Team Associated 1/8 scale Truggy Info and Tips >
Old 10-28-2009, 05:12 PM
  #751
flippz's Avatar
pm joey the rocket. hes seems knowledgeable and a good racer hes trying to unload his
flippz is offline
Old 10-29-2009, 02:46 AM
  #752
Gary-D8's Avatar
Hey, just hoping one of you guys can help me out. I am currently running the stock setup on a Factory Team kit and cant get rid of the push the truck has. Tires are not the problem because I have tried a few different types and still have the same problem to some extent. I am mainly after more turn in so I can hold more speed through the start of the corners. The way I drive, I can handle oversteer but just dont like the feeling of understeer and running wide through the tight corners.
If anybody has any advice or setups they can recommend it would be greatly appreciated. Our tracks over here are usually pretty rough so that has to be considered as well.
Gary-D8 is offline
Old 10-29-2009, 03:00 AM
  #753
try this 1st the diff. oil set-up 7k-7k-3k & 45f wt.,50r wt. shock oil
mbx5rcr34 is offline
Old 10-29-2009, 03:20 AM
  #754
flippz's Avatar
i run the 7-7-3 set up and helps a lot on turn in steering. if you change to maifields set up for the dirt nitro that gives you a lot of on power steering as well. i could not believe the diffrence it made.
flippz is offline
Old 10-29-2009, 03:28 AM
  #755
Gary-D8's Avatar
Thanks for the help guys. I'll try the 7-7-3 and see how that goes for a starting point and then just go from there.
Cheers,
Gary
Gary-D8 is offline
Old 10-29-2009, 05:32 AM
  #756
Trader Rating: 49 (100%+)
Also make sure ur servo saver is tight enough
cleblanc is offline
Old 10-29-2009, 09:20 AM
  #757
NJA82's Avatar
Trader Rating: 33 (100%+)
Easiest way to improve the turn in without messing with shock oils and diff oils is using the steering rack mod and the rc8b foward battery location, do this and you will be dialling steering out of the truck.
NJA82 is offline
Old 10-29-2009, 01:11 PM
  #758
Gary-D8's Avatar
Please excuse my ignorance but what is the "Steering Rack Mod"?
Gary-D8 is offline
Old 10-29-2009, 02:27 PM
  #759
rider313's Avatar
Trader Rating: 94 (100%+)
Originally Posted by Jamie007
89074 steering rod ends
89076 camber rod ends
89077 chassis brace rod ends
89211 3x26mm FHC screws (cut to 24mm)
89210 3x20mm FHC screws
25215 M3 lock nuts
89272 RTR aluminum steering rack
This is a RC8 but everything is the same except for the longer tie rods.
this is. go to page 38 for a pic. its about half way down.
rider313 is offline
Old 10-31-2009, 07:08 PM
  #760
flippz's Avatar
Default SHANERACER
SHANERACER: i got the parts today and again thanks a ton. i will post how i do at the sinners sunday race
flippz is offline
Old 11-01-2009, 08:12 AM
  #761
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
which jconcpets body does ryan maifield use?
Quad Racer 34 is offline
Old 11-01-2009, 08:39 AM
  #762
Illuzion – RC8T - Punisher body
Part # - 0060
(Fit for Associated RC8T) – requires additional Part # 2054 JConcepts rear body mount adaptor.
The Punisher body by JConcepts for the Associated RC8T is the meanest, nastiest thing out for 1/8th truck racing. Throw everything you know out the window, the Punisher separates itself from the rest of the bodies on the market with it’s distinctive styling.
Beginning with the newly re-designed grill and headlight treatment, the Punisher stares you down like a trained fighter. The hood and cab treatment are amongst the lowest in class giving the Punisher top notch performance. The bed area represents the latest offering for 1/8th truck racing featuring a super low profile design for increased engine cooling, air flow and escape.
The Punisher body is the choice of current and defending ROAR National Champion Ryan Maifield.
Features:
* Original JConcepts – Punisher styling
* Low profile inspired body, cab and window design
* Below engine head designed bed for increased engine cooling, air flow and escape
* Clear heavy-duty polycarbonate with protective film
* Window masks and detailed decal sheet
* 2009 ROAR National Champion design
**Please note it is necessary to install Part # 2054 JConcepts rear body mount adaptor to run this body.
Punisher body mount adaptor for RC8T - Maifield Edition
Part # - 2054
Adapt the popular JConcepts Punisher body to the RC8T truck with style, with the JConcepts body mount adaptor. Custom machined, lightweight pocketed, blue anodized with etched logo, this body mount adaptor is not only a functional part of the ROAR National Champion Punisher body but also aesthetic jewelry.
Features:
* Original JConcepts styling
* Adapts ROAR National Champion Punisher body to RC8T
* Custom machined, light weight and pocketed and blue anodized with etched logo
* Includes 4 – 3x12mm screws and 4 – 3mm lock nuts
** Required for use with 0060 Illuzion – RC8T - Punisher body
Hope this helped.
Chris Reilly is offline
Old 11-01-2009, 08:44 AM
  #763
Is the wing moved ahead on the truggy like the buggy ?
Old 11-01-2009, 08:46 AM
  #764
oops lol i meant to post this in the buggy section. do u know which buggy body he runs?
Old 11-01-2009, 09:59 AM
  #765
Mikey Hudson's Avatar
he runs the hi flow rc8 body
Mikey Hudson is offline
