Like Tree3Likes
Mugen MBX6
Old 09-06-2009, 12:43 AM
  #4996
Default Brushless Conversion Set-up Sheet.
Well,
After yesterdays day of racing, I'm planning on taking my Brushless Conversion MBX6 back to a baseline set-up. My problem is I'm new to offroad, and have tried some stuff, suggestions from those who know and wild a_ _ guesses from my own mind.
I race on hard packed, mostly dry tracks with a good amount of jumps and corners, some off camber stuff. Basically good track layouts where you need a good neutral car.
If anyone and suggest a good starting point set-up sheet it would be appreciated.
Thanks in advance!!!
everything_rc is offline
Old 09-06-2009, 02:39 AM
  #4997
T-spoon's Avatar
Originally Posted by jpz_67
9.75/10.75 for most tracks. If it is really bumpy and rough I move to the 10.0/11.0 springs. I have not found the need to go any softer than these yet.
Thanks,gonna give them a try today.
T-spoon is offline
Old 09-06-2009, 07:15 AM
  #4998
keetonni's Avatar
Hey guys iam really thinking about getting a mbx6. Do u guys have any tips for building or setup wise? Thanks Keeton
keetonni is offline
Old 09-06-2009, 07:18 AM
  #4999
Davidka's Avatar
Trader Rating: 86 (100%+)
Follow the instructions and don't use the S3 o-rings in the diffs.
Davidka is offline
Old 09-06-2009, 08:34 AM
  #5000
keetonni's Avatar
Thanks were can I find the 10.75 and 9.75 springs at? And a part number would help out to thanks
keetonni is offline
Old 09-06-2009, 10:44 AM
  #5001
has anybody used the upper hole on the rear uprights? and if so how do you like it
thanks
john
JHN1 is offline
Old 09-06-2009, 11:41 AM
  #5002
jpz_67's Avatar
Trader Rating: 57 (100%+)
thanks
john
I am using the upper hole on my current setup. It made the car more planted in the rear and felt like it slowed down the rear from rotating so quick. Made the car easier to drive.
jpz_67 is offline
Old 09-06-2009, 02:43 PM
  #5003
sugelle's Avatar
Trader Rating: 63 (100%+)
I just read the MBX6-Kris Moore interview article that was in rc car magazine a few months back. Kris mentioned that a lot of drivers use 14T pinion gear versus the stock 13 T. Ny question....whats the difference or the advantage? I never quite understood gearing
sugelle is offline
Old 09-06-2009, 02:48 PM
  #5004
Marcus Falconie's Avatar
a little more top end and a smoother bottom end with the 14, most if not all the Mugen guys still run the 13 at the Nitro Pit a very big track.
Marcus Falconie is offline
Old 09-06-2009, 02:54 PM
  #5005
sugelle's Avatar
Wow...that was fast! Thanks for your answer. So on a more technical, motocross style smaller track would you say 14T or 13T clutch bell???
sugelle is offline
Old 09-06-2009, 02:57 PM
  #5006
jpz_67's Avatar
The 13, so you have more rip coming out of the turns or for short run up jumps.
jpz_67 is offline
Old 09-06-2009, 04:13 PM
  #5007
Trader Rating: 16 (100%+)
Just switch to the 44 spur if you want to get more top end, Moves the engine in more towards the center of the chassis
Zach Phillips is offline
Old 09-06-2009, 05:41 PM
  #5008
T-spoon's Avatar
I haven't found a place where a 14 tooth doesn't work yet.It also helped keep "MY" ass end a lot calmer.So far so good..
T-spoon is offline
Old 09-06-2009, 07:47 PM
  #5009
Davidka's Avatar
I use my old OS RG (good low end torque, not much top end) with a 14t bell. It sounds slow and goes fast.
Davidka is offline
Old 09-06-2009, 07:57 PM
  #5010
sugelle's Avatar
What exhaust pipe and header works well with this narrow chassis? I have a Jammin JP.21 and I tried to mount a JP2 Pipe but it doesn't fit within the molded mud gaurds. Any ideas?
BTW...Saving my $$$ to get a Mugen Ninja and OS 2060.
sugelle is offline
