Team Associated 1/8 scale Truggy Info and Tips >
Old 04-30-2010, 08:34 AM
  #1366
Teufel Racing's Avatar
Trader Rating: 30 (100%+)
I'm not awear of any after market CV's for the truggy,
There might be some, but they could be worse than the stock ones. Best I can say is to measure them and see if another Mfg. (Losi, Mugen, for example) had some of the same length or that would be close enough to use.
Teufel Racing is offline
Old 04-30-2010, 09:04 AM
  #1367
Tbizz's Avatar
Originally Posted by retired rc guy
Hey all
One quick question.
1 Are there two versions of the RC8B factory team, an older version and an updated one with running production changes/improvements
Try posting this in the RC8B forum. All I know is there was the original RC8 then the updated RC8B came later on.
Tbizz is offline
Old 04-30-2010, 09:58 AM
  #1368
There is only one RC8B. I think they are always fine tuning.
Chris Reilly is offline
Old 04-30-2010, 10:58 AM
  #1369
aray's Avatar
http://www.amainhobbies.com/product_...-CE-Conversion
dang wish that was the deal a month ago, le + ce parts
aray is offline
Old 05-09-2010, 07:25 PM
  #1370
pistolpete1982's Avatar
Trader Rating: 26 (100%+)
Hey guys, I got an RC8T RTR about 2 months ago, changed out the diff oil to 7/10/5, put an aluminum clutch from impulse-rc, and also changed out the bearings on the clutch bell, ran it this weekend and it ran alot better than the stock setup. My question is what does moving the battery to the front do? I've been reading alittle bit about it but haven't read what does it do or whats it good for.
pistolpete1982 is offline
Old 05-09-2010, 07:39 PM
  #1371
Midnight's Avatar
Trader Rating: 87 (100%+)
IMO it helps improve overall steering.
Midnight is offline
Old 05-09-2010, 07:48 PM
  #1372
Is it because of the weight? I don't see how much extra weight your adding to the front.
Old 05-09-2010, 09:39 PM
  #1373
RUNNINONMT's Avatar
Default done!!!!! :)
finished my new ride
RUNNINONMT is offline
Old 05-09-2010, 09:47 PM
  #1374
Pistol,
The weight is the reason. The old style NiMh pasck were/are pretty heavy, so moving the weight forward help with the steering. I have an old pack in the front of mine with a LiPo in the stock location. Seems to work pretty well, I might get around to weighing the packs so I can add a little more weight forward to rebalance things.
Old 05-14-2010, 04:05 PM
  #1375
Tbizz's Avatar
Not only the slight shift of weigh but my main reason for getting it was because the original battery/reciever box was a mess with everything in there. The extra servo wire plus the battery and RX squeezed in there made me want it. Moving the battery up front let me servo tape the reciever down and neatly arrrange the wiring.
On that note the bad part is you have to take screws out to replace the battery.
My $.02
Tbizz is offline
Old 05-19-2010, 05:18 PM
  #1376
Trader Rating: 15 (100%+)
Outdoor season is in full swing any new setups? (shane)?
I am just running the out of the box CE setup. cant complain really had some great results, but think it can be faster. I think the rear is a little stiff. going to try some smaller holed pistones with lighter oil.
drt_racer5 is offline
Old 05-19-2010, 06:28 PM
  #1377
Shane Racer's Avatar
The only thing I changed for outdoor is 1/2wt thicker in the rear and went to the kit positions for the shock angles.
Shane Racer is offline
Old 05-19-2010, 07:14 PM
  #1378
Midnight's Avatar
Are u still running losi springs.
Midnight is offline
Old 05-19-2010, 08:13 PM
  #1379
yes
Old 05-20-2010, 07:24 AM
  #1380
jpz_67's Avatar
Trader Rating: 57 (100%+)
So has anyone in here switched from the losi to the rc8t ce? Just wondering as I have driven an 8t 2.0 and thought it was dialed, mainly in the steering department. Just wondering what peoples thoughts were on the rc8t's steering on tighter tracks.
jpz_67 is offline
