Like Tree3Likes
Mugen MBX6
Old 11-30-2008, 03:33 PM
  #1621
vikingen...I have always ran these without any problems....
Dynamite 2553....aluminum steering horn
Dynamite 2543....aluminum brake/throttle horn
quimby is offline
Old 11-30-2008, 04:13 PM
  #1622
tony montana's Avatar
Trader Rating: 76 (100%+)
man you werent kidding, that chassis is tweaked alright
tony montana is offline
Old 11-30-2008, 04:30 PM
  #1623
FrankBlack's Avatar
I know I did a yr with the 5r on the same chassis and its still true, my 6 is only 2 month old. Dont wanna replace it till you can get a extended engine mount or something
FrankBlack is offline
Old 11-30-2008, 05:29 PM
  #1624
CanyonCarverR1's Avatar
Damn! How'd that happen? Just wondering if there's something I need to be aware about.
Originally Posted by FrankBlack
CanyonCarverR1 is offline
Old 11-30-2008, 05:33 PM
  #1625
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
I've got a brand-new chassis plate here and it's bent just like that.
fiveoboy01 is offline
Old 11-30-2008, 06:00 PM
  #1626
FrankBlack's Avatar
Serious?? Im sure i put a ruler on the chassis when i first built the kit and it was straight. I dont know how it happened but its progressively getting worse.
Old 11-30-2008, 06:43 PM
  #1627
fiveoboy01's Avatar
I wouldn't say it's as tweaked as yours, but it's still bent. I'll snap a picture.
EDIT, I was wrong, it's not bent. Must have been the way I was holding the ruler.
Checked my used one(used as in 2 practice tanks and 1.5 qualifying sessions) and it's as bent as yours.
However, I had a radio problem causing me to hit a concrete wall nearly full-tilt. So I'd guess that's why mine's tweaked
Old 11-30-2008, 07:12 PM
  #1628
Originally Posted by vikingen
I run ko servos..
..but that leaves the throttle... what horn, alu or plastic, would you recommend ?
thanks again
KO servos uses horn for JR and Airtronics (all 3 use same horn).
Losi-Runner is offline
Old 11-30-2008, 07:58 PM
  #1629
Timox's Avatar
Regarding the bent chassis issue.
Can you guys tell the difference in performance between a bent chassis and a straight one ?
Dose it make any real difference to the way the car behaves or drives that is noticeable ?
Timox is offline
Old 11-30-2008, 09:00 PM
  #1630
FrankBlack's Avatar
I cant, the car is still fast.
Old 11-30-2008, 09:35 PM
  #1631
Bigkev's Avatar
Australian Mugen sponsored buggy driver Wayne Walker, who won the 08 Australian nationals (MBX5R) and the 08 FEMCA GP Champs (MBX6) has over the weekend has won the buggy off-road New Zealand Nationals. Go Mugen.
Pos Name Details Best Result
1 Wayne WALKER Mugen MBX-6 / Ninja JX 065/00:45:37.039 Final
2 Zac RYAN Hong Nor X2CR / Axe Rossi 063/00:45:14.582 Final
3 Ryan OCONNOR 211 Associated RC8 / OS V-Spec 060/00:45:35.890 Final
Bigkev is offline
Old 11-30-2008, 10:09 PM
  #1632
The new Mugen chassis is significantly lighter than the 5R version, so its not going to be as durable. Also, that flex with the new chassis helps aid in stability, so stiffening the chassis may actually effect performance as opposed to leaving the chassis as is and just replace it when it gets worn. If you allow your chassis to get wore thin, it will bend. I suggest to buy a new chassis if the chassis is worn down. JMHO
Jesse is offline
Old 11-30-2008, 10:58 PM
  #1633
Sam-E's Avatar
Thats how they are out of the box, like I said we checked a brand new chassis out of the box at the LHS and it was like that.
Sam-E is offline
Old 12-01-2008, 08:06 AM
  #1634
RBMike's Avatar
That's not right. I've been running mine since the first weekend it was out & I put a ruller on it last night. Flat as flat can be. You guys seeing this out of the box need to call Mugen.
RBMike is offline
Old 12-01-2008, 09:40 AM
  #1635
r_morney's Avatar
Default New Mbx6 kit
YSK - According to news at "http://rcspecial.com/news/" new MBX6kits are being shipped with some upgrades:
Mugen Updates Newest MBX6 Kits!
November 30, 2008 | By Admin In Buggy, Gas, Products | Comments(0)
It seems there are some changes for the better inside the latest MBX6 kits:
•New radio box cover with screws and no clips
•New front lower A Arms
•News diff joints
•New longer front upper pin
•News springs (softer
•News roll bars (softer
•Same price
r_morney is offline
