Like Tree3Likes
Mugen MBX6
Old 03-26-2009, 11:33 AM
  #3046
Mugen9112's Avatar
Originally Posted by imaxx21
190292926364
Make the offer for $28
Mugen9112 is offline
Old 03-26-2009, 05:58 PM
  #3047
zJatoRad's Avatar
Trader Rating: 38 (100%+)
does anyone need MBX6 air filters?
http://www.rctech.net/forum/r-c-item...b0118-2-a.html
zJatoRad is offline
Old 03-27-2009, 07:32 AM
  #3048
Moving the rear hubs up or back,, what does this do for the cars handling? Can someone explain this? Thanks
justag3 is offline
Old 03-27-2009, 07:40 AM
  #3049
Trader Rating: 50 (98%+)
moving the hubs back takes weight of the rear of the car and give more exit corner steering.
going to the upper hole on the rear hubs is like raising the roll center on the tower.
micrors4guy is offline
Old 03-27-2009, 07:56 AM
  #3050
thuren's Avatar
Gives more exit steering because that weight off the rear(like mentioned) translates into more weight on the front to hold the front tires on the ground better under power. Less wheelie effect This is also putting more weight on the front all the time, so I feel you get better corner entry steering too when the track is low traction. I pretty much run my rear hubs/arms all the way back unless the track is really high bite, although the longer wheelbase should make the car less twitchy when it is high bite, so I may just leave the car long the next time I'm on a sticky track.
edit: ever notice how long the new Losi 2.0 is? It's LOOOONG. They work really good too.
thuren is offline
Old 03-27-2009, 11:55 AM
  #3051
Thanks for the advice,,, very good.......
justag3 is offline
Old 03-28-2009, 01:22 PM
  #3052
Keep in mind, if you go too far back, you lose out on traction.
Jesse is offline
Old 03-28-2009, 04:37 PM
  #3053
Trader Rating: 14 (100%+)
not really.
moving the hubs up or down changes both the forward traction and side bite.
I cant remember what height does what, but one hole will reduce side bite and increase forward traction, compared to the other. In contrast, the other hole will increase side bite and decrease forward traction.
o.s. power is offline
Old 03-28-2009, 04:39 PM
  #3054
imaxx21's Avatar
yellow is the new pink
imaxx21 is offline
Old 03-28-2009, 04:51 PM
  #3055
Trader Rating: 25 (100%+)
The further back or longer the wheel base.....you loose traction? I've heard that before, why is that?
arm2storm is offline
Old 03-28-2009, 04:57 PM
  #3056
Sam-E's Avatar
Less weight over the rear axles, more pronounced in electric 2wd.
Sam-E is offline
Old 03-28-2009, 04:59 PM
  #3057
Mugen9112's Avatar
imaxx - how do you like the os speed 2?
Old 03-28-2009, 05:02 PM
  #3058
imaxx21's Avatar
best engine ive ever ran.
smooth power everywhere, and great fuel mileage
ive got the 6mm in the carb and a 2050 pipe, feels great
imaxx21 is offline
Old 03-28-2009, 05:04 PM
  #3059
Mugen9112's Avatar
Yea i hear that! I have the os speed alum 1 and I am enfatuated I run the 5.5mm insert with the 2060 pipe = f**kin sick
btw your knuckles got shipped out yesterday.
Old 03-28-2009, 05:05 PM
  #3060
imaxx21's Avatar
sweet thanks.
imaxx21 is offline
