Like Tree3Likes
Mugen MBX6
Old 05-11-2009, 04:46 PM
  #3526
Trader Rating: 35 (100%+)
the springs this kit came with are grey, so i am assuming it is the old kit.
losiracer22 is offline
Old 05-11-2009, 04:51 PM
  #3527
OfnaJoe's Avatar
Trader Rating: 58 (100%+)
No, even the 1st run kits had black springs, look at the lower suspension arms, if they have a cut out under the outdrives it is the updated kit
OfnaJoe is offline
Old 05-11-2009, 05:05 PM
  #3528
ezveedub's Avatar
Trader Rating: 17 (100%+)
All the MBX6 springs are black. Look the the front lower arms. If they are flat on the bottom, its version one. If it has a bump on them to clear the ackerman ball ends, its version two. 2.3F & 2.8R swaybar also are version 2.
ezveedub is offline
Old 05-11-2009, 06:46 PM
  #3529
Davidka's Avatar
Trader Rating: 86 (100%+)
You might have an MBX5 or 5r then, they came with gray springs. None of the new big bore springs are any other color than black (wish they'd go back to colors though..).
Davidka is offline
Old 05-11-2009, 06:53 PM
  #3530
pl_unc86's Avatar
Is there really much difference in the original version and the updated kit? Performance wise? I traded a guy a computer for one and it just noticed it is the first gen one. I have another kit on its way though.
pl_unc86 is offline
Old 05-11-2009, 07:13 PM
  #3531
rockfordccinc's Avatar
Default shock oil
what is the equivalent to the #400 that comes with the kit to losi oil?
rockfordccinc is offline
Old 05-11-2009, 07:39 PM
  #3532
Davidka's Avatar
Losi 32.5 is closest to Mugen 400.
Davidka is offline
Old 05-11-2009, 07:45 PM
  #3533
Default Diff question.. seems tight
Just got done building my diffs and they seem tight. I am using the Tonys Screws Orings, Mugen diff oils. 5-5-3
They just seem so tight. I did not use the S3 orings in the diffs. Should I double gasket??
Help in a hurry.. not going to continue until I hear back from you guys...
mOOgo_davo is offline
  #3534
T-spoon's Avatar
Smile
Losi 32.5 =397wt and losi 30=381wt hope this helps...
T-spoon is offline
Old 05-11-2009, 07:49 PM
  #3535
T-spoon's Avatar
Cool
I built my diffs today with tony's o-rings,I use only one gasket without the s3 o-rings and they are really smooth.
T-spoon is offline
Old 05-11-2009, 07:50 PM
  #3536
I have built the ones in my MBX5T Many times and they never seemed this tight.. Do that just need to be broken in? No nothcy or hard spots just stiff...
  #3537
porkchop's Avatar
how far did you fill you only want to go to the cross pin it sounds like it way to full because i been runing the same oils
porkchop is offline
Old 05-11-2009, 07:58 PM
  #3538
filled to the cross pins
Old 05-11-2009, 07:59 PM
  #3539
porkchop's Avatar
just give them time to break in then
porkchop is offline
Old 05-11-2009, 08:23 PM
  #3540
TonysScrews's Avatar
Update!
Tony's Screws now sells the GMK Supply Mobil 1 Grease. The grease comes in a reusable syringe that has a threaded cap on the end to keep the grease from leaking out. The Mobil 1 synthetic grease is ideal for diff o-rings. It's a perfect addition to the Tony's Screws S5 diff o-rings!
TonysScrews is offline
