Team Associated 1/8 scale Truggy Info and Tips >
Old 12-01-2009, 04:18 PM
  #901
lethalleigh29's Avatar
Originally Posted by captaindemo17
anyone running the narrow wheel hubs on their truck? how do you like them and are you running both front and rear? i am buying some but would like some input first. thanks in advance
i am running them on the front only it increases turning slightly to make my truck more responsive IMO..
lethalleigh29 is offline
Old 12-04-2009, 08:42 AM
  #902
rider313's Avatar
Trader Rating: 94 (100%+)
were do you guys musure for ride hight front and back. do you go to the flat spot or the tip of the kick up part by the bumper?
rider313 is offline
Old 12-04-2009, 09:03 AM
  #903
cary's Avatar
Trader Rating: 67 (100%+)
on the flat part of the chassis
cary is offline
Old 12-06-2009, 04:48 AM
  #904
j_blaze14's Avatar
Trader Rating: 34 (100%+)
Originally Posted by mgtmadness2007
I have maybe 10 runs (if that much)on my RC8T FT and I noticed the rear, front arm holes hallowed out in an oval and rear holes of the rear arm still circular. I replaced the rear arms and if it happens to my RC8B and again to my RC8T looks like I may sell them.
Waste of money if I would have to replace the arms after every 10 runs or less.
you don't "have " to replace them until they break. plastic arms with metal hinge pins in 1/8th scale off-road racing will produce slop 100% of the time, in any car.
j_blaze14 is offline
Old 12-06-2009, 05:00 AM
  #905
trying to dial push out of my truggy on exit of corners. on power
my diffs are set at 7 10 3
shocks are 50F 40R
Any info will be great.
everything else is stock track is rather bumpy with lots of loam.
Old 12-06-2009, 11:20 PM
  #906
MBR52's Avatar
Trader Rating: 8 (91%+)
shocks are 50F 40R
Leigh, i had the same prob here, all i have done is gone 777 in diffs, nd also put the FT chassis braces in nd now it turns great
MBR52 is offline
Old 12-07-2009, 04:51 AM
  #907
strodedawg's Avatar
Trader Rating: 81 (100%+)
i just backordered the new towers from my lhs, do i need new inserts for the front tower? if so anyone know a part #. also is that grill and headlight decal sheet available yet? if so from where
thanks
strodedawg is offline
Old 12-08-2009, 06:52 AM
  #908
GASMAN123's Avatar
Originally Posted by jneg
The oil is comming out from the top or the bottom seals? If it is comming from the top its either the top is not screwed completly or the bladder is damaged or not seated correctly. If its comming from the bottom then rebuilt your shocks with new seals but like the guys said earlier take a close look at the shaft for bending or scratches. If it has either then replace the shaft.
Hey I was at a race this weekend and after a few laps I noticed my engine would die out when I would refuel the truck ? Is it the gas tank lid or ? I checked the fuel lines and no holes or cuts ? Help
GASMAN123 is offline
Old 12-08-2009, 06:58 AM
  #909
Shane Racer's Avatar
Your bottom is probably to rich. If your tune seems good then you might want to richen up the top and lean the bottom.
Shane Racer is offline
Old 12-08-2009, 07:44 AM
  #910
Frank L's Avatar
Trader Rating: 148 (100%+)
If the tune is good then all that's left is the tank and fuel line. I would start by replacing the fuel line it's cheap and then if it still does it change the tank. I have had new tanks have problems from the start. There's nothing else that can cause flame out issues.
Frank L is offline
Old 12-08-2009, 07:52 AM
  #911
GASMAN123's Avatar
So I had my truggy since July 2008 and ran the crap out of it ! When do you guys know when its time for a new truggy ? My chassis is still good and most parts hold up well but when is it time for a new one ?
Old 12-08-2009, 07:53 AM
  #912
NitroFreakManHo's Avatar
+ 1 I agree with that ( assuming you have no air leaks or clutch issues )
NitroFreakManHo is offline
Old 12-08-2009, 01:49 PM
  #913
rider313's Avatar
are you running your tank almost dry when you pit? and how full do you fill it? i have had this issue befor cuz i was running it almost dry and my pitguy would over flow the tank when fueling so when the lid slapped down it would push exrta fuel threw it causing it to stall.
rider313 is offline
Old 12-09-2009, 06:06 AM
  #914
Potoczak's Avatar
Trader Rating: 120 (100%+)
Does anybody have there hands on the championship edition rc8t, i back ordered mine from stormer hobbies but no luck yet. I just cant wait to get it.
Has anybody done electric conversions on the rc8t. That is my plan!!!!!
Potoczak is offline
Old 12-09-2009, 06:32 AM
  #915
JoeyTheRocket's Avatar
They just started shipping them out last week to the distributors.
JoeyTheRocket is offline
