Team Associated 1/8 scale Truggy Info and Tips
#886
any proline LPR tire will fit into rc8t stock wheel
#887
On page 39 there is a picture of a fuel tank. Anyone knows what it is? I just bought the Jammin X2T tank since that is what someone said it was but it doesn’t fit. (unless people are re-drilling the post locations)
#888
I'm still looking for that video on how to properly set up your sway bars... appreciate any help you guys can provide?
#889
yes you have to drill another hole for front post to instal jammin x2 fuel tank.
#890
hey guy did my first race ever this weekend. I won the sportsman class by 22 seconds.
With a bad throttle servo so my brake was only aplying half way. I was running the stock set up since it was my first race i was just trying to get consistant laps. My fastest was a 31.314 and average was around 32.7. the pros were running 28.34 consistantly, i think with a better set up plus the steering mod i will be able to get into high 20s for lap times also. i plan to run the mafield nitro pit set up. what do you guys think.
#891
has any noticed the right front control arm hinge pin holes are bowed and if you ream them out there to big,as in they have a lot of slop. the left side has about .001 of clearance and the right after reaming them are about .051. just wondering if anyone has noticed this but i have gone through three sets. one was out of the le kit,one was sent by the ae factory and one was purchased through the lhs.
please post up.
please post up.
#892
please post up.
please post up.
Waste of money if I would have to replace the arms after every 10 runs or less.
#894
Agreed^^ A little bit of slop in the suspension arms stops things from getting bound up in rough conditions and also lowers wear and tear as theres no binding with every movement..
If anyone thinks slop is to bad, i hate to say this but have a look at the Losi 8ight`s they have enormous amounts of slop and yet they seem to handle better that way...
#898
#899
The holes for my rear a-arm are as follows. front hole in a-arm(one closest to center of chassis) is 0 (or oval shape) where I was able to fit a 1.5 mm allen wrench tip in around the hinge pin. and the other side is O= perfectly circular.
It was not back and forth slop.
