Like Tree3Likes
Mugen MBX6
Old 03-15-2012, 06:26 AM
  #15871
Motorman007's Avatar
Trader Rating: 89 (100%+)
Motorman007 is offline
Old 03-15-2012, 08:09 AM
  #15872
chad bradley's Avatar
Front Lower arm spacer is behind the front arm (pushing the arm forward)
Front Upper arm spacers (caster)-the thinnest of the two spacers is between the front tower and upper arm, the rest of the spacers are on the back side. Depending on the track size/layout and surface, I play with the caster position alot. If I want the cars steering more responsive, use more clips behind the upper front arm (usually on loose small tracks or lots of tight turns)
Rear lower arm spacer is in front of the rear arm
Wheel hubs
Front....+1mm
Rear.....+2mm
I think using the +1mm will be better in the rear, however the +2mm at the nitro challenge was very good for that high speed and large track. Most of the time making the back end wider can make the car less reactive and looser. Wide is good if there is lots of traction and a big track to make the car stable.
If you want more overall steering, try using the stock 0 offset front wheel hub but add another 1mm washer on the pivot ball on each side. The longer you can make the front arm the more steering you will usually gain (using wider hexes doesnt make your a-arm any longer, just the width). If you want to take steering out and make the car easy to drive, take all the 1mm washers out (the washer between the pivot ball and front arm) and use the 2mm wheel hex. Make sure when adding or taking away these washers you have to re adjust your steering links and the upper pivot ball to get back the correct camber
chad bradley is offline
Old 03-15-2012, 08:29 AM
  #15873
front sway bar
2.3 is stock for the front end. At nitro challenge I started off practice and the first round of qual. with the 2.3 front bar. Round 1 the track was pretty dry and had alot of traction. For round 2 I found a 2.5 front bar (If I had a 2.4 I think that would of been best), there was a huge difference going from 2.3 to 2.5, the 2.5 took away alot of steering but made the car extreamly easy to drive (round 2 was my best finish for a round). I was a little worried about the steering I lost with the 2.5 so I put the 2.3 back on and mounted the link a few mm from the end of the bar.
The link that set screws to the sway bar is an adjustment as well, the closer you mount the link on sway bar to the end the softer the bar will be and the further away from the end the stiffer the bar will work.
Old 03-15-2012, 08:32 AM
  #15874
Some new Jammin towers for the 6R
http://jamminproducts.com/BuyMugen.html
Old 03-15-2012, 09:17 AM
  #15875
Nice.
brian kadow is offline
Old 03-15-2012, 10:11 AM
  #15876
Thank you very much sir.
Old 03-15-2012, 10:26 AM
  #15877
on my build the alum. holders stick out some. 2or 4 threads showing
and the bottom has like 5-7 threads showing.
what did it do wrong? do they need to break in.
I read did them like 3 times to make sure I did not cross thread the plastic.
ALSO, WHO MAKE THESE SCREWS
Old 03-15-2012, 11:07 AM
  #15878
Someone got a little crazy with there Mill.
Old 03-15-2012, 11:11 AM
  #15879
jpz_67's Avatar
Trader Rating: 57 (100%+)
Thats all a bunch of custom items for when Reno Savoya ran for mugen.
jpz_67 is offline
Old 03-15-2012, 11:16 AM
  #15880
Thanx John.
He must have made more, b.c. some of the guys over the pond had some of the screws and stuff on their buggy too.
I will take out the balls cover and try and see if the balls are pushed all the way to the end.
Old 03-15-2012, 12:42 PM
  #15881
Trader Rating: 75 (100%+)
Anyone looking to get rid of a mbx6 and Eco shoot me a pm..
Preciate it
gixxer420 is offline
Old 03-15-2012, 01:09 PM
  #15882
BigNasty's Avatar
Originally Posted by slow coach
just to clarify thats 15mm inboard of the most layed down stock truggy hole, how does that position line up on the Buggy tower or is it somewhere inbetween
it's definitely somewhere in between. if you look at the new m2c tower, it has both sets of holes and they are in completely different parts of the tower. i believe they also have the 15mm inboard position. i have 9mm, 11mm and 15mm holes drilled inboard of the inner most STOCK truggy location, along the same plane. definitely worth a try.
BigNasty is offline
Old 03-15-2012, 02:24 PM
  #15883
Ross71's Avatar
Originally Posted by Motorman007
Thanx John.
You will probably find that its the plastic caps that fit over the end of the pivot balls not allowing the nut to go in correctly.
Ross71 is offline
Old 03-15-2012, 02:33 PM
  #15884
Company Representative
JoeNolasco's Avatar
For anyone that is interested in the FTW Night Fox Body for the MBX6R checkout our vendor forum here on RCTECH! Mega Blowout!
http://www.rctech.net/forum/p1-hobbi...-new-post.html
JoeNolasco is offline
Old 03-15-2012, 02:37 PM
  #15885
am
I think Renos dad made alle the Mugen eqipment for him. When he stopped using his father as a meckanik, all the nice prpping on his var also disapeard..
am is offline
