile but have found xray (the ribless ones) bladders can work too with foam backer. vented cap of course.
The xray fit loose like the losi's do at first. but had to wait for that mythical xray quality to reveal it self and allow to swell after being exposed to shockoil. now they snap into the cap like the mugen does. In addition the shock is easier to bleed and the shock shaft does not protrude into the bladder as far. How these shocks are designed (almost all manf.) for the shaft to hit these delicate bladders is beyond me.
The big stumbling block I came across during my conversion to vented caps is finding the right foam. everything I tried would not hold up, even AKA tire foam would break down after a day and handling would change. I heard some guys using onroad tire foam.
Just forwarding my experiences with something that others seem wanting to do as well. I may put together a little photo tutorial of the entire conversion if enough are interested.
johnny t is offline
