Team Associated 1/8 scale Truggy Info and Tips >
Old 06-28-2009, 07:46 AM
  #616
lethalleigh29's Avatar
Originally Posted by Midnight
Dont take this the wrong way, but may be you need to evaluate your driving. Ive had some hard crashes with no breakage. The only thing Ive bent was the front cvd.
Me too ive only ever broken 1 rear hub and that was on the buggy but that was when i handed really akward
lethalleigh29 is offline
Old 06-29-2009, 12:15 AM
  #617
Amoeba's Avatar
To be fair to Wetfoot he pushes his truggy hard but both times the breakage didn't occur due to crashes. I was marshaling the last race where his hub carrier snapped and saw it happen. He wasn't tumbling, it was an off-center landing off a triple where his right rear wheel came down first and the hub snapped... which sent it tumbling.
I haven't had enough time on mine to know if the hub carrier is a weak point, though I'll definitely find out since my driving still sucks
I'd assume the only drawback to upgraded King Headz or MRC hubs would be bending the hinge pin? I think I prefer being able to finish a main with a bent pin over a snapped hub=DNF.
Amoeba is offline
Old 06-29-2009, 06:08 AM
  #618
JoeyTheRocket's Avatar
The AE aluminum hubs are out now. Also don't forget the a crash or two before the hub actually snapped is what damaged it first. I have come of the track before with no crashes and my hubs were cracked. Then I was able to stop scratching my head wonder why the truck changed so much.
JoeyTheRocket is offline
Old 06-30-2009, 03:41 PM
  #619
Trader Rating: 49 (100%+)
I had an rc8t before and ended up sellin it.. Just recently bought one again and bout to get it up and going. I was wondering if anyone else was having problems with servo horns? That's the only issue I had with my original truck was I was tearin up aluminum servo horns left and right. As soon ask would get the saver set to where the tires aren't lookin twitchy when it running, snap or bend. If any of y'all aren't havin problems with this, can you give me a measurement from the chassis to the bottom of the servo saver to get me in the ballpark? Thanks.
cleblanc is offline
Old 06-30-2009, 03:47 PM
  #620
cary's Avatar
Trader Rating: 67 (100%+)
the gap is like 8mm from top of nut to bottom of saver arm
cary is offline
Old 06-30-2009, 03:59 PM
  #621
JUST DOUBLE THE SERVO HORNS UP.ONCE I DID THAT ,I HAVE NOT BROKE ONE.JUST GRING THE PART THAT GOS ON THE SERVO.
AETRUGGYMAN is offline
Old 07-01-2009, 01:46 AM
  #622
its been 6 mons. of racing,practicing never had this issue on rear hub on the servo saver i would say the stock set-up is 8mm ,but i did 7mm ...........& i dont have problem w/ it ,my only complain is the damn stock clutch shoe set-up i tried the mc alum. shoe still too much filing lol, i heard good things about the fioroni sliding clutch good & less maintenance ,i want to know if this is really true or are the pro-drivers using this set-up too ??
mbx5rcr34 is offline
Old 07-01-2009, 05:45 AM
  #623
MBR52's Avatar
Trader Rating: 8 (91%+)
mmmm, thats funny. I have ran the clutch (Standard and M2C) for 6 months now and not once have I had to get out a file. And I am only on my second set of shoes... This is the first time I have used the M2C and if anything, i like the standard shoe more, but everyone sees things differently
Cheers All
MBR52 is offline
Old 07-01-2009, 06:04 AM
  #624
im sure this question has been asked before but what it the best oil spring setup for the 8 x 1.3 pistons
And what oil / Springs are best for the 10 x 1 springs.
Cheers
Old 07-03-2009, 12:39 PM
  #625
Trader Rating: 14 (100%+)
Does anyone know if the new RC8B radio tray and battery box will fit on the RC8T??
Slippery Dan is offline
Old 07-03-2009, 02:00 PM
  #626
NitroFreakManHo's Avatar
You bet it will. Hoosier just put up a thread for it on Truggyracers
NitroFreakManHo is offline
Old 07-03-2009, 03:07 PM
  #627
It definitely fits i just put one on my truggy. Yet to try it out but it looks neat at least.
ace955 is offline
Old 07-04-2009, 05:20 AM
  #628
Are they available yet.
Old 07-05-2009, 12:21 AM
  #629
Yes they are .I got mine from Kelletts in Sydney on Friday
ace955 is offline
Old 07-05-2009, 12:31 AM
  #630
thanks mate.
