Team Associated 1/8 scale Truggy Info and Tips >
Old 01-16-2010, 07:36 AM
  #1036
Midnight's Avatar
Trader Rating: 87 (100%+)
Originally Posted by slash bash
yes the bags were done in order. as per instructions. called AE just like i did on tuesday about the input cup that was mishaped. and i got the same answer as before they will ship a new one to me. Thats nice but still have to wait another week or two for the part. cali to fla shipped usps just sucks.
oh well they could have just said tuff send us the old one and we will send you a new one after inspection. but they didnt. Oh well good luck on your ce kit i hope you dont have any of these problems. and dont get in a hurry putting the ft hub assy together. its kinda a pain in the arse.
thanks
Sorry to hear that bro. Do they have some at ur local hobby shop. My shop would give guys the part if the kit came messed up and when the new part came they would just put it on the wall.
Midnight is offline
Old 01-16-2010, 09:41 AM
  #1037
So I got 350 credit on amain I haven't run lipo and thinking about running a lipo servos and reciever what do you guys recomend charger and battery quality that will last a while
thanks
Little E
Little E is offline
Old 01-16-2010, 02:34 PM
  #1038
Midnight's Avatar
Hey bro. What tires came with ur ce truck
Midnight is offline
Old 01-16-2010, 03:04 PM
  #1039
My RC8T CE came with JCONCEPTS Crosshairs and Associated Tires. I actually have them up for sale right now if you want them....
teambretzke is offline
Old 01-16-2010, 03:44 PM
  #1040
Midnight's Avatar
Thanks but I dont think I would need 2 sets.
Midnight is offline
Old 01-16-2010, 04:24 PM
  #1041
Mikey Hudson's Avatar
thanks
Little E
I run the reedy lipo packs (part# 631) and regulator (part# 636) with no problems.
As for a charger, right now I have a hyperion charger (EOS 0606i).
Mikey Hudson is offline
Old 01-16-2010, 09:01 PM
  #1042
Midnight's Avatar
What compound are they? Are they going to work good on a clay moist high traction track.
Midnight is offline
Old 01-17-2010, 05:35 PM
  #1043
Midnight's Avatar
Ok, as Ive said before, my 8t ce will be here around thur and I plan to put Shanes setup on it. Just have a few questions like rear ride height, wheel hex, battery position, I think the diff is 777, wing mount, gearing. Thanks guys. Also which rear shock fluid can I run instead of ae 25. All I have is losi shock oil. Also my losi shock springs want be in by the time I build, but I have all of ae springs, which one can I use for now. Thanks in advance. I will be running a +4 until I sale my buggy and get a toro.
Midnight is offline
Old 01-17-2010, 06:06 PM
  #1044
Midnight's Avatar
Also do I need losi truggy springs front black and rear grey?
Midnight is offline
Old 01-17-2010, 06:21 PM
  #1045
Rear ride height - 43mm
Wheel Hex - I would assume the narrow hexes
Battery Position - Most likely the forward battery position
Diffs - 7,7,7
Wing mount - low angle and forward position (25mm is normal for this)
Gearing - 14/52
Shock oil - AE 25 is similar to Losi 27.5
Springs - You could stick with the black fronts (harder than Losi blacks) and bronze rears (they should be fairly identical spring rates)
Most of this I got from Shane's setup sheet he sent me. If anythig is wrong please correct me.
  #1046
That is correct
Old 01-17-2010, 07:06 PM
  #1047
j_blaze14's Avatar
Trader Rating: 34 (100%+)
what is "shanes setup"? is that a track?
j_blaze14 is offline
Old 01-17-2010, 07:36 PM
  #1048
It is an actual setup for the truggy and buggy. This is what was posted in the buggy thread.
Originally Posted by Shane Racer
All right guys. Here is the setups for buggy and truggy. Anyone that tried them at Leisure hours last weekend can confirm that they are very good. The only thing that does not thrill me is you have to use losi springs. But hey,there just springs. I'll be at my home track this weekend where i can actually try it with AE silvers. I will be able to compare lap times to see if we can run AE springs and accomplish the same feel.
Truggy:
Front:
silver bar
#3 on tower(shocks)
middle steering rack
1 dot hinge pin bushing
-2 camber
18 deg. caster
A on caster block
inside on arm
2 out toe
38mm ride height
1 dot kickup
Front shocks:
Spring-losi black
fluid-losi 35wt
piston-(1.3 x 6 hole)
length-full
1/2 rebound
rear:
gold bar
medium wheelbase
#3 tower(shocks)
-2 camber
2.5 toe
lower hole in rear hub
#2 camber(tower)
short link in new hubs
inside on arms
2 deg ant-squat
Rear shocks:
Spring-losi grey
fluid-AE 25wt
piston-(1.2 x 6 hole)
length- full
1/2 rebound
Buggy:
Front:
silver bar
#7 tower
1dot on everything
-2 camber
18 deg. caster
2 deg toe out
A-caster block
inside on arm
29mm
Front shocks:
spring-losi silver
fluid-losi 35wt
piston-(1.4 x 6 hole)
length- full
1/2 rebound
Rear:
silver bar
medium wheelbase
#9 on tower
-2 camber
1 dot D plate
B on hubs
#3 inside on tower
inside on arms
1 dot anti-squat(2 deg.)
30mm
rear shocks:
spring-losi green
fluid-losi 20wt
piston-(1.2 x 6)
length-1mm internal
1/2 rebound
30mm
You have to use two spring adjusters in the front and the rear of the buggy to get ride height.
Old 01-17-2010, 09:29 PM
  #1049
TXRC8racer's Avatar
Trader Rating: 19 (100%+)
man when are the new towers comming out??? On ebay tonight I done a little shopping and was watching the new CE towers go for 60+ dollars a piece..Did buy the CE chassis on ebay which i am assuming its the same as the FT chassis for 29$
TXRC8racer is offline
Old 01-18-2010, 10:27 PM
  #1050
Midnight's Avatar
Diffs - 7,7,7
Gearing - 14/52
Just wanted to say thanks bro.
Midnight is offline
