Team Associated 1/8 scale Truggy Info and Tips
#4066
hi im new and just playing with my rc8.2 as a basher. id like to know if the rc8t fuel tank will fit in my buggy for a little longer run time thanks to all who reply i realize its only 25cc bigger but should get 2-3 minutes if it fits. i think it looks like it will but want to be sure
#4067
#4070
Does anyone run the Dynamite Max Life clutch shoes for RC8 on the stock clutch? Any good?
#4071
Yea I run them, have been for 3 years, they do build a little heat in the bell if the track is tight, but all I do is trim my shoes after every race day and check my bell bearings. All in all the maxlife shoes are good, I get about 2 to 3 gallons out of them.
#4073
#4075
chassis
Has anyone tried the new BCE+3mm chassis yet,if so are you using the mugen rear center drive shaft. If you are what is the part number for it. I am thinking of buying one of the chassis, but I don't know anything about it. Thanks ArronRc.
#4076
I just got done switching everything over to the BCE chassis. I used some shims as stated a page or 2 back. It seems to be okay with the shims.
#4078
#4080
I was thinking I was on the BCE thread when I said a couple of pages back. The things I had to do was add some engine shims to move the rear center cvd closer to the center diff. The other was I cut the center diff riser shim. So the front and rear chassis braces would bolt directly to the chassis. Oh and one more thing. I had to open up the hole where the D plate tab goes. BCE said they leave it small so you could use older parts or something like that. Other than that everything bolted right up.
