Team Associated 1/8 scale Truggy Info and Tips >
Old 08-20-2013, 06:16 PM
  #4351
ABN Hoosier's Avatar
Trader Rating: 20 (100%+)
wondering....RC8.2T...
ABN Hoosier is offline
Old 08-21-2013, 07:00 PM
  #4352
coneman's Avatar
oh yeah.
coneman is offline
Old 08-24-2013, 12:53 AM
  #4353
Trader Rating: 29 (100%+)
what brand big dome cap and shock body from?
taztal3 is offline
Old 08-24-2013, 07:56 AM
  #4354
Those are Kyosho shocks. Not just the cap, the whole shock.
Old 08-26-2013, 09:07 AM
  #4355
I just recently replaced all of the driveshafts on my RC8T. I bought the truck last year used. So far the truck as been pretty rock solid. I've been slowly replaceing worn parts on the truck as needed and decided to replace the driveshafts because I wanted to start over with fresh/unbent shafts. First off this was a big mistake because I am also building a track at my house. building a track means lots of bad landings when trying to figure out how to space the mounds of dirt to actually be able to land it smoothly. Consequently this means that I have found out just how easy it is to bend an outdrive! It seems like the fronts take all the abuse because I have bent them several times and not had a problem with the rears. My real issue though is that I have snapped the ball/dogbone end off of 2 shafts on the rear. These are brand new driveshafts that I just ordered from Amain. I just rebuilt the rear diff and it is working smoothly. I'm wondering if there was a bad batch of driveshafts from Associated or if there is something wrong with my truck. Is it common for people to snap driveshafts on the RC8T?
Micah78 is offline
Old 08-26-2013, 12:37 PM
  #4356
hyperfuxx's Avatar
Trader Rating: 32 (97%+)
You might have too much droop in the front. When I first started running the truck I bent a few. And if you crank the steering hard on a landing that also adds to it.
hyperfuxx is offline
Old 08-26-2013, 04:15 PM
  #4357
has anyone replaced the top arms with turnbuckels like they do on the buggies with the truggy?
brendon.matt is offline
Old 08-26-2013, 04:20 PM
  #4358
no need is fine the way it is
mavdriver is offline
Old 08-26-2013, 04:34 PM
  #4359
Yep i also bent my front shafts , i recently replace with new ones , haven`t had no problems so far , knock on wood and i drive my truggy hard big jumps end over end flips , love this truck
Old 08-27-2013, 06:16 AM
  #4360
i find im replacing more top arms then bottoms due to them bending
Old 08-27-2013, 08:48 AM
  #4361
Has anyone broken their axles? Mine have snapped of right at the diff output cups twice in the rear. The cups don't look worn and nothing seems to be binding. This was the kind of shit I used to deal with on my big block tmaxx. I figured moving up to an 8th scale truggy built to handle big block nitro power would pretty much eliminate these problems. I guess I probably just got a bad batch of shafts from AE. Just like the steering posts I bought where one of the posts had no threads in it. Quality control anyone?
Micah78 is offline
Old 08-27-2013, 12:57 PM
  #4362
Bigwave's Avatar
If you run too much droop on the truggy then you can have issues with shaft bending or breaking, back the droop off.
Bigwave is offline
Old 08-27-2013, 01:15 PM
  #4363
I guess I'm showing my ignorance here but, how do I back of the droop? I'm not sure what droop is or how it could cause the rear driveshafts to snap like twigs at the diff output cup. I'm not saying your wrong, I just don't know what droop is or how it correlates with the axles snapping.
Micah78 is offline
Old 08-27-2013, 01:22 PM
  #4364
There are grub-screws on the insides of the arms. Screw them in to reduce droop - equally on both sides.. Set the truck up on something so the arms are hanging down. You should see the angle of the arms change(the angle at which they hang basically being the droop...)
Just a random idea - but I also have a TT MT4 G3, and with these there has been some random snapping of shafts. Not sure if they're made in the same factory (TT owns AE), but with the MT4 G3 parts anyway, it seems like there was a bad batch at some point. Because normally they're very very tough. I had a rear shaft snap last winter. OK, was about 0C out, but I wasn't doing anything too crazy.. Just an idea...(that there may have been a bad batch - because that seems to be what happened with the MT4 G3/ST-1 axles..)
Herrsavage is offline
  #4365
mgtmadness2007's Avatar
What about the monster gt axles? Would they fit? I cannot remember. Ttr st1 axles may fit also.
mgtmadness2007 is offline
