Like Tree3Likes
Mugen MBX6
Old 05-28-2010, 11:40 PM
  #7501
Jaz240's Avatar
Trader Rating: 52 (100%+)
Make sure you tighten all 4 caps the same amount, as that also effects rebound rate
Jaz240 is offline
Old 05-29-2010, 12:11 AM
  #7502
mrbusta's Avatar
Trader Rating: 20 (100%+)
oooppsss +1 jazz i forgot to mention that
mrbusta is offline
Old 05-29-2010, 04:37 AM
  #7503
JUD
JUD's Avatar
Originally Posted by mrbusta
hello there i have the henergy brand lipo fantastic battery lifepo wich is 1450 mah fits in there great and last for a long time i got it from cobra racing
works a treat no mods at all
Thanks!!!
JUD is offline
Old 05-29-2010, 11:09 AM
  #7504
BLKNOTCH's Avatar
Just wanted to post that after a bit more research I will be going with the Novarossi 41029/9901SS combo as the MBX6 is a narrow chassis vehicle where the 41021 would not be a good fit.
Sean
BLKNOTCH is offline
Old 05-29-2010, 02:01 PM
  #7505
lk
Default Life battery
I use the Hyperian 850 wich will easily do a 30 minute main and I have heard of 45, and a LRP 1400 which will go for over 90 minutes.
Both fit in the MBX6 without modifications.
lk is offline
Old 05-29-2010, 02:22 PM
  #7506
Eman 12's Avatar
Default bearings
What kind of bearings do you guys use for the mbx6
thanks
Eman 12 is offline
Old 05-29-2010, 08:55 PM
  #7507
FactoryRacing23's Avatar
Trader Rating: 2 (75%+)
I just got a full Ready Roller bearing set for mine, Have yet to install them but hear they are the way to go..
FactoryRacing23 is offline
Old 05-29-2010, 11:18 PM
  #7508
Funking-Awesome's Avatar
Trader Rating: 30 (100%+)
I use plaig bearings throughout my Mugens. They are cheap but great quality!
Replace them every couple of race meets and you'll be fine!
Funking-Awesome is offline
Old 05-30-2010, 10:16 AM
  #7509
JUD
JUD's Avatar
Ok I was wondering if anyone cuts an opening in the top of the battery box so the leads can stick out for charging? Or would it be bettery to keep it covered. Thanks
JUD is offline
Old 05-30-2010, 10:53 AM
  #7510
jnslprd's Avatar
i closed mine in,just moved the charge lead into the battery compartment so its only 2 screws to access.
has anybody rigged up an electronics tray with body clips instead of screws?
jnslprd is offline
Old 05-30-2010, 01:46 PM
  #7511
plus2ss's Avatar
I soldered a charge lead to my on/off switch wires going to the battery, and ran the lead out of the gromet with the servo wires. I also put a thin bead of silicone rtv around the lids of the radio box. No more dirt in my box, and i dont have to take the lid off to charge. I do peek in there once and a while to make sure everything is ok.
plus2ss is offline
Old 05-30-2010, 05:54 PM
  #7512
Eman 12's Avatar
Default wheel hubs
Have you ever had any problems taking your wheel hubs off. i got to replace my bearings and i cant pull them off
Eman 12 is offline
Old 05-30-2010, 09:00 PM
  #7513
s porter's Avatar
If you used loctite, try putting a little heat to it before trying to loosen the set screw. Only use a dab of red loctite when reasssembling.
s porter is offline
Old 05-30-2010, 10:21 PM
  #7514
I have always used blue locktite on the hubs and never had any problem what so ever. The only place i use red locktite any where is on the bone pins.
dreaux is offline
Old 05-31-2010, 06:37 AM
  #7515
JUD
JUD's Avatar
Thanks fellas! It just seems so much safer for everything to be in the box. Wonder why Mugen doesn't make the room for the leads? They have the space.
JUD is offline
