Like Tree3Likes
Mugen MBX6
Old 07-17-2010, 03:56 AM
  #8206
James khoo's Avatar
Trader Rating: 15 (100%+)
Here how i wire the battery conector and filter holder
James khoo is offline
Old 07-17-2010, 07:00 AM
  #8207
Originally Posted by Lonestar
there's so much work on this car... everything lightened (you should see the wheel hexes)... laydown steering servo (which the legend says his dad did "just because the mugen engineers in japan told him it couldn't be done)... every little detail is carefully thought out... absolute masterpiece. This combined with out-of-this-world fingers and you've got our next world champ
Paul
How much does it weigh?
topcat-lll is offline
Old 07-17-2010, 07:30 AM
  #8208
Registered User
Exactly the same as mine but i run mini deans instead of futaba connectors, have you had them come apart? mine did it once and i swapped them out
Megacrash is offline
Old 07-17-2010, 07:58 AM
  #8209
Glorykid's Avatar
Savoyas car is bang on the 3.2kg weight limit with a lipo/life rx battery fitted.
with a nimh pack its just slightly over.
hope this helps
Glorykid is offline
Old 07-17-2010, 08:15 AM
  #8210
MadRussian's Avatar
I am still in awe of all the work in his car.
Wow!!
MadRussian is offline
Old 07-17-2010, 04:59 PM
  #8211
perdoden's Avatar
Hi all
I need more steering !!
Which setup is best for more steering
Thank you all
perdoden is offline
Old 07-17-2010, 05:05 PM
  #8212
smracer31's Avatar
Originally Posted by perdoden
Hi all
Thank you all
cant help without knowing your current setup
smracer31 is offline
Old 07-17-2010, 07:49 PM
  #8213
Quick question,
Can I order those washers that go behind the clutch shoes separately without ordering another flywheel(have 3).
If so, can I have the part number or maybe a part number or something I can use thats similar?
Andy Z is offline
Old 07-17-2010, 08:15 PM
  #8214
John Sullivan's Avatar
Originally Posted by Andy Z
Quick question,
I think they come with clutch shoes if i'm not mistaken
John Sullivan is offline
Old 07-17-2010, 09:50 PM
  #8215
plus2ss's Avatar
Hey John, What happened to you in the main today? You and Scott had a good battle going. Anyway, i was wondering if you could pm me your setup if you dont mind.
plus2ss is offline
Old 07-18-2010, 12:50 AM
  #8216
James khoo's Avatar
No,I never had that issue.Try to use lighter connector like I'm using and cable tie it to the receiver box.Bigger connector is easy to come loose due to heavier plug swing around or knocked itself loose.
Cheers
Old 07-18-2010, 02:10 PM
  #8217
morgoth's Avatar
Originally Posted by morgoth
Could anyone give me the partnumber of the shims for the front and rear diff? I can't find it in the manual...
Anyone?
morgoth is offline
Old 07-18-2010, 02:54 PM
  #8218
s porter's Avatar
CO114 is a Mugen shim set
Kyosho also sells a pack of 13x16 shims that will work
s porter is offline
Old 07-19-2010, 01:03 AM
  #8219
Lonestar's Avatar
Trader Rating: 14 (100%+)
yes you can buy the flywheel shims without buying the flywheel. They comes in bags of 4. don't have the part# with me, check amain for "flywheel washers mugen" and you should find them.
Paul
Lonestar is offline
Old 07-19-2010, 01:07 AM
  #8220
R/C GUS's Avatar
Is there much difference between the mbx6 and the mbx6 m spec ?
R/C GUS is offline
