Team Associated 1/8 scale Truggy Info and Tips >
Old 11-04-2009, 03:26 PM
  #796
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Originally Posted by GASMAN123
Hey guys I have a dumb question my left front shock lost all the oil in it. Now should I just refill it or ? I don't know what is the proper thing to do ? Thanks
I would rebuild the shock with new seals.
Bigedmond is offline
Old 11-04-2009, 03:31 PM
  #797
rider313's Avatar
Trader Rating: 94 (100%+)
i would also check the shafts to make sure they are not bent or have any burs on them.
rider313 is offline
Old 11-04-2009, 04:52 PM
  #798
NitroFreakManHo's Avatar
Was the shock bladder seated properly, or torn?
NitroFreakManHo is offline
Old 11-05-2009, 06:48 AM
  #799
GASMAN123's Avatar
Exclamation
I'm going to check today when I get out of work ? How do I know its seated correctly ? I replaced the bladder like the book states but I also might of done it wrong ill redo it again and if the oil keeps coming out ill rebuild the whole shock thanks for the input !
GASMAN123 is offline
Old 11-05-2009, 02:44 PM
  #800
The oil is comming out from the top or the bottom seals? If it is comming from the top its either the top is not screwed completly or the bladder is damaged or not seated correctly. If its comming from the bottom then rebuilt your shocks with new seals but like the guys said earlier take a close look at the shaft for bending or scratches. If it has either then replace the shaft.
jneg is offline
Old 11-06-2009, 04:52 AM
  #801
Default proline "bulldog" rc8t body
when this body gnna be available ?? do i need to get the body mount adapter too?? for this new bulldog body ...........i would like to get this than the jconcepts punisher ,what you guys think
mbx5rcr34 is offline
Old 11-06-2009, 09:58 AM
  #802
race raider's Avatar
Trader Rating: 38 (100%+)
It looks like you are going to need a adapter
race raider is offline
Old 11-06-2009, 01:29 PM
  #803
GASMAN123's Avatar
Cool
Its coming from the top so ill replace the bladder and go from there ? Thanks guys for all the input !
Old 11-07-2009, 08:03 PM
  #804
flippz's Avatar
hey guys i ran today and i am still hooking out of the corners. i have great turn in speed and off power steering but when i go in to a turn and have to let off the throttle the car does a loop, i have changed and checked every thing. tried diffrent tires and shocks. i put 7k back in it but that did not help. if i am slightly on the throttle i am ok but if i an out of the throttle and go back to it then i hook.
give me some ideas
flippz is offline
Old 11-08-2009, 12:20 AM
  #805
Amoeba's Avatar
give me some ideas
Is it hooking (front pulling) or is your back end sliding out? You might consider changing your clutch setup to give a smoother snap which may help. Some guys will use 2 aluminum 1 carbon or use a mix of 1.1, 1.0, 0.9 springs to vary when the shoes hit and get a progressive feel. I run 2 1.0's and a 0.9 with aluminum's and it's helped keep me from breaking traction.
Amoeba is offline
Old 11-08-2009, 11:59 AM
  #806
rider313's Avatar
a dragging brake is my guesse.
rider313 is offline
Old 11-08-2009, 02:22 PM
  #807
flippz's Avatar
its slidding out.if im off throttle turning in its ok but as soon as i hit the gas the car just spins in a circle. if i am straight im ok but if i have the wheels turned at all the car just spins out. i run hard alum. shoes and 1.0 springs.
i just noticed my left front cv axle is digging into the left front control arm when the suspension is fully loaded but unloaded it is fine. the right side sits in about 2mm closer to the diff. do you think this has anything to do with it?
flippz is offline
Old 11-08-2009, 02:32 PM
  #808
Default Tank
Can someone please help me i have followed the build instructions but i seem to have a problem with air bubbles in the fuel line which seems to be leaning my engine on and off, there does not seem to be much movement in the tank like i have in my losi buggy and the tank seems to hit the chassis very easily could this be causing the problem.
chewie76 is offline
Old 11-08-2009, 02:38 PM
  #809
flippz's Avatar
chewie,
unfortunately that is the akelis hill of the ae truck . the tank probaly has a internal leak and that is causing the air bubbles. try a new fuel tank and i bet that helps.
also you can use shock o-rings for insulators under the tank to keep the vibration down.but the antfaom in the fuel helps with that and the clunk container also helps eliminates the bubbles also.
flippz is offline
Old 11-08-2009, 02:54 PM
  #810
do i get another AE tank or one from a different truck, i have seen people with D8T and X2CRT tanks in them
chewie76 is offline
