Team Associated 1/8 scale Truggy Info and Tips >
Old 09-05-2013, 05:24 PM
  #4381
portyansky's Avatar
Trader Rating: 54 (100%+)
It's been a good 8 years running Mugen(guess I should change my avy). I picked up a AE 7/10/3 40/35 a good start? Run medium grip bumpy top soil. Oh yea going electric first to finish off the year.
portyansky is offline
Old 09-05-2013, 05:41 PM
  #4382
The truck should feel great with those oils. I like to go even thicker in the shocks some times. If you are building a new kit I would advise not to put two shims under each sun gear in the diffs like the manual suggests. Put one shim under each, assemble it dry and see how it feels. Then put the other two shims and see how it feels. If you can feel extra resistance after adding the shims take them out. You will lose a lot of corner speed with the front diff shimmed too tight.
There are some situations where the rear end gets a bit squirrely on turn in with 3 in the rear and in those cases I like to bump it up to 5. I find the 7 works great up front when the diffs are shimmed so there is no resistance from the shims. When I was running the four shims up front like the manual suggested, my truck pushed unless I took the oil down to 5 in front.
jhrbacek is offline
Old 09-05-2013, 05:52 PM
  #4383
portyansky's Avatar
It's. 4 or 5 race day old CE. I'm taking the diffs out tomorrow. He has something crazy like 10/7/7 (or maybe he said 10/5/7 yes, f/c/r) and then he wonders why it doesn't steer....
Old 09-05-2013, 07:08 PM
  #4384
The truck turns on a dime. If he had problems with lack of steering, and the servo saver wasn't loose, then I am 95% sure he has two shims under each sun gear. It was unbelievable how much better my truck handled when I took them out. I really have no idea why AE suggests to use all four.
jhrbacek is offline
Old 09-06-2013, 04:20 AM
  #4385
I had to add 1 extra shim to my rear diff after stripping it twice within 1 gallon of fuel. Since adding the extra shim I've had no problems out of my rear diff. I guess maybe you could get away with a loosely shimmed diff in the front, but I wouldn't recommend it in the rear.
Micah78 is offline
Old 09-06-2013, 05:55 AM
  #4386
portyansky's Avatar
He is referring to the shims inside the diff cups.
Old 09-06-2013, 09:25 AM
  #4387
ABN Hoosier's Avatar
Trader Rating: 20 (100%+)
Porty!
ABN Hoosier is offline
Old 09-06-2013, 11:24 AM
  #4388
I'm referring to the shims inside the diff cup as well. I stripped the "spider" gears inside the diff cup two times in a row. I added an extra shim behind one of the sun gears and haven't had a problem since.
Micah78 is offline
Old 09-06-2013, 01:50 PM
  #4389
portyansky's Avatar
Originally Posted by ABN Hoosier
Porty!
What up ABN. Loooooooong time no "see"
Old 09-06-2013, 03:11 PM
  #4390
Trader Rating: 29 (100%+)
what size of shim behind sun gears ? only rear ? what about front one shim behind a sun gears ??
taztal3 is offline
Old 09-06-2013, 03:42 PM
  #4391
Trader Rating: 41 (100%+)
Go my new rc8t ready and started break in today..had a problem at 1/4-1/2 tank of fuel.it would start bogging lean --not enough fuel? I could top the tank off at this point and it run fine,,bad fuel tank?mabe air leak in tank? give me your thoughts.I am sure someone has had this problem..
Thanks,Tommy
rifraf is offline
Old 09-06-2013, 03:54 PM
  #4392
Thanks,Tommy
might be the tank but check the fuel lines , I ran glow for allot a years i really dont miss it at all , i`m now running my truggy electric so much cleaner and dependable
mavdriver is offline
Old 09-06-2013, 08:14 PM
  #4393
Electric - yuck...
Herrsavage is offline
Old 09-06-2013, 08:41 PM
  #4394
I was racing nitro until 8yrs ago,gettin back into it now..I have raced nitro for about 20yrs..the first thing I did was replace to NEW kit fuel line..I was just wondering if anyone has had trouble in the past with a bad fuel tank from Associated...
rifraf is offline
Old 09-06-2013, 09:03 PM
  #4395
portyansky's Avatar
If you see air bubbles in your fuel line going into the engine then most likely your tank is not good. Best way to test the tank is to empty it, place a long fuel tube on it, submerge it in water blow into the line while plugging the other end with your finger, if you see air bubbles then your tank is pooched.
I have done this method for many questionable tanks, some passed the test (which meant it was something else) and a few needed replacing.
