Like Tree3Likes
Mugen MBX6
Old 11-15-2008, 08:06 AM
  #1516
Davidka's Avatar
Trader Rating: 86 (100%+)
Originally Posted by muaythai
hi guys just checking whether everyone had put oil in the bladder prior to putting the silicon oil. i only knew about this thenique 'after 'filling those bladders with the 450wt.
now all set up so feels its too late. the shocks are full of oil. will it be detrimental to the life of those pistons??
You don't want to fill the bladders with oil (I assume you mean the space behind the bladder in the cap). The oil is not compressible, the air is and that is the purpose of the bladder, to allow for the change of volume inside the shock when the shaft displaces oil.
Davidka is offline
Old 11-15-2008, 05:05 PM
  #1517
tony montana's Avatar
Trader Rating: 76 (100%+)
what droop setting are you guys running. I seen on scott hughes's setup he runs like 21mm front and 19 rear? Oska I seen at mugens setup sheets he is running 12mm front and rear. Also where exactly onthe front hub do I measure it from? Do I just put a wheel in the middle of the chassis and then measure
tony montana is offline
Old 11-15-2008, 06:07 PM
  #1518
moeman's Avatar
Trader Rating: 26 (100%+)
I too think the 450 is way too heavy, going to try the 25-30 wt.
moeman is offline
Old 11-15-2008, 07:48 PM
  #1519
I run 400 front 350 rear mugen oil. seems to work great.
Jesse is offline
Old 11-15-2008, 07:53 PM
  #1520
Originally Posted by tony montana
what in the world are most of you using to adjust the turnbuckles on the car with? It takes forever to adjust them using a small L shaped allen wrench?
buy yourself a snap on pick set, the straight pick and the "L" shaped pic seem to work great.
Jesse is offline
Old 11-15-2008, 08:09 PM
  #1521
Originally Posted by ilmugenracer
bend the header so it fits. you can use a vice or your bare hands. be careful, its easier than you think and you dont want to go too far.
+1, or use 2 wooden dowells that you can get from ace hardware or Home depot...this is so you wont scratch your header. agree on the fact to be careful not to go too far, it is pretty easy to bend.
But i am able to fit a JP3 with zero issues, forgot to add, but the buggy is awesome!
the way everybody stepped up their game is simply awesome. it wasnt even a question if mugen was able to stand up to such competition...
Jesse is offline
Old 11-16-2008, 05:41 AM
  #1522
Bigkev's Avatar
Default Droop settings
Tony, the droop measurement is shown on your setup sheet as 'Rebound Stop'. The setup sheet shows a bare wheel rim under the chassis, then droop is measured from ground level to base of PBS knuckle &/or lowest end point of rear suspension arm.
A lot of guy's do it more accurately buy putting chassis ride height blocks under there chassis at there desired ride height (front & rear) and then measure there droop (rebound stop).
Currently got my MBX6 droop at 12mm both ends, but can't comment on handling results yet, haven't had much track time.
Cheers Kev
Bigkev is offline
Old 11-16-2008, 06:00 AM
  #1523
Trader Rating: 68 (100%+)
I use the hook tool that is pictured on the right. Works great on the turnbuckles. I would suggest buying a quality brand name as I have found that the cheaper ones will bend or break.
Greg B is offline
Old 11-16-2008, 07:46 AM
  #1524
fiveoboy01's Avatar
Trader Rating: 30 (100%+)
Can you post a picture? Mine doesn't look like it's going to go in very well without the header being all crooked...
fiveoboy01 is offline
Old 11-16-2008, 10:20 AM
  #1525
ira
ira's Avatar
Trader Rating: 18 (100%+)
Originally Posted by infanterene
I put it together right. I actually know of 2 others so it is rare but I am not the only one.
Is it the front or rear diff?
ira is offline
Old 11-16-2008, 10:34 AM
  #1526
fianlly got to run some fuel threw my x6 today. Im glad I made the switch. Car jumps awesome and had great accleration. Couple of things I may need some help with thou. When the track was damp it was hooked. But when it started drying out in spots I could tell it was getting loose. Im running the stock setup up except 3-5-2 diffs and middle hole on the towers for the shocks. Im also running full droop. I dont wanna loose any steering thou. Oh yeah Im running 2.5 rear toe.
Old 11-16-2008, 12:25 PM
  #1527
Trader Rating: 22 (100%+)
Is the clutch flywheel on the mbx6 any different from the mbx5/r?
I want to put the fioroni clutch on it when i pick up my MBX6:
http://www.amainhobbies.com/product_...ducts_id/13236
has anyone tried this clutch on their ride?
phixd is offline
Old 11-16-2008, 12:27 PM
  #1528
imaxx21's Avatar
im using the same aftermarket clutch i used on the 5R on my 6...
imaxx21 is offline
Old 11-16-2008, 12:28 PM
  #1529
fiveoboy01's Avatar
Somebody already answered it when you asked before, but yep they're the same.
  #1530
jaylude22's Avatar
Trader Rating: 93 (99%+)
The clutch, flywheel and clutch bell are the same for the 5r and 6.
jaylude22 is offline
