Like Tree3Likes
Mugen MBX6
Old 09-25-2012, 11:32 PM
  #17716
jmaxey51's Avatar
Originally Posted by kman16jr
Ok but if i have tires should i try that first?and how would the rotation be if i used 7-10-7,And i can aslo try the inserts in the rear toe block as well,the springs i dont have so what should i try first?
Try tires first, 9 times out of 10 it's tires causing the issue. Then inserts... 7-10-7 will let the buggy turn more, the rear will be more possy and it will slide around the turns but square up faster and straight line is hooked. It's also very consistent. A lot think I'm crazy for running it but once they try it they usually love it.
jmaxey51 is offline
Old 09-26-2012, 12:09 AM
  #17717
kman16jr's Avatar
Trader Rating: 56 (100%+)
Thanks ill try the tires first and if it doesnt help than ill try the inserts,and if worst comes to worst ill change the diff oils.lol.What about moving the rear hubs more forward?
kman16jr is offline
Old 09-26-2012, 12:42 AM
  #17718
shaidi khalid's Avatar
try use the lower holes in the shock tower.the diff oil can effect as well.for me i run 5-7-3 and lighter shock oil..i'll use 350 with 8.5 springs.the outer holes for shocks also helps..but first,try change the tyres dude.
shaidi khalid is offline
Old 09-26-2012, 01:53 AM
  #17719
TRF415boy's Avatar
Originally Posted by shaidi khalid
hi there
im now using mbx6..
i want to change the chasis of my car
which one is better in handling?
mbx6r or the mbx6r eu edition?
can someone help me with this?
Hi,
Since no one in the US has any experience with the R-EU chassis, there are only a few people here who can tell you which is better.
I can tell you one thing: if you can get hold of the EU chassis, get it (and don't forget to get the front centre driveshaft to go with it). it's MUCH better than any other chassis out there.
TRF415boy is offline
Old 09-26-2012, 05:28 AM
  #17720
thanks dude
i wanted to try both of them
and decide which one is better
Old 09-26-2012, 10:48 AM
  #17721
jmaxey51's Avatar
Shorter wheel base will help a good bit too, all easy things to change at the track. Try all of that before diffs.
jmaxey51 is offline
Old 09-26-2012, 11:21 AM
  #17722
mjealey's Avatar
Originally Posted by shanef
You'd want to lower the rear link on the tower to gain more rear grip. Can also try to lay the rear shock over, lighter rear shock oil, longer rear link.
I think you guys have it backwards. You want to go up on the shock tower to lower the roll center of the buggy. A lower roll center increases rear grip.
http://jq-products.com/the-news/43-t.../160-the-guide
In general, longer links make the car more calm, and gives it more traction, and actually even improves forward bite. Having the links as far in on the shock towers as possible, makes for the most stable car. Raising the link on the tower, has a similar effect of lengthening it, in that it gives more traction.
Short links make a car more responsive, and make it square up better and faster when exiting a corner. It can feel like it has more traction, and ultimately it does, but it is more uneven. The car will have a lot of traction up to a point, and then it will suddenly loose it, spin out or similar, so it won't be as easy to drive. Lowering the link on the tower will have a similar effect, as a shorter link, and will make the car be more responsive, and have less traction.
mjealey is offline
Old 09-26-2012, 02:48 PM
  #17723
Numburn's Avatar
That is the area of setup that really confuses me. According to that raising the camber link on the tower increases sidebite. So you would think that using the upper hole on the hubs would (decreasing space between arm and link) would have the same effect. Yet, from what I understand using the lower hole on the hubs gives more sidebite. The only reasoning I can come up for this is that changing the bottom hole on the hubs is changing leverage at the pivot point on the lower arm... very confusing.
Numburn is offline
Old 09-26-2012, 03:00 PM
  #17724
merdith6's Avatar
Default Yep
You are correct.
I have tried several things to improve rear traction with the agressive low speed steering I have that I want to keep. Most of the adjustments to improve rear grip is at the expense of low speed steering. for example, more caster makes the car less twichy but gives too much on power for my driving style. I dids move the rear hubs forward but only the smallest spacer width because too much makes the car drive funny.
Moving the upper link higher on the tower is the conclusion i came to for increasing sidebite too, have not tried it yet.
merdith6 is offline
Old 09-26-2012, 06:51 PM
  #17725
JamminSP's Avatar
REAR UPPER CAMBER LINK - SHOCKTOWER
EFFECT ON REAR ROLL CENTER
Upper holes • Lower rear roll center
Lower holes • Higher rear roll center
REAR ROLL CENTER CHARACTERISTICS
Higher
• Increases on-power traction
• Use to avoid traction rolling at corner entry
• Use under low-traction conditions
Lower
• Decreases rear traction into corner
• Increases steering into corner
• Use to avoid traction rolling mid-corner and corner exit
REAR UPPER CAMBER LINK -LENGTH CHARACTERISTICS
Shorter link (outer hole on tower and/or inner hole on hub)
• Increases steering and decreases
stability into corner
• Increases on-power traction slightly
Longer link (inner hole on tower and/or outer hole on hub)
• Decreases rear camber gain
• Increases stability
• Slows down the car‘s responsiveness
JamminSP is offline
Old 09-27-2012, 01:39 AM
  #17726
Anyone know what air filter battle is running here:
Chris-s is offline
Old 09-27-2012, 01:48 AM
  #17727
Rock333's Avatar
Trader Rating: 51 (100%+)
It is from Pro-Line. Good luck finding one. Been looking for them every where with no luck.
Rock333 is offline
Old 09-27-2012, 06:13 AM
  #17728
robert battle use ultimate racing air filter
im using it
Mugen Seiki Malaysia / Ninja / oddonell' / Sweep Racing / Max Racing Products / Muchmore / Sanwa
Old 09-27-2012, 06:51 AM
  #17729
Motorman007's Avatar
Trader Rating: 89 (100%+)
http://www.modelixracing.com/en/comp...ilter?sef=hcfp
Motorman007 is offline
Old 09-27-2012, 07:49 AM
  #17730
tobatoci's Avatar
Default fiber disk
Hi guys..
i am new to mugen world. 3 month old and addicted to lightweight rotating part.
my first my upgrade is
Acer ceramic bearing kit for mbx6, E0242 & E0243 on the front only. after tested few round and found i do really like this stuff.. less rotating mass. then i go buy another for the rear..
now im looking fiber disk to replace steel disk that can fit on to the join cup..
has any one here have try fiber disk? what fiber disk can fit on my mugen and does its work perfect?
tried find at nearest LHS but couldnt found the disk fit on mugen
Thanks..
tobatoci is offline
