Like Tree3Likes
Mugen MBX6
Old 09-12-2008, 04:59 PM
  #601
teeforb's Avatar
Trader Rating: 94 (100%+)
What's the cheapest you guys are getting them for?
teeforb is offline
Old 09-12-2008, 05:04 PM
  #602
teeforb's Avatar
check this out guys!!!
http://www.modelsinmotion.co.uk/prod...338&tamiya=268
teeforb is offline
Old 09-12-2008, 05:40 PM
  #603
Got mine for 500 from Eddie at full throttle. Great company to deal with
clarksib is offline
Old 09-12-2008, 05:59 PM
  #604
moeman's Avatar
Trader Rating: 26 (100%+)
Have you got a link Brutha?
moeman is offline
Old 09-12-2008, 06:13 PM
  #605
TonysScrews's Avatar
The new MBX6 has a 44T conical (ring) gear and 13T pinion gear in the diffs. Stock spur gear is 46T and clutch bell is 13T for an overall final drive ratio of 11.98:1 (MBX5R had 40/12 R&P with 13/46 CB&S for a final drive ratio of 11.79:1).
Stock MBX6 turnbuckles are steel, rear hubs are plastic and shock towers are carbon fiber. Doesn't look like a whole lot of option parts are needed for the MBX6 to fully bling it out (aka MBX6R). I personally like the rear hubs in plastic. Titanium turnbuckles will save some weight. Aluminum shock towers will not be needed unless the carbon fiber ones prove to be weak.
Weight will not be an issue. They are already at 7.2 lbs without any lightening.
MBX6 Option Parts:
E0117 - Titanium Rear Camber Link
E0142 - Aluminum Pillow Balls (4 pcs)
E0142/1 - Aluminum Pillow Balls (2 pcs)
E0163 - Front Sway Bar (2.2mm)
E0164 - Front Sway Bar (2.3mm)
NOTE: STOCK...E0165 - Front Sway Bar (2.4mm)
E0166 - Front Sway Bar (2.5mm)
E0167 - Front Sway Bar (2.6mm)
E0168 - Rear Sway Bar (2.7mm)
E0169 - Rear Sway Bar (2.8mm)
NOTE: STOCK...E0170 - Rear Sway Bar (2.9mm)
E0171 - Rear Sway Bar (3.0mm)
E0172 - Rear Sway Bar (3.2mm)
E0173 - Aluminum Rear Upright Set
E0173/L - Aluminum Rear Upright Set (Left)
E0173/R - Aluminum Rear Upright Set (Right)
E0233 - Spur Gear 44T
NOTE: STOCK...E0234 - Spur Gear 46T
E0235 - Spur Gear 48T
E0240 - Wide Offset Hub 1mm
E0241 - Wide Offset Hub 2mm
NOTE: STOCK...E0543 - Shock Piston 1.35mm 5-hole
E0544 - Shock Piston 1.25mm 6-hole
E0549 - Aluminum Front Damper Stay
E0550 - Aluminum Rear Damper Stay
E0551 - Front Spring 1.6mm 9.5T
NOTE: STOCK...E0552 - Front Spring 1.6mm 9.25T
E0553 - Front Spring 1.6mm 9.0T
E0554 - Rear Spring 1.6mm 10.5T
NOTE: STOCK...E0555 - Rear Spring 1.6mm 10.25T
E0556 - Rear Spring 1.6mm 10.0T
NOTE: STOCK...E0707 - Clutch Bell 13T
E0708 - Clutch Bell 14T
E0709 - Clutch Bell 15T
E0808 - Titanium Servo Turnbuckle Rod 35mm
E0830 - Titanium Steering Turnbuckle Rod 44mm
TonysScrews is offline
Old 09-12-2008, 06:57 PM
  #606
FrankBlack's Avatar
Any idea if the titan turnbuckles on the 5r will fit the 6?
FrankBlack is offline
Old 09-12-2008, 07:06 PM
  #607
The servo turnbuckle and the rear camber link turnbuckles are the same part number. The steering turnbuckles are a different part number. I'll have to measure the 5R ones to see how long they are. The new X6 ones are 44mm so the 5R ones "might" work if they are really close.
Old 09-12-2008, 07:29 PM
  #608
Vsfriedmugan's Avatar
yea no a R kit "YET" lol but scott has his 6 with the new proline body on mugens website with the 6r decals (the 5's mod. to look like a 6) so myself and all you other mugen finatics are going CRAZY!
Vsfriedmugan is offline
Old 09-12-2008, 07:31 PM
  #609
hey Tony when can we get your x6 screws??????
Old 09-12-2008, 07:38 PM
  #610
FrankBlack's Avatar
Thx Tony, so the 5r came with "all" the turnbuckles titanium and the 6 has all steel turnbuckles?
Old 09-12-2008, 08:23 PM
  #611
The 5R was basically a full option kit. The 6 is going to be a standard kit with some nice parts included and you buy the options you want or think you have to have, or at least for now that's how it will be.
jetmechG550 is offline
Old 09-12-2008, 08:48 PM
  #612
Sam-E's Avatar
The old bring out the basic buggy, sell the option parts then bring out the fully optioned version, thats one way to get either two kits out of your customers or sell a lot of optioned parts.
Hmmm, me thinks I have seen this type of marketing before!!!
Sam-E is offline
Old 09-12-2008, 08:55 PM
  #613
Davidka's Avatar
Trader Rating: 86 (100%+)
Oh please... This is no basic buggy, in all likelihood there will be no "R" version. There is too little to "upgrade" on this. Come to think of it, not much of the stuff that came with the 5r did anything to improve the performance over the standard kit, it just made it heavier. Of course, every CNC alloy junkie out there bought it anyway.
This car is going to be a big disappointment, somebody buy my EC so I can prove it.
Davidka is offline
Old 09-12-2008, 09:10 PM
  #614
Sam-E's Avatar
Yes but why supply what is supposed to be a race buggy with steel turnbuckles, mugen must know that 90percent of racers will toss them.
Sam-E is offline
Old 09-12-2008, 09:13 PM
  #615
They may have gone with steel to keep some weight up????? With just a couple of option parts and lightweight parts, Scott Hughes said his weighed in under the ROAR limit.
