Team Associated 1/8 scale Truggy Info and Tips
#871
How's your spring and collar on the steering rack ? Has it backed off ?
#872
#873
I need to check it on my buggy.
I was going to say check your clutch and front brake. There are a few things that can do it. It's really a guess sometimes. Not seeing it. I think I'm better at helping others than myself sometimes.
#875
Servo saver is fine as far as i know, i will double check it but the wheels seem to be turning lock to lock no dramas out there on the track from what i can see, droop settings are the same as stock, i wasnt keen to change them as the track was a bit bumpy and blown out by the end of the event, we did lower the suspension about 2 full turns on each collar which did help slightly for the main but it still was very hard work to drive, was the longest 30 minute main a person could drive trying to get the thing to steer without hitting the outside pipes all the time...
When i get a chance to tear it down and do the routine maintenance on it i will double check the servo saver, thats a good tip that could be a simple solution if its not right.
Thanks.
Thanks.
#876
When is the championship edition supposed to be available to the public!!!!!! Need to buy one NOW>>>>
#877
#881
whats up shane, i am done for the year and have a lot to learn in the off season. i borrowed a set of tires from a fellow racer and wow what a diffrence they make. they were small hole shots. i can not believe it makes that much of a diffrence. i went from the last postion qualifing to second in the main. i will be investing in tires
#882
#884
