Team Associated 1/8 scale Truggy Info and Tips >
Old 02-16-2009, 09:18 AM
  #451
Scottmisfits's Avatar
This is Mike Hudsons. He took a piece of carbon, a B44 battery strap would work well, and used heatshrink around the battery and the brace.
Scottmisfits is offline
Old 02-16-2009, 09:43 AM
  #452
jeff alessi's Avatar
Originally Posted by bottomline2000
shock length they are referring to is droop and you want to measure from the middle of the top screw to the middle of the bottom mounting screw. A digital caliper works wonders for stuff like this.
do u measure with a caliper when the cars on the ground or when its off ground. so should it be 113 in front and 123 in rear when the cars sitting on a stand or all for wheels on the ground dropped and the suspension settled?
jeff
jeff alessi is offline
Old 02-16-2009, 09:47 AM
  #453
jeff
You measure droop with the car on a stand and the shock mounted on the car.
113 front and 123 rear. (I don't know if this is the setting for the RC8 as I don't own one). Like said before you measure from the center of the mounting screws.
Alan D. is offline
Old 02-16-2009, 01:52 PM
  #454
Trader Rating: 23 (100%+)
Default Droop
Just set the car up on a spare set of wheels or on a stand and measure from the middle of the top bolt to the middle of the bottom bolt with your calipers. To set ride height you put the car on the ground with the tires on and a half tank of fuel in it. Then you measure from the ground to the flat part of your chassis on the front and the back. Instead of using digital calipers I would get the associated ride height gauge for this.
Jmnay_83 is offline
Old 02-16-2009, 03:22 PM
  #455
Default shock length/droop
RevRace, just so you know. you set the shock length with the droop screws on the inside of the arms and ride height with the preload adjustment on the shocks. Not sure of your skill level, but did want to point that out before you started rebuilding your shocks..lol.
bottomline2000 is offline
Old 02-16-2009, 07:59 PM
  #456
revrace's Avatar
Thanks for all of the replies on the shocks. For the steering mod, is it the exact same parts as the buggy steering mod, if not could someone please post what parts I need? Also, are the AKA truggy wheels zero offset...I just bought two full sets of tires and wheels but haven't glued them yet.
revrace is offline
Old 02-17-2009, 03:51 AM
  #457
Shane Racer's Avatar
You will need 92mm tie rods. every thing else is the same.
AKA truggy wheels are zero offset.
Shane Racer is offline
Old 02-17-2009, 06:16 AM
  #458
revrace's Avatar
Perfect!! Thank You
revrace is offline
Old 02-19-2009, 06:54 PM
  #459
Hutch301's Avatar
Trader Rating: 29 (100%+)
Questions?? steering mod RC8T
I am very curious about this steering mod ya'll talk about on the RC8T. I adjusted the radio for more steering but I ended up cracking my castor blocks. The hub was hitting that front flap when I turned it all the way which eventually cause it to crack. Are ya'll replacing the castor blocks and if so with what? I would appreciate it if someone would post a link, picture, or just described it in a little more detail because as it sits I do not get enough steering for my liking. Thanks.
Hutch301 is offline
Old 02-23-2009, 11:29 AM
  #460
Jamie007's Avatar
Default RC8T Update
Just wanted to post my experience so far with the RC8T. Within the first 10 min of running it I broke a rear hub, which I was expecting after reading this thread. I replaced it, and immediately broke another one, bent a hinge pin and cracked a A-arm. I have since picked up the M2C hubs and have not had any issues since. The M2C hubs are really nice, can be used on either side, and even come with 4mm hinge pins and a drill bit for modding A-Arms! and are cheaper then anything else I've seen, I highly recommend them!
Also I'm using the SC8 plastic chassis mounts, and they are holding up great, even after several cartwheels, some hardcore wrecks, and some 20ft+ jumps. This truggy is stonger then I thought! I'm very happy with it. I'm currently using 7 - 10 - 5 for my diff's in my brushless setup, and it is working very good. However sometimes it is hard to keep the front wheels touching the ground and will probably try 15 in the center diff.
Jamie007 is offline
Old 02-23-2009, 11:55 AM
  #461
JoeyTheRocket's Avatar
I also have to say I'm very happy with the truck! I have had mine since last October I haven't broken one part. In fact I have gone through 2 v-specs before anything has worn out.
JoeyTheRocket is offline
Old 02-23-2009, 09:47 PM
  #462
wetfoot's Avatar
I just ordered mine yesterday. It will be here on Thursday.
wetfoot is offline
Old 02-24-2009, 07:59 AM
  #463
NitroFreakManHo's Avatar
Just dremmel the 'shield' castor blocks using a sanding drum, and the hubs won't hit anymore. As for the steering mod, I did it, but haven't run it yet to tell you what it did. It looks like it will work great though, it took away any bump-steer, and made the outside tire turn in nearly as much as the inside tire.
Here's a pic, with the original ackerman plate shown:
I just painted these for Canadian Winter Nats 09:
NitroFreakManHo is offline
Old 02-24-2009, 11:57 AM
  #464
Trader Rating: 14 (100%+)
Does anyone have a part number or brand for these?
Thanks.
Slippery Dan is offline
Old 02-24-2009, 12:47 PM
  #465
http://www.lunsfordracing.com/mm5/me...egory_Code=4MM
