Like Tree2Likes
Mugen MBX6
Old 03-18-2015, 06:11 PM
  #18526
Originally Posted by curacing2 View Post
We looked at doing that but the inserts on the 6 push in from the outside and the 7 push in from the inside so the recesses are on different sides, even the holes are different sizes so you can't just turn the front 2 holder around, I always liked the 6 system but the 7 is so much better in ease of diff removal and don't flog out (get slop) like the 6 inserts do.
Oh well I will stay with the threaded hinge pins, thanks anyway
30Tooth is offline
Old 03-19-2015, 02:54 AM
  #18527
bcr500's Avatar
Trader Rating: 34 (100%+)
Don't give up already. I'm almost positive that the blocks from the mbx7t are the same width as the mbx6 blocks so you can still use the 6 arms.
bcr500 is offline
Old 03-19-2015, 04:27 AM
  #18528
damang999's Avatar
Trader Rating: 15 (100%+)
Does anybody know if the 7 body will fit on the 6 ok ?
damang999 is offline
Old 03-19-2015, 08:09 AM
  #18529
You might be very right, the plates change a little visually but at least seem very close. Thanks!
Yes it does, at least the MBX7 body on the MBX6 (mine isn't a R). Cut the tail of the 7 body a little more past the rear body post and that's it.
30Tooth is offline
Old 03-19-2015, 10:22 AM
  #18530
Ccolemugen's Avatar
Trader Rating: 10 (92%+)
I have done the change over to captured hinge pins from the 7T on my MBX6R and they are Identical. Now just that much easier to work on. The front B block dosent have the 2 3mm screws that hold it to the chassis. I use the M2C B-block instead of the mugen. I also used the same setup on one of my X7's to run the X6 rear arms captured as well. (dollarhobbyz) sells everything you need in one part #.
Ccolemugen is offline
Old 03-19-2015, 12:23 PM
  #18531
damang999's Avatar
Thanks 30tooth
Old 03-19-2015, 01:20 PM
  #18532
Thanks 30tooth
No problem, also didn't have to enlarge the hole for the engine but had to drill a hole for the antenna before painting because the 7 radiotray has the antenna in another place. I recommend velcro to attach the body.
30Tooth is offline
Old 03-28-2015, 07:34 PM
  #18533
Default Manifold
Hey guys..im new to offroad and i got a used mbx6r..im planning to use a novarossi p5xlt engine but i dont know what manifold should i get...the novarossi 41030 long compact manifold or the novarossi 41029 short compact manifold?..both are mugen polished...thanks guys.
Angeluz03 is offline
Old 11-05-2015, 05:20 PM
  #18534
dollarhobbyz.com/mugen/mbx7t/mugen-1-8-mbx7t-front-rear-suspension-arm-hinge-pins-nuts.html
are these the parts you are talking about?
Kris Flynn is offline
Old 11-05-2015, 07:25 PM
  #18535
Ccolemugen's Avatar
You would also need the hinge pin mounts below also. They have been out for quite some time. You might be able to find the same kits on eBay or when dollar restocks truggy parts when the X7TR comes out. I still run my MBX6R from time to time and love how it drives.
Mugen 1/8 MBX7T Aluminum Suspension Arm Hinge Pin Mounts & Bushing Set
Old 03-12-2016, 03:36 PM
  #18536
1/8 IC Fan's Avatar
Trader Rating: 102 (100%+)
To get some insight, was it Mugen that offered the Carbon Side Guards, and if so what is the Part Number
1/8 IC Fan is offline
Old 03-13-2016, 08:49 AM
  #18537
Nope, it was user Rpm1968 that offered them. Quick google search and mbx6 manual doesn't return anything Mugen made for the 6, I remember there was for the 5R.
30Tooth is offline
Old 03-18-2016, 10:50 AM
  #18538
thkelly's Avatar
Does anyone know if the mbx7 tank fits the x6?
thkelly is offline
Old 03-20-2016, 12:05 PM
  #18539
Stobert2012's Avatar
Okay... So, I'm sure I'm asking a question that's been asked a hundred times over. But, I don't feel like going through a thousand pages to find it. I'm new to 1/8 scale and just bought a Mugen MBX6. Are most of the parts backwards compatible with the MBX7, our no? And, if some super nice guy could give me maybe a detailed answer, that would be great.
Stobert2012 is offline
Old 03-20-2016, 02:59 PM
  #18540
From what I remember from the X7 first days people were getting the 6 tank on the 7. To drill a new hole is expected but confirm that on the start of the X7 thread and not the X7R thread.
Drivetrain and suspension parts if you change a bunch of them together as they are relying on new parts to work. Steering parts/chassis are a no-no as the steering has the pivots closer together amongst other small changes. The upgrade I can recommend is the 7's ring and pinion gears as the standard 6 parts aren't free rolling other than that the car is top notch.
30Tooth is offline
