Mugen MBX6
Hi guys..
i am new to mugen world. 3 month old and addicted to lightweight rotating part.
my first my upgrade is
Acer ceramic bearing kit for mbx6, E0242 & E0243 on the front only. after tested few round and found i do really like this stuff.. less rotating mass. then i go buy another for the rear..
now im looking fiber disk to replace steel disk that can fit on to the join cup..
has any one here have try fiber disk? what fiber disk can fit on my mugen and does its work perfect?
tried find at nearest LHS but couldnt found the disk fit on mugen
Thanks..
Thanks..
http://racemugen.com/catalog/xtreme-...acturers_id=54
if you want long lasting and non fading performance try PSM disk.
i use it on my car for a year now and still look new.
after 16 races the brake wont let you down.
try it dude
try it dude
Is anybody using the M2C long rear chassis brace? Picked it up and wondering if there's an advantage of using it. I need to drill the chassis if I need extra support
Hi guys..
Thanks..
Thanks..
Got a noob question for y'all.
Most set up sheets by mugen drivers include mugen shock and diff oils. I have always mainly ran mugen oils, but is there that much of a difference in other oils? Is the quality any different? I have read and heard different things about the temperature effects oils differently. Is it really just a sticker your paying for or is the quality of mugen oils worth the price?
Shoot me some opinions guys!
They are worth it in my opinion, they last longer before breaking down in my experience.
I agree. Mugen makes good diff oils. I use associated in the shocks.
Dirt keep flowing through my gear boxes. Any suggestion on assemblibg the gearbox for dirt proof.
Any tip for adjust the engine mount, its hard to make them paralel the cb and the spur.
http://rcracer.co.nz/Forum/viewtopic.php?f=5&t=2374
Blake... This is a shock oil chart that converts CPS (Mugen) to WT. For instance Mugen 450 is about the same as Associated 35 wt.
I don't know if all diff oils are measured the same or not. Anybody??
For me, i have found out that different oil is best at different temp. ranges. F.eks Losi, very good oil from 20 degrees celsius and up. Kyosho is perfekt from 15-25 degrees before the viscosety changes so much that i need to go up or down in viscosety.
I use Mugen oil because it hold up well and my teammates also use it. We can then compare setups and what we feel happends when changing up or down in viscosety or change pistons. I think working togehter as a team and help eachother out is the most important thing as it helps a great deal when chasing setups. I think alot of guys does not think of this.
I also run Losi oil and have no complaints.. for losi oil run 37.5 front/37.5 rear as a good strating point
Hi guys..
Thanks..
Thanks..
http://www.amainhobbies.com/product_...Set-20-Updated
http://www.amainhobbies.com/product_...e-Spring-Set-4
