Like Tree3Likes
Mugen MBX6
Old 12-07-2008, 01:18 PM
  #1696
CanyonCarverR1's Avatar
Originally Posted by clarksib
What did you change with your diffs? I have the mid/exit push and am running 5-5-2 diff setup so far 400 fr/ 350 r shocks
Change the center diff to 7K oil, it will give more drive to the rear and help it turn while on the throttle. There's a great article my Chad Bradley on diff setup, try googleing it.
CanyonCarverR1 is offline
Old 12-07-2008, 01:24 PM
  #1697
tony montana's Avatar
Trader Rating: 76 (100%+)
Im really looking for more steering off power
tony montana is offline
Old 12-07-2008, 01:27 PM
  #1698
Originally Posted by tony montana
understeering mid to exit corner, said I may need to take some droop out
Sorry, when you said "mid to exit corner" I thought you meant on the throttle.
Old 12-07-2008, 01:32 PM
  #1699
when I come into a corner pretty hot, I want the car ito hug the line off power with out pushing till I hit the exit of the turn to get back on throttle
Old 12-07-2008, 02:57 PM
  #1700
jpz_67's Avatar
Trader Rating: 57 (100%+)
Not to many people may like it but so far 7-4-2 is money for me. Car did not seem to give up any turn in and pulls better mid corner out.
jpz_67 is offline
Old 12-07-2008, 03:27 PM
  #1701
Here's that article I was talking about...good reading!
http://xtremerc.com/pages/howto.php?howto=24&page=3
Old 12-07-2008, 03:29 PM
  #1702
I think I understand what you're experiencing. I too am trying to get some more off power steering. I'm going to try lighter oil in the front diff. Check out the link in my previous post.
  #1703
I may have found the problem, I had alot of droop in the car. I looked at scott's setup and his droop is like 19, I had like 25 in the rear. That may have made the car lazy
Old 12-08-2008, 03:53 PM
  #1704
Default MBX6
just wanted to know i am about to order mbx6 but does it come with the upgrade stickers and the upgraded parts like the battery box the upper hinge pin holders and i think a new fuel tank.
any info would be great
thanks
JHN1 is offline
Old 12-08-2008, 04:17 PM
  #1705
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
There are no issues with the fuel tank and battery box that I'm aware of, unless I missed something.
Search the thread, the answers to your questions are in it.
fiveoboy01 is offline
Old 12-09-2008, 10:40 AM
  #1706
slow coach's Avatar
if your using the mugen droop gauge then scotts 19 has more droop than your 25, by more i mean more downtravel.
+1 running that diff setup also runs pretty good this setup was suggested by one of the UK drivers so looks like it works worldwide as well
slow coach is offline
Old 12-09-2008, 03:32 PM
  #1707
Hey guys are the driveshaft axles the same between the X5 and X6?
Losi-Runner is offline
Old 12-09-2008, 04:29 PM
  #1708
Im not using the mugen droop gauge. I use digital calipers with a wheel under the chassis and then measure to the rear hubs with the shocks off.
Old 12-09-2008, 07:56 PM
  #1709
Braz's Avatar
Trader Rating: 3 (80%+)
X6 are longer due to the captured cvd pin arrangment, checked that out before i gave all my X5 spares away.
Braz is offline
Old 12-09-2008, 10:58 PM
  #1710
Oh good to know. So does any one know where to get those new alu driveshaft axles and center shaft cups from Mugen? I'm searching and no luck as of yet.
