Team Associated 1/8 scale Truggy Info and Tips >
Old 11-10-2012, 07:22 AM
  #4051
Thanks.. To be honest, I shimmed it last time, and the caster block broke on the very next outing to the track. I only had one small shim in there(up front), and there was no binding or anything - it felt like I would expect it to feel new more or less. Maybe the shim played no role and it was just coincidence.. But as it is now, that to me feels like way too much slop..
Herrsavage is offline
Old 11-10-2012, 04:33 PM
  #4052
carpet Carlos's Avatar
Mine had that play from new literally right after built same with me buggy
carpet Carlos is offline
Old 11-10-2012, 06:26 PM
  #4053
Bigwave's Avatar
Loose = Fast. If it doesn't drive poorly then don't sweat it, it's all about how it feels when actually driving it, not how it seems on a stand.
Bigwave is offline
Old 11-10-2012, 09:10 PM
  #4054
I love my truggy !
Old 11-10-2012, 10:50 PM
  #4055
I believe you of course, so I'll just leave it. But speaking from my own experience, my SC8 doesn't have slop like that, nor my RC8.2. Neither did my first RC8T, RC8, or RC8B.. That just seems like a lot of slop is all.. Maybe I just need some new red bushings. Has to be that - because the arms are new, the pins, and I think even the hubs..
Old 11-11-2012, 12:40 AM
  #4056
christmaxx's Avatar
My truggy has had the slop in the rear arms since new. the hole in the arm on one side is oval for some reason letting it move forward and back about 1mm it changes the toe angle slightly when it does it but i cant tell it does it on the track.
also on a side note for those bending axles, i found this mod on another forum. i have not tried it but they look stronger.
http://www.beatyourtruck.com/forum/s...ge-scale-build
christmaxx is offline
Old 11-11-2012, 07:29 PM
  #4057
djbclk430's Avatar
Trader Rating: 59 (100%+)
hey guys i just got the kings headz 1.5mm offset motor mount when iuse the stock clutch bell it is not lining up with the spur gear to far back what are they running for clutch bell or mod to remedy this? Any info would be appreciated THANKS!
djbclk430 is offline
Old 11-13-2012, 09:08 AM
  #4058
What do you guys think about the narrow hexes vs the standered hexes
Old 11-13-2012, 04:35 PM
  #4059
DaveW's Avatar
Use the narrow hexes... toss the wide ones.
DaveW is offline
Old 11-13-2012, 04:49 PM
  #4060
R/C Lidz's Avatar
that mount is for when you use an aftermarket clutch that has a flat flywheel (i.e. Werks, Ascendancy, etc). The stock AE flywheel has an offset that allows the clutchbell to sit back. With the flat flywheels the clutchbell is pushed forward to the point where only half of the teeth make contact.
R/C Lidz is offline
Old 11-16-2012, 11:43 AM
  #4061
Trader Rating: 29 (100%+)
i cant wait to see new truggy out yet ?
taztal3 is offline
Old 11-16-2012, 11:47 AM
  #4062
What new truggy ?
Old 11-16-2012, 01:54 PM
  #4063
what i mean that i hope new truggy out now but i can be patient myself .
i know that they working on new nitro buggy at world . it is worth to wait that all
taztal3 is offline
Old 11-16-2012, 02:22 PM
  #4064
I hope they do and hope they don't. I just rebuilt my truggy
Old 11-16-2012, 08:15 PM
  #4065
djbclk430's Avatar
Smile
