Team Associated 1/8 scale Truggy Info and Tips >
Old 12-17-2009, 03:21 AM
  #946
Default proline "bulldog" rc8t body
sorry if i ask stupid question here cause im placing an order from amhbbs ,do i need to order the body mount adapter or just the body shell proline bulldog rc8t ,i understand if you want the jconcepts punisher you need the (blue) body mount adapter .............when i look at ryan c. rc8t its hard to tell,pls. let me know thks
mbx5rcr34 is offline
Old 12-17-2009, 04:07 AM
  #947
Mr.Mellow's Avatar
Default bulldog....
No, you do not need an adapter. You have to drill out the shock tower with a template that comes with the body, and then use the existing body mounts. This body looks SO kick a$$!!! Ran mine a couple of weeks ago and does make a difference. I'm not sure if it's perception, but it just felt better.Enjoy .
Mr.Mellow is offline
Old 12-17-2009, 04:14 AM
  #948
Trader Rating: 264 (100%+)
Buy the adapter. Much easier!!
Fred Perkins is offline
Old 12-17-2009, 10:47 AM
  #949
Originally Posted by Steebo
Anyone here use the BCE Speed Chassis for the RC8T? What does it do for the truck?
I got one when they first came out. Quality is good, the only problem I have is that the hole where the D plate goes into the chassis is not big enough. I had to trim the D plate set pin on both the KingHead and the Associated plates to make it work. Maybe they have fixed that by now but it sure is little bit of a pain in the ass.
When I got the BCE chassis I also went to the RTR plastic chassis braces. I honestly cant tell you if it improved the truck much, but it does have a cool copper color. Lol.. If you got the money go for it, if you think it will shave off seconds from your lap time probably not…
Norbert50p is offline
Old 12-17-2009, 01:46 PM
  #950
rider313's Avatar
Trader Rating: 94 (100%+)
I used the proline template on my Jconcepts punisher body and it worked flawlessly. IMP it looks better than the blue mount. Plus its four 1/8 holes cant get easier than that.
rider313 is offline
Old 12-22-2009, 12:30 AM
  #951
kenshinmd's Avatar
Hi guys, just ordered an RC8T CE from amain and will probably reach my place next week, it is my first time running an associated 8th scale, any issues to watch out for, parts that I need to stock up. Ill be running it in a pretty blown out track with lots of bumps and doesn't have any big jumps what setup would you advice, should I go 7-7-7 or 7-10-3 for the diffs? Thank you very much in advance.
kenshinmd is offline
Old 12-22-2009, 12:35 AM
  #952
Bigedmond's Avatar
Trader Rating: 18 (100%+)
777. Gives the truggy a nice neutral feel that you can push for days. If you find that the rear end likes to wash out, drop it down to 5 in the rear.
Bigedmond is offline
Old 12-22-2009, 03:37 AM
  #953
kenshinmd's Avatar
Thank you for the advice, any parts that have issues so far? so that I can get some spares before next years race season begin
Old 12-22-2009, 08:28 AM
  #954
handyman77's Avatar
Trader Rating: 32 (100%+)
hub carriers for sure, cvd's and hinge pins
handyman77 is offline
Old 12-22-2009, 06:00 PM
  #955
suryo88's Avatar
Trader Rating: 33 (100%+)
front and rear arm, steering rod end, shock end, shock shaft
suryo88 is offline
Old 12-23-2009, 10:10 AM
  #956
GASMAN123's Avatar
Hey guys I need some opinions on upgrading my truggy ? I have FT RC8T but am looking at doing some upgrades like the CE version! Should I just buy the CE or can I just buy some upgrade parts and go from there? I raced this truck for a year and really its still in good shape I need a chassis but other than that its held up well ! What should I do ? Buy a Bce and upgrades or just get a whole new truck ? Thanks for any input
GASMAN123 is offline
Old 12-23-2009, 01:04 PM
  #957
suryo88's Avatar
get a new CE kit, upgrade gonna cost you $200 plus
suryo88 is offline
Old 12-24-2009, 11:36 AM
  #958
Trader Rating: 17 (95%+)
RC8T CE for sale in for sale section NIB!! $450 shipped
koreanassasom is offline
Old 12-24-2009, 12:49 PM
  #959
suryo88's Avatar
YGPM
suryo88 is offline
Old 12-24-2009, 09:55 PM
  #960
Steebo's Avatar
Trader Rating: 17 (100%+)
Is there still a tank issue? If so, what is a better tank MBX5T or the D8T? Or is there a better tank than those two out there?
Steebo is offline
