Like Tree3Likes
Mugen MBX6
Old 11-23-2008, 11:07 AM
  #1576
doubletap's Avatar
Trader Rating: 10 (92%+)
which pipe is good for this engine(B01)beside MUGEN SEIKI? is this good with long or short pipes such as Team Factory & Thunder tiger pipe? thanks , I think I'm in the wrong thread... it might be right since I saw NINJA engine atop..
pardon... thanks.
doubletap is offline
Old 11-23-2008, 02:33 PM
  #1577
FrankBlack's Avatar
Originally Posted by slidejob26
I have been racing the X6 for about a month now with great results. Last night I broke a bushing in the upper hinge pin holder. The holder itself was ok, just the bushing busted out. Is this a result of the hinge pins being a little short as mentioned earlier in this thread? I havent had any probs with it till now.
any thoughts?
thanx
Have a close look at your brace, i spat a pin out and the brace looked ok, the bush was gone also, i had a closer look at the brace and it had a crack in it, was very hard to notice. Using the alum brace and the losi hinge pins cut to 46mm and i cant see how it can ever happen again.
FrankBlack is offline
Old 11-23-2008, 02:46 PM
  #1578
slidejob26's Avatar
I'll do that!
slidejob26 is offline
Old 11-23-2008, 03:46 PM
  #1579
jpz_67's Avatar
Trader Rating: 57 (100%+)
+1, that is exactly what happened to my buggy. Popped the pin out, the bushing split, the block appeared to be fine and then I looked real close and saw a hairline crack. Glad mugen is making a factory hop up option for this piece.
jpz_67 is offline
Old 11-23-2008, 05:20 PM
  #1580
Timox's Avatar
any thoughts?
thanx
Could be a combination of things happening. The upper pins being 1mm or 2mm too short and the holder having 1mm or 2mm of flex all adds up.
The new alloy holder seems like it would fix it even with the stock pins i would think.
Timox is offline
Old 11-23-2008, 05:51 PM
  #1581
gasman517's Avatar
I was taking the front of the buggy apart today and noticed that the pinion has cut a groove in the diff case. the mesh as good but the pinion is very close to the case. Any thoughts
gasman517 is offline
Old 11-23-2008, 06:15 PM
  #1582
Trader Rating: 14 (100%+)
question for anyone using the stock pistons in the shocks, i have to screw the spring collar on the shocks farther down the shock to get the ride height level, if i go by the setup up sheet with the kit, the car sits to low, how many mm's are you screwing down on your shocks, front and rear?
jlo
jlo8864 is offline
  #1583
jpz_67's Avatar
You didnt shim the pinion did you? I would think that is the only way that could happen.
jpz_67 is offline
Old 11-23-2008, 06:17 PM
  #1584
jpz_67's Avatar
jlo
Jlo, off the top of my head I am not sure how many mm's of preload I have but just turn the collars until your ride height is rear arms level, and front arms slightly above level. This is a good starting point.
jpz_67 is offline
Old 11-23-2008, 06:19 PM
  #1585
gasman517's Avatar
My kid built the front i just asked him and it turns out there is a shim in there tks
Old 11-23-2008, 06:24 PM
  #1586
jpz_67's Avatar
Anytime. The only shimming that may be required is a shim on either side of the ring gear, and depending on the fit inside the bulkhead you may not need any at all. Good luck and enjoy the car.
jpz_67 is offline
Old 11-23-2008, 06:27 PM
  #1587
gasman517's Avatar
He loves the car ! he had a losi before and when he got the mugen he picked up a whole lap the first time out
Old 11-24-2008, 03:32 AM
  #1588
Bigkev's Avatar
A mate of mine in the local hobby shop the other day found some 4mm x 46mm hinge pin shafts made by HPI. These fit perfect and save you cutting Losi hinge pins. Also make sure you use the correct plastic bushing inserts, use the ones without the hole in the other end of them.
HPI 4mm x 46mm Shafts - http://www.amainhobbies.com/product_...oducts_id/6342
Bigkev is offline
Old 11-25-2008, 06:46 PM
  #1589
allan42r's Avatar
had my car down to 3250 grams pulled the lipo out and put in the nimh which was 40 grams heavier and the car was better. the springs that are avail. right now are too stiff for that light of a car. we have three more softer rates and a 2.6 rear bar comiing.
allan42r is offline
Old 11-26-2008, 12:33 AM
  #1590
just wonder...does the mbx6's center cvd's fit in the mbx5?
chumanji is offline
