Like Tree3Likes
Mugen MBX6
Old 04-19-2012, 08:57 PM
  #16261
jmaxey51's Avatar
Originally Posted by skye b.
Antbody ran the M2C 3 piece engine mount? I ran the King Headz on my Kyosho and it was ok, nothing special though. The set screw deal on the M2C is interesting but I cant find any feedback on it.
i have both, IMHO the M2C is nicer and stronger. my old king headz cracked.
jmaxey51 is offline
Old 04-19-2012, 09:27 PM
  #16262
All I needed to hear. Thanks guys
skye b. is offline
Old 04-20-2012, 03:58 AM
  #16263
curacing2's Avatar
Originally Posted by CanyonCarverR1
I saw from a recent video that my car was bouncing off the ground when landing off big jumps. Is that probablly due to too light of rebound damping? Currently running 450F/400R, both with Mugen tapered pistons, taper facing down.
Do you think its just bouncing from chassis slap?
If your shocks are built with just a little rebound and your ride height is normal and springs are not too stiff try 450F/400R or go up to 500/450, i havn't tried the tapered mugen pistons, someone who's experienced with running them will set you right.
curacing2 is offline
Old 04-20-2012, 05:56 PM
  #16264
Sorry for changing the subject but do most people run the plastic rear chassi brace or the aluminum with the +5 chassi
J
JHN1 is offline
Old 04-20-2012, 08:08 PM
  #16265
MadRussian's Avatar
Plastic
MadRussian is offline
Old 04-21-2012, 12:07 AM
  #16266
BigNasty's Avatar
Pretty much anything m2c makes is bomb-proof. Get it.
BigNasty is offline
Old 04-21-2012, 09:28 PM
  #16267
Ahh, another easy question for you guys. What 'loop' style tank pull works best on the Mugen? Looks like from pics I see, its either the Losi or Durango.
Not a fan of the DE style pull
skye b. is offline
Old 04-21-2012, 09:39 PM
  #16268
megasaxon's Avatar
Trader Rating: 25 (88%+)
i like the Losi one
megasaxon is offline
Old 04-21-2012, 10:45 PM
  #16269
jmaxey51's Avatar
i used to run them but after multiple times it opening the tank lid causing empty tank and busting a tank, decided to go back to the old faithful ziptie.
jmaxey51 is offline
Old 04-23-2012, 01:27 AM
  #16270
hyper9boy's Avatar
Hi. How do I stop my front drivetrain cvd,s from sweeking , when I'm on the gas around a corner they sound gay, I've lubed them it lasts for a few Laps .
HELP PLS
hyper9boy is offline
Old 04-23-2012, 01:35 AM
  #16271
merdith6's Avatar
Default Hayyy
HELP PLS
In my buggy, the front center cvd is the culprit. I like the teflon spray stuff from Lowes. i use it when i rebuild my car too on cvd's and hinge pins and even on a arms to prevent dirt from sticking. It doesn't last forever, but it is easy to hit the cvd's with it...and it dries fast enough...
http://www.lowes.com/pd_213197-39963...d=10151&rpp=24
merdith6 is offline
Old 04-23-2012, 05:23 AM
  #16272
BigNasty's Avatar
Here's what I would try:
1) get some more people to race against. I've found that you can't hear anything over 15 buggies running at the same time.
2) try leaning your engine out until out is screaming...it, too, will drown out the squeak.
Seriously? Try some mobil 1 synthetic grease in that center cvd. Be sure to use that rubber boot too.
BigNasty is offline
Old 04-23-2012, 05:35 AM
  #16273
bill marchant's Avatar
Trader Rating: 274 (100%+)
I found that I had the same problem...I got rid of the mugen boots entirely, since then no more squeak ( only in the front cvd not the rear)
bill marchant is offline
Old 04-23-2012, 06:08 AM
  #16274
hyper9boy's Avatar
I don't beleave it's the centre , it's only when I've got the wheels turned , or turning a corner on power. when going in a straight line it's quite.
Old 04-23-2012, 06:29 AM
  #16275
BigNasty's Avatar
Seriously? If it's built right, you know, like the manual tells you, just drive. I have never heard of this. But then, i'm moving too fast to be able to tell whether the front or the back is squeaking. Maybe you are used to a 10th scale car. 8th scale cars make a lot of drive train noise. Even the electrics. That's why I hate e buggy. I'd rather hear the engine than the drive train.
Or you could do what my girlfriend advises...sell that shit and take up scrap booking
BigNasty is offline
